Old 07-01-2012, 04:17 PM   #3391
Trader Rating: 30 (97%+)
this is probably answered before, so sorry in advance, but does the 417x motor mount fit perfectly into the 417, thanks
zaraz is offline   Reply With Quote
Old 07-01-2012, 04:17 PM   #3392
transplantlife's Avatar
Trader Rating: 43 (98%+)
yes
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 07-03-2012, 11:43 AM   #3393
Default 417X torque steer - mod racing
Besides softening the rear & stiffening the front, are there any usual, obvious setup checks to alleviate torque steer?
Any recommendations/ideas would be appreciated.
Thanks!!
mhavlena is offline   Reply With Quote
Old 07-03-2012, 11:56 AM   #3394
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Thanks!!
Torque steer with a belt car?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-03-2012, 12:22 PM   #3395
PutAwayWet's Avatar
Fits perfectly. You need both sides, obviously. And, I didn't bother with the bolt-on cross piece. Just the motor mount and the opposite side upright.
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 07-03-2012, 12:34 PM   #3396
Thanks!!
your chassis sounds tweaked, binding in the suspension or stuck bearing... any thing can cause that. But a belt car typically won't torque steer...
redbones is offline   Reply With Quote
Old 07-03-2012, 02:44 PM   #3397
I guess I didn't describe the problem properly.....the car oversteers at corner exit (wants to fishtail as if it was a torque steer problem).
The tweak is fine, the bearings are fine, and no binding..
Appreciate!
Old 07-03-2012, 05:07 PM   #3398
WildManDriving's Avatar
Trader Rating: 28 (100%+)
Appreciate!
How fresh is the rear gear diff?
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 07-03-2012, 05:28 PM   #3399
Not very fresh, built it over a year ago, used it in 17.5 blinky, still very free. Now using it in mod...used 1000Cst oil.
Are you saying that a tired gear diff would produce the oversteer condition?
Interesting...
Old 07-03-2012, 06:25 PM   #3400
Interesting...
take your shocks off and recheck everything. make sure shock shaft is not bent. The gear diff should not be too notchy or too free that the teeth skips. If all mechanical issues are ok, you can give a little more front droop to give it a little more rear traction. Also test on new tires. Old worn tires can lose grip suddenly sometimes.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 07-03-2012, 07:53 PM   #3401
GMartinez's Avatar
Trader Rating: 83 (100%+)
Tamiya 417X Loaded with Spares ARTR
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 07-04-2012, 12:47 AM   #3402
Interesting...
If you've tried everything else try a new gear diff, it has overcome the same problem for me.
Old 07-04-2012, 01:20 AM   #3403
mingnon's Avatar
just installed the double cvd's (tamiya) and WOW feels great, cant wait to give it a run next week.
How often should they be pulled out and stripped, cleaned etc? trying to maximise lifespan of them
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 07-04-2012, 01:35 AM   #3404
CraigM's Avatar
Trader Rating: 34 (100%+)
Interesting...
If it feels good it probably is, make sure nothing is binding and then work on your setup. More front droop, rear shocks stood up more and less rear camber are the first things I'd try. Split rear blocks also help if you aren't already running them.
Every meet
Don't take them apart, just spray them with contact cleaner and blow them with a compressor then regrease
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-04-2012, 03:36 AM   #3405
Robert_K's Avatar
Appreciate!
Running on a Low grip track? First check your tires.
Then try some softer oil in the geardiff. 800 or 650.
I had the same, got from 1000 to 650, then to 1500. 650 worked best for me 1500 made it worse.
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
