Old 07-30-2012, 03:55 PM   #3631
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by mr lee View Post
The 416WE/X and 417 share the same suspension parts so the C hubs are still the same. The standard 416 also had the same Chubs, knuckles and rear hubs but the suspension arms were different.
Actually the chubs were updated some time in the 416WE model cycle. The original hubs off the 416 were far less meaty and more brittle than the current ones, so the mould was changed but the part number stated the same
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-30-2012, 04:56 PM   #3632
hello, i need some help, im owner of a 417x, im not an experimented driver, i want to know how to make the steering smoother cause mine is a little bit nervous.
thanks
osorron is offline   Reply With Quote
Old 07-30-2012, 05:24 PM   #3633
Trader Rating: 54 (100%+)
thanks
Is the steering rack properly shimmed? I had this issue when I had a 417. Jilles looked it over at 2011 snowbirds and fixed it. There is a shim not mentioned in the assembly instructions that needs to be used. It will bind up if not used.
Jamison R is offline   Reply With Quote
Old 07-30-2012, 07:37 PM   #3634
Which shim is that one?
Old 07-31-2012, 09:01 AM   #3635
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I build my steering assembly by the book and it couldn't be any smoother.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-31-2012, 09:27 AM   #3636
417 or 417x? I had the 417. I built mine by the book too. It tightened up about half lock. Just my personal experience
Old 07-31-2012, 09:28 AM   #3637
rosko's Avatar
Wonder how long for the 418 wc car to hit the shelves
rosko is offline   Reply With Quote
Old 07-31-2012, 10:01 AM   #3638
Thanks, good to know.
mr lee is offline   Reply With Quote
Old 07-31-2012, 10:12 AM   #3639
PutAwayWet's Avatar
Unless there's a change to the screw pattern of the bulkheads (ie. new bulkheads), I don't expect there to be a 418. Every significant change I've seen since the 417 has come out has been in manipulating flex through different decks. That, and including gear diffs in the kit. Unless I'm mistaken, I see kit bulkheads on Jilles' car. Even the new servo mount looks like it's simply retrofitted to an existing deck. The outside mount hole is still there. 417 WC kit...absolutely. I don't see why it would be a 418, however.
A sharper-eyed person may come to a different conclusion...
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 07-31-2012, 10:56 AM   #3640
Super Moderator
417x, same car the guy you responded to is running.
- RCSpecialties -
Old 07-31-2012, 11:12 AM   #3641
artwork's Avatar
I think it is more likely to see a 417 World Championship edition...I would not expect a 418 until next year at the earliest. Unless they move the bulkeds and have to redrill the bulked holes in the chassis, then you won't see the number increment to 418.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is online now   Reply With Quote
Old 08-02-2012, 03:35 AM   #3642
CraigM's Avatar
I wonder if the new car will come with 0.5mm shims for under all the bulkheads?
Can any trainspotters out there figure out what damper cylinders they used at the worlds? I thought they were the TRF buggy ones but the buggy HL dampers won't take the blue lower cap - their lower shock cap is an insert style.
http://www.rcmart.com/tamiya-42132-c...h=595_744_1011
Old 08-02-2012, 03:54 AM   #3643
RC MARKET's Avatar
TAMIYA new lower deck 2.5mm arrived
RC MARKET is offline   Reply With Quote
Old 08-02-2012, 04:10 AM   #3644
What about the new Tamiya upper deck? Will you be getting those in soon as well?
Thx!
mhavlena is offline   Reply With Quote
Old 08-02-2012, 05:59 AM   #3645
Possibly a prototype....
They do not look like anything else that is currently available.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
