Old 06-15-2012, 08:17 AM   #3256
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Qatmix View Post
It's the 417. The Car has more flex than i have seen on a car (even the 416 is rigid compared to it). It took a while to get the set-up sorted but now my car is really planted and I get fastest lap pretty much every week. At our club the racers after getting a trf have bought the 417 over the X.
I also do not use additive. I run 13.5 on a tight circuit.
Interesting. I wonder if the stiffness is really that much different between the two.
I run light sauce to compensate for cold tires. The track is literally soaked in sauce. Its a track that has been open for 2 or so years and the layout or carpet has never been changed. I am sure you can imagine there are sections that are stained by rubber and additive.
Due to my driving style (a little twitchy, late braking and hard acceleration) I think i would benefit from the added flex. I will need to lean into those corners a little better...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 06-15-2012, 09:16 AM   #3257
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by artwork View Post
When you move wheelbase at both ends of the car at the same time (assuming an equal amount) the weight distribution changes on the car. This is usually done to affect the tipping point or center of weight shift.
This was the answer to the question that I incorrectly asked for. I guess I need to better understand the impact to handling if the tipping point and/or center of weight shifts front to rear or vice versa. Thanks!
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 06-15-2012, 10:33 AM   #3258
artwork's Avatar
Trader Rating: 56 (100%+)
A car with more front bias will be easier to drive and opposite for the rear.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-15-2012, 01:26 PM   #3259
Originally Posted by turd ferguson View Post
Hey guys. Just to let everyone know. Tamiya is releasing a new chassis and upperdeck for the TRF417x. They are meant for high bite. The part #s will be loaded to the TamiyaUSA site in a few weeks with parts scheduled to arrive in July. Here is the info I recieved:
Items:
42232 RC TRF417X Lower Deck 2.5mm Thick
42233 RC TRF417X Upper Deck 2.5mm Thick
Happy Racing
Anyone know if they will sell a kit with these pieces or is it just going to be an option part? Tamiyausa hasn't replied to the 3 emails I have sent.
Old 06-15-2012, 04:57 PM   #3260
transplantlife's Avatar
Trader Rating: 43 (98%+)
I think the 2.5 lower and upper deck will be a option if you run on carpet
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 06-16-2012, 06:56 AM   #3261
this definately looks like an avenue i am going to explore. Something I hope to know soon is if the 2.5 will be a part of a complete TRF417x kit. hopefully not a $100 option.
Old 06-16-2012, 07:01 AM   #3262
artwork's Avatar
The 2.5 chassis will never be part of the standard kit. It will always be an option part. The Tamiya 417x is a high performance car designed for paved surfaces. It is not a carpet car, however people have had good luck running it on carpet and higher bite surfaces. I would not be surprised if you see the tamiya boys run this new chassis at TITC next year, due to the amount of grip at that track.
Old 06-16-2012, 07:53 AM   #3263
hmm... true... I may be selling a brand new 2.25mm lower deck then...
Old 06-16-2012, 11:48 AM   #3264
you could always run the CSO 2.5MM chassis
Old 06-16-2012, 12:02 PM   #3265
Guillermito's Avatar
Hello, it wanted to know how as to regulate the stabilizer bars, so that both arms of the suspension raise equal.
Thanks. Best Regards.
Mugen MBX7R - Nova Keep Off 4S - Futabas S9353HV & R614FS
Mugen MBX7R ECO - Combo Tekin Gen 2 - Futaba S9353HV & R614FS
Team Durango DEX410V3 - Tekin Redline G2 7.5T & RS Pro - Futabas BLS551 & R614FF
Tamiya TRF417X - Tekin Redline 6.5T & RSPro - Futaba BLS551 & R614FS
Tamiyas: Hotshot - Blackfoot - Avante 2011 - Futaba 4PKS-R FASST
Guillermito is offline   Reply With Quote
Old 06-17-2012, 02:00 AM   #3266
Jochim_18's Avatar
Ok guys I run my 417x for the first time today all I can say is wow it was a night and day from my TC6... Car is very predictable and easy to drive on MOD... I pretty much use my own setup the way I like it and it was spot on car was dialed.. I did run a short wheelbase due to our track is smaller and technical on summer season due to we race at night and lighting is an issue...
I found with a shorter wheelbase car rotate and hug the corner like nothing else but it's a little twitchy on exit I'm going to make my wheelbase just a a little Longer and should perfect..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-17-2012, 02:07 AM   #3267
CraigM's Avatar
Trader Rating: 34 (100%+)
  1. set droop even both sides
  2. detach shocks
  3. flip car upside down
  4. hold one arm against the droop screw and the other side drop
  5. repeat holding the other arm against the droop screw
  6. if one arm drops more than the other then adjust the link until they are even - lengthen the side that drops more or shorten the side that drops less
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-17-2012, 02:40 AM   #3268
Hey guys, I have a question to the guys owning an TRF417 or TRF417x. Please can you measure the distance between the top level of the lower chassis plate and the upper level of the upper bulkhead.
The picture visualizes the distance I'm interested in.
Thanks in advance!
EvoFreak is offline   Reply With Quote
Old 06-17-2012, 02:49 AM   #3269
mingnon's Avatar
  2. detach shocks
Thanks Craig
remember you showing how to at MMM, but couldnt remember. Just got it sorted on the new 417X just finished building, and cant wait till Tues night to give it a run
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 06-17-2012, 03:10 AM   #3270
CraigM's Avatar
Thanks in advance!
29mm
Originally Posted by mingnon View Post
Thanks Craig
no problem, kit setup will be quite good for 21.5 but if you need any help otherwise let me know
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
