Old 06-17-2012, 04:00 AM   #3271
Thank you Craig!
EvoFreak is offline   Reply With Quote
Old 06-17-2012, 03:38 PM   #3272
mingnon's Avatar
Thanks Craig, cant wait till tomorrow night to give it a run
only change made is 450 shock oil and ride red springs all round (what i was using on 416)
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 06-18-2012, 06:15 AM   #3273
Guillermito's Avatar
Originally Posted by CraigM View Post
  1. set droop even both sides
  2. detach shocks
  3. flip car upside down
  4. hold one arm against the droop screw and the other side drop
  5. repeat holding the other arm against the droop screw
  6. if one arm drops more than the other then adjust the link until they are even - lengthen the side that drops more or shorten the side that drops less
Thank you. You have to do with the car wheels up? I always thought and I saw it with the chassis on the floor...
Mugen MBX7R - Nova Keep Off 4S - Futabas S9353HV & R614FS
Mugen MBX7R ECO - Combo Tekin Gen 2 - Futaba S9353HV & R614FS
Team Durango DEX410V3 - Tekin Redline G2 7.5T & RS Pro - Futabas BLS551 & R614FF
Tamiya TRF417X - Tekin Redline 6.5T & RSPro - Futaba BLS551 & R614FS
Tamiyas: Hotshot - Blackfoot - Avante 2011 - Futaba 4PKS-R FASST
Guillermito is offline   Reply With Quote
Old 06-18-2012, 03:04 PM   #3274
CraigM's Avatar
Trader Rating: 34 (100%+)
It's more accurate upside down because the droop screws remove any inconsistencies in travel. I take the wheels off btw.
Normally then I put the car on droop blocks and using the big side of the droop gauge I lever one arm up and keep sliding it further in on the arm until the other side lifts, then check the other side.
Your suspension needs to be 100% free or it won't work
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-19-2012, 10:25 AM   #3275
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
For 17.5 blinky at my local outdoor asphalt track.... iv think i need to be shooting for an FDR of 3.6. would this be a good gear combo to start with? Will it fit properly? recommendations? (its been a while since iv run on-road)
94/50 = 3.65 fdr
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-19-2012, 11:23 AM   #3276
artwork's Avatar
Trader Rating: 56 (100%+)
94/50 = 3.65 fdr
I am running 49/103 which is a 4.0 fdr with a revtech and it fits just fine on a medium sized outdoor track. Comes off about 150 with a fan...and is pretty fast.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-19-2012, 12:00 PM   #3277
Super Moderator
So you think closer to 4.0?
- RCSpecialties -
Old 06-19-2012, 12:02 PM   #3278
artwork's Avatar
That is where I would start...watch your temps and then add gear as you need to.
Old 06-19-2012, 12:03 PM   #3279
Super Moderator
Ok, thanks for the tip. Our outdoor track is going to be pretty large... the straight is going to be around 110 feet.
Another question, what fan are you running? I have been looking for a setup thats designed to just mount-and-go.. but can't find one. Suggestions?
- RCSpecialties -
Old 06-19-2012, 12:18 PM   #3280
artwork's Avatar
Get a side piece racing Seis Fan and just tape it down to the chassis...they work very well. Remember to plug it directly into the receiver as it cannot handle the higher voltages.
http://www.sidepieceracing.com/products/seis/
Old 06-19-2012, 06:31 PM   #3281
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
I've been looking at multiple 417x setup sheets online trying to understand a few pro-setups and had a few questions.
What is the advantage of running the front C block with the front rear B blocks?
On the 416 it was normal to run 2mm for the front wheelbase. I noticed many of the 417x setups are using 1mm-0.5mm. What is the advantage of this?
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 06-19-2012, 08:34 PM   #3282
CraigM's Avatar
C/B is 0.5 deg arm sweep, which increases castor as the car rolls giving you more mid corner steering
Shorter front wheelbase gives less entry steering but more exit steering. Most setups also use 3.5mm rear wheelbase, so the weight bias is shifted forward
Old 06-19-2012, 09:02 PM   #3283
tr1kstanc3's Avatar
That helps quite a bit. If I change the front wheelbase to be shorter, I should also correspondingly change the shims on the steering bellcranks as well to keep the geometry correct. My question is, what is the steering change from going to more or less shims in how it translates to driving on the track?
☆ Joe Tran ☆
Old 06-19-2012, 09:17 PM   #3284
Super Moderator
iv been slowly completing my 417x build, and now complete.... it seems the drivetrain is less than smooth... the front spool pully is almost square up against the rearward front suspension hanger...did I get something wrong?
- RCSpecialties -
Old 06-19-2012, 09:54 PM   #3285
CraigM's Avatar
Yes you should adjust the ackerman shims too. Less ackerman shims give more toe out as lock increases so less aggressive steering. You need to find a balance with ackerman, too many shims and your car will be twitchy, too few and it will push mid corner.
Sounds like you have may have the eccentric bearing carriers around the wrong way. Maybe take a photo so we have a better idea what you mean
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
