Like Tree1Likes
Old 07-13-2012, 09:04 AM   #3481
where can i buy "TDX SMART shim for TAMIYA TRF417 gear diff (0.3MM)"??
asuradahk001 is offline   Reply With Quote
Old 07-13-2012, 09:22 AM   #3482
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
RCMarket is your friend
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 07-13-2012, 09:49 AM   #3483
The shock towers are 417x towers.
So the differences are
2 gear diffs (no spool)
Blue edged stickers.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-13-2012, 11:05 AM   #3484
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
The lower deck on the newer TRF417x Reedy Race chassis looks an awful lot like the image on Kentech's blog.
He updated the blog saying that it was a 2.5mm not 2.25 but maintained the same cutouts, but the Tamiya site says it is 2.25 with additional fles(additional cutouts)
I think there is a THIRD TRF417X chassis on the way which is the MR edition, 2.5mm with MINIMAL cutouts... Until we get images for
42232 TRF417X Lower Deck (2.5mm)
42233 TRF417X Upper Deck (2.5mm)
We wont know...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 07-13-2012, 12:39 PM   #3485
can anyone identify this kit? the current bid is quite tantalizing.
ebay .com/itm/R-C-RC-Auto-1-10-1-10-scale-kit-Car-for-Tamiya-TRF416-TRF-416-416WE-chassis-/160816249666?pt=Radio_Control_Parts_Accessories&ha sh=item2571653b42#ht_6668wt_1393
scott.wilson is offline   Reply With Quote
Old 07-13-2012, 02:26 PM   #3486
mingnon's Avatar
Cheap knockoff of trf416.
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 07-13-2012, 02:29 PM   #3487
svndayNZ's Avatar
Trader Rating: 20 (100%+)
We wont know...
Mate with all due respect, this hobby is just that, a hobby.
A place where we can leave behind our professional lives and have some enjoyment out of these things. I've read several of your posts and each one is commenting on chassis flex and how certain things are better than others. If you get into over analyzing chassis flex in a tiny hobby like this you'll never never enjoy it. Get out there and have fun.
svndayNZ is offline   Reply With Quote
Old 07-13-2012, 02:42 PM   #3488
chineese knockoff.
Old 07-13-2012, 02:45 PM   #3489
That is exactly as I do, Have fun. I just never knew how much flex plays a role in the handling, until I started experimenting myself- while having fun. Its just some info I found and hopefully someone doesn't buy a particular part because of a misprint, or etc. We all do our own research, wether is on the 'net, hands on, or by peers, we share it to help each other improve. $100 is quite a bit to dump into a chassis upgrade that could go towards spares or a date with the wife or outing with the children. I'd hate to see someone spend it on a chassis part with one expectation and get something completely different.
A forum, is just that, a forum which people can share information, opinions and thoughts. The track I race on is very competitive, and I have yet to reach my chassis' full potential and I am not even messing with gearing yet... The culprit I believe is chassis flex. Hard, sharp turns I have tons of steering, yet my chassis performs flawlessly on slower sweeping turns. Additional camber in the front is leading to excessive tire wear on only one tire, increased rear camber and increased spring rate causes the rear to slide and it skips on the traction compound soaked sections causing hopping and traction roll.
That is the reason I am focusing on flex. that flex which only appears to happen at one part of the track and less steering input is needed when turning right. The chassis is balanced(as well as I can make it)
Old 07-13-2012, 03:42 PM   #3490
Been out of the game for a few months. Has there been a solid fix for the gear diff II washer conning problem some people have experienced?
cheers
Obsidian is offline   Reply With Quote
Old 07-13-2012, 06:50 PM   #3491
tmomedrano's Avatar
Originally Posted by CraigM View Post
Good point about the split between front and rear link heights, the split between them affects the balance and the height affects the level of mechanical grip. It's not clear what end of the car you are talking about though?
When I used to run xray, Hagberg told me a higher inboard front link will give more initial steering, and a lower link will give more mid corner. I've mostly found this true, because if you go too low on the front link you get taily mid corner, especially in sweepers as you say. It's a balancing act though because too high and you get big initial steer and then slide causing double steer.
i actually experienced the opposite...wierd huh?
more shims = lazy (maybe why it seems that it has less steering?) car but more grip in the middle on the front specially taily in the middle of the sweepers. i always end up with box setup though (4mm F, 3mm R).. but with 4.5mm shims in-front i spin out at the fast sweepers more often with my limited driving skills.. i like the balance already for our track with box setup.
[ Team Maxx Traxx ] http://iloveporrc.blogspot.com/ * http://timmedrano.com
tmomedrano is offline   Reply With Quote
Old 07-13-2012, 11:33 PM   #3492
mingnon's Avatar
cheers
check out Craig M's blog its toward the bottom of the page
Old 07-14-2012, 07:22 AM   #3493
syndr0me's Avatar
Trader Rating: 32 (100%+)
Those are some sweet stickers.
syndr0me is offline   Reply With Quote
Old 07-14-2012, 10:20 AM   #3494
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Skin for the new 417x is complete... ready to do battle.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-14-2012, 10:35 AM   #3495
I'm looking to buy a TR417X(upgrading from a TM E4FS). Any suggestions on parts support as I can get the kit from Tower Hobbies. My PO Box is located in Miami.
Archangel100 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
