Old 07-18-2012, 09:31 AM   #3526
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
What springs are most 417x guys running on asphalt? Can anybody point me towards a tuning set?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-18-2012, 09:36 AM   #3527
artwork's Avatar
Trader Rating: 56 (100%+)
Either silver or blue HPI springs...I have been running Blues and they work very well on a lower bite surface.
See chart for information...
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 07-18-2012, 09:59 AM   #3528
Originally Posted by asuradahk001 View Post
Just testing in my TA06
Do we know whether these shims would work in a Gear Diff Unit II?
Perhaps, if you could provide the dimensions of the TDX shim, that would be great!!
Thanks!!
mhavlena is offline   Reply With Quote
Old 07-18-2012, 10:04 AM   #3529
Super Moderator
The HPI springs all look much heavier than the tamiyas... Do guys ever run Xray springs on their tamiyas?
- RCSpecialties -
Old 07-18-2012, 10:41 AM   #3530
John.C's Avatar
Trader Rating: 36 (100%+)
Keep in mind that the HPI springs require the large diameter retainers. I've also used Reflex Racing springs on asphalt with great results. These work with the stock retainers. If your in the position of buying new springs I would start with these two (HPI and Reflex). I do not know anyone that runs the Xray springs on their Tamiyas.
John.C is offline   Reply With Quote
Old 07-18-2012, 03:40 PM   #3531
Super Moderator
I have the large retainers coming in the mail. Those reflex springs look pretty nice.. do they hold their shape/tension well over time? Also, is there a reason you/others dont run tamiya springs?
- RCSpecialties -
Old 07-18-2012, 05:48 PM   #3532
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Where can I get bulk Aluminium screws for both 417x and TA06?
Thank you,
M.E.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 07-18-2012, 06:11 PM   #3533
GMartinez's Avatar
Trader Rating: 85 (100%+)
Thank you,
M.E.
check ebay
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-18-2012, 08:01 PM   #3534
YmeBP's Avatar
Trader Rating: 32 (100%+)
Thank you,
M.E.
scratch that they don't have them anymore .,..
check here
http://www.fastener-express.com/metr...ap-screws.aspx
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-18-2012, 10:31 PM   #3535
veecee's Avatar
Trader Rating: 34 (100%+)
check here
I tried these guys before. There's a good chance the blue won't match. I even had screws in the same order in various shades of blue. They then told me that they have a lot of difficulties with blue screws. Might be ok if you are in the US and returns aren't a hassle. But if you're outside the US, I'd think twice...
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 07-18-2012, 11:28 PM   #3536
Nuno Gancho's Avatar
Hi, do anyonye use diff in front, with what oil and in what condition, will it leak, what to do to prevent them to leak.
Nuno Gancho is offline   Reply With Quote
Old 07-19-2012, 01:08 AM   #3537
CraigM's Avatar
I've tried reflex, they are ok but I still prefer HPI or Ride. No one uses tamiya springs on asphalt, HPI have better grip and feeling and are have finer steps in tension. Normally just silver all round, sometimes blue or pink
500k oil or higher, or even better putty. Oil will still leak, but slower than 1k. I frequently use a putty diff if I want to make my car easier to drive or get into corners better.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-19-2012, 02:20 AM   #3538
But with the putty after five runs it gets under the big side spur gear forcing it out and then gets damaged, do you still use sand paper to work on the spur gear or assembly directly from bag.
Old 07-19-2012, 02:38 AM   #3539
mingnon's Avatar
Craig
started to build the new 417X using the blog is working a treat so far
trying to work out gearing for stock (17.5) at sma, does 75, spur, 25pinion giving a fdr of 5.841, does that sound okay or to high/low for a tamiya
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 07-19-2012, 02:52 AM   #3540
CraigM's Avatar
I use the gears straight from the parts tree, no sanding just trim. I've never had a putty diff fail
Originally Posted by mingnon View Post
Craig
No problem, I'll finish the blog tonight! That gearing sounds ok to start with but you're best to check with the stock gurus
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
