Like Tree1Likes
Old 07-19-2012, 03:29 AM   #3541
hlucn8r's Avatar
Originally Posted by mingnon View Post
Craig
started to build the new 417X using the blog is working a treat so far
trying to work out gearing for stock (17.5) at sma, does 75, spur, 25pinion giving a fdr of 5.841, does that sound okay or to high/low for a tamiya
Hey mate at our local track up here we are starting at a 3.5 fdr for 17.5, I'm running 48p, 65 spur - 36 pinion. I find it is on pace
Milton Lincoln
Fraser Coast RC Car Club/FCRCCC
Hotbodies TCXX ~ B-max 2 MR V2 ~ Ko ~ Speedpassion ~ Hobbywing ~ Ryan Dezign
hlucn8r is offline   Reply With Quote
Old 07-19-2012, 03:32 AM   #3542
hanulec's Avatar
Trader Rating: 27 (100%+)
Anyone have or know of a good setup for tamiya b3 tires and an nsx body
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-19-2012, 04:07 AM   #3543
CraigM's Avatar
Trader Rating: 34 (100%+)
17.5 is boosted in Australia
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-19-2012, 04:19 AM   #3544
TRG
TRG's Avatar
Craig
It sounds to high to me. I would first check with your motor manufactures recommendations, then start stepping up from there. I run a 17.5 LRP X12 in mine. Manufacture recommends FDR of 4.0 and I'm getting most success with a fdr of 3.82 or 3.89 (depends on track).
I'm using 64p gearing - Spur 96, Pinion 49 (fdr 3.82) or 48 (fdr 3.89).
In 21.5 (hobbywing) I'm using fdr 3.5. 64p pinion 49, spur 88
Both classes I'm running in Blinky.
Good luck,
Hope this helps.
TRG is offline   Reply With Quote
Old 07-19-2012, 05:03 AM   #3545
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Which track is that? What are the approximate dimensions? I'm guessing outdoor...
Craig, it is for AARCMCC classes, but there are some variations between states as 17.5 blinky seems common in QLD and that's what they're going to run for their State Titles.
Somewhere in the high 3's would be reasonable for blinky 17.5, depending on track size and layout.
At SMA (and elsewhere that runs AARCMCC 17.5), we run boosted 17.5.
Matt - the biggest factor in gearing for stock is your motor and ESC. There are guys who run close to 5.0 and guys who run over 6.0. Your "style" on the throttle starts to play a big part in the picture, because often the guys running lower FDRs are probably better on throttle control, so heat is less of an issue. If you combine lower FDRs with aggressive boost/turbo and tend to mash the throttle, you'll smoke the motor pretty quickly. Quite a few went up at the ACT Indoor Titles last weekend due to the extra strain that the higher grip puts on the motor. A lot of people throw too much timing too early at the motor and all it does it get hot. Quickly.
Also, some motors like to spin fast, so you gear 'em shorter. I ran an FDR of around 6.2 at Whalan last year and the darn thing was still accelerating at the end of the straight. That was with a Fanton Ion 3 and Tekin RS and it didn't get hot The Hobbywing speedies tend to work better with lower FDR's than the Tekin.
What motor/ESC are you thinking of running? Once you know, go hit up the guys who run that combo. In a couple of weeks, I'll be making the switch too and starting with the Ion 3/TekinRS set. I'm thinking around the 6 mark, FWIW.
Needless to say, I won't be one of the quick guys
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 07-19-2012, 05:12 AM   #3546
PDR
PDR's Avatar
Sorry, I meant to check something here. For 21.5, are you running a Hobbywing motor? It's interesting that the bulk of guys locally are running FDR's in the 2.9 range for 21.5 blinky and getting good results, but that's with motors that are definitely on the "torquey" side. My Orion Vortex VST has worked a treat at around 2.85, but is starting to fall apart, so I'm contemplating new motor options.
Old 07-19-2012, 01:26 PM   #3547
mingnon's Avatar
Thumbs up
Phil
am going to be running a reedy sonic and hobbywing 120A V2.1 (bought from Steve). I wont be running with the stock guys, going to finish the build, then try to learn the intricacies of stock for a couple of months and practice a fair bit. Am still putting all attentions to the 21.5 at the moment (as its slowly paying off).
Think i will aim for 6 to start with and work my way from there. I dont think anyones running a reedy in stock at the moment, will check on Tuesday night.
Thanks everyone for their help
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 07-19-2012, 05:05 PM   #3548
hlucn8r's Avatar
Thats right here in Qld we run 17.5 blinky, I run the 3.5 fdr at most tracks up here Fraser Coast, sunshine Coast, Bayside and at Logan.
Yes all outdoor.
When I first started racing about 3 years ago we were running 17.5 boosted then it changed to blinky. I have not yet raced in other states.
Milton Lincoln
Old 07-19-2012, 08:07 PM   #3549
barts71m's Avatar
Just a heads up Phil and Matt. Id gear between 5.5 & 6 fdr for SMA with that motor combo. Im interested to see how the Reedy motor goes in stock.
barts71m is offline   Reply With Quote
Old 07-20-2012, 12:10 AM   #3550
CraigM's Avatar
Don't die wondering
Old 07-20-2012, 12:48 AM   #3551
mingnon's Avatar
Im going to start at 6 and get used to driving it, then work way down i reackon. I don't want to get to cocksure and drive the new trf417x into the fence (to often).
Probably going to be months yet before i stick it in a Tuesday night stock race anyways.
Old 07-20-2012, 04:31 AM   #3552
CraigM's Avatar
From my extremely limited experience I think the reedy motors like an extra tooth or two. I'd start at 5.5
Old 07-20-2012, 04:38 AM   #3553
mingnon's Avatar
cheers Craig
Old 07-20-2012, 05:10 PM   #3554
mingnon's Avatar
Probably an easily answered question but i have no idea.
With the 51472 Sep suspension mounts, why does it have 1XA and 1A stamped/printed on the mount?
Old 07-20-2012, 05:13 PM   #3555
artwork's Avatar
Trader Rating: 60 (100%+)
Because these mounts can be either 1a or 1xa based on which way you install them. The setting you want goes towards the center of the car.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
