Like Tree1Likes
Old 06-26-2012, 04:32 PM   #3346
OSherman's Avatar
Tire selection (or worn vs new tires) and Insert choice can alter droop as well.. Something to keep in mind during a practice session when searching for that rite Tire/Insert combination..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 06-26-2012, 04:49 PM   #3347
kyle133's Avatar
I always use setup wheels while setting up the car to avoid this problem
ACTION HOBBIES KINGSVILLE
MT POCKETS RACING
kyle133 is offline   Reply With Quote
Old 06-27-2012, 11:01 AM   #3348
Hi. Ive just put split blocks on the rear of the front suspension,What i was wondering is wether i need to put spacers under them. When it had the flipped from block on they had 5mm spacers under them. I have tried to search but nothing comes up on here.
scytherat is offline   Reply With Quote
Old 06-27-2012, 11:07 AM   #3349
artwork's Avatar
Trader Rating: 60 (100%+)
Well if you are trying to run the front blocks flat on the chassis then no, but if you are running higher front full center or anti dive then you will need to install shims. The split blocks do not require shims to get them flat with the front block.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 06-27-2012, 11:57 AM   #3350
Trader Rating: 22 (100%+)
2mm under the split blocks will give you the same height.
That is providing the flipped block is an italic writing original block.
Check out the Tryhard website willgive you more insight.
bjspinner is offline   Reply With Quote
Old 06-27-2012, 12:29 PM   #3351
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Looking at this picture here, does anybody know where I can get this Tamiya logo in vector? or know what font this is?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-27-2012, 01:37 PM   #3352
artwork's Avatar
Sorry, but split blocks do not need to be shimmed in order to run flat pins on the chassis and maintain level arms. Unless of course you are trying to raise the roll center or trying to run anti-squat or anti-dive, then shims are required.
I am assuming of course a 417 Chassis...
Old 06-27-2012, 01:39 PM   #3353
artwork's Avatar
I would contact Fred over at Tamiya USA and see if they will share the logo artwork...don't think so but it is worth a shot.
Old 06-27-2012, 01:47 PM   #3354
Super Moderator
do you happen to have his email address?
- RCSpecialties -
Old 06-27-2012, 01:47 PM   #3355
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Originally Posted by inpuressa View Post
are you running foams?
No i'm running rubber. Nobody runs foams anymore. It isnt a wheel or shock length issue. it is in the droop or downstops as they've described. the fault has to be with my tuning. but i cant get more than 4mm out of it right now. so some extra tweaking and i should be right
svndayNZ is offline   Reply With Quote
Old 06-27-2012, 01:50 PM   #3356
Which suspension block changes track width and which changes toe in or out
bosfan is offline   Reply With Quote
Old 06-27-2012, 02:01 PM   #3357
His question was how many shims under split blocks if he has 5mm under a flipped block.
The answer is 2mm.
Old 06-27-2012, 02:56 PM   #3358
Super Moderator
What do the separate suspension blocks do for the car that you don't get with the once piece? And these are only run in the front, yeah?
- RCSpecialties -
Old 06-27-2012, 03:07 PM   #3359
CraigM's Avatar
Trader Rating: 34 (100%+)
They let the chassis flex more giving more grip, sometimes at the expense of corner speed. Can be used both ends depending on what you are looking for
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-27-2012, 11:57 PM   #3360
Nuno Gancho's Avatar
do anyone have the table for reference regarding the HINGE BLOCKS, SPLIT FOR TRF 417, and they may be assembled in both side how do I know which side is correct.
thank you.
Nuno Gancho is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
