Old 06-29-2012, 03:10 AM   #3376
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by transplantlife View Post
craig how do you like the dcj in the rear
I like them, it feels like they let the rear suspension and diff work more freely, but I don't thing the difference is huge
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-29-2012, 03:24 AM   #3377
Originally Posted by Cpt.America View Post
Looking at this picture here, does anybody know where I can get this Tamiya logo in vector? or know what font this is?
Have almost every logo in Illustrator vector (.ai) because I plot my own decals. Give me your email and I'll mail it to you.
Z
_____________________________________________
Tamiya TRF 417, Fantom Racing
rcpoint is offline   Reply With Quote
Old 06-29-2012, 03:37 AM   #3378
Trader Rating: 19 (100%+)
Originally Posted by CraigM View Post
The car is much smoother to drive with DCJs in the front at least. It might not be much faster but it's definitely better
Do you mean the wheel chatter? I actually have never gotten a ton even on a pit with proberly cleaned and built cvd's, when i have it was very minimal. I still use the car for the tcs event, so maybe ill give the dcj's a shot and see how they feel on the track.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 06-29-2012, 04:30 AM   #3379
CraigM's Avatar
If you turn the CVD in your hand holding each end and gradually add some angle you'll notice you feel the chatter before it would ever be visible. I think from about 15 degrees onwards you can start to feel some resistance. You can get upwards of 22 degrees of steering lock on the tamiya, so it's there even if you can't see it. The DCJs eliminate it, I think they are especially important if running steel spool cups because the metal on metal combined with some chatter would not be a good combination
Old 06-29-2012, 04:48 AM   #3380
Yes, i learned this on my xray, only difference is xray cvd chatter is much more noticeable, you can put grease in them to smooth them because they are openly designed and supposed to be much lighter, so i just run dcj/ecs shafts in that. Thanks!
★Randy Banks★
Old 06-29-2012, 07:12 AM   #3381
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Z
Thanks Z, but my decal guy actually found it for me.. now sure where, but we got it! thanks.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-29-2012, 07:58 PM   #3382
mingnon's Avatar
Can anyone in Aust point me to a place to purchase the diff shims pn 19804494 (5x10x0.1)
cheers
matt b
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 06-30-2012, 12:49 AM   #3383
CraigM's Avatar
cheers
matt b
www.smallparts.com.au has every shim you could ever need for a fraction of the price of the tamiya parts
Old 06-30-2012, 01:40 AM   #3384
mingnon's Avatar
Thanks Craig
just had a look, what a great place to get bits and pieces
cheers
Old 06-30-2012, 02:09 AM   #3385
CraigM's Avatar
Thanks Craig
cheers
Thank JV, he put me onto them. They are really good my stuff came in 2 days.
Have you coned your diff shims?
Old 06-30-2012, 05:02 AM   #3386
mingnon's Avatar
I pulled the diff to see about a leak, the shims appear flat (placed on trued machine block) BUT there feels like there there is a little bit of slop in the outdrives/housing and what appears to be a groove/dull patch on the outer most shim (from the pin), so was going to replace them and see if it leaks anymore.
Have looked at your "build a diff" info as well and will need to order some 0.5 shims to have a go at it
Old 06-30-2012, 07:37 PM   #3387
Having trouble with putting swaybar links together I have the grey ball cups on top but can't put the black part on the rear studs does it go the other way around?
bosfan is offline   Reply With Quote
Old 06-30-2012, 08:48 PM   #3388
the rear uses the same 5mm ball cups, top and bottom part. both of them cut 5mm (i hate doing this lol) and make a hole in the top one. I made them 30mm long end to end. Only the front assembly is unique due to the 4mm ball built into the arm.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-30-2012, 11:40 PM   #3389
Trader Rating: 24 (100%+)
Have a TRF417, what is the fastest gear combo for a Team Powers 17.5 Plutonium with 12.5 rotor/ceramic bearings(shimmed rotor close to board), ORCA Vitra esc.
What is a good starting point for gearing? Spur??? Should I go big or go small on spur?
JoeyE is offline   Reply With Quote
Old 07-01-2012, 06:13 AM   #3390
Thank you
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
