Old 06-14-2012, 05:30 AM   #3241
I race my 417 on carpet with foam tyres. It goes very well. I added a separate post to stiffen up the car even more and the corner speed was improved.
I also ponder changing the suspension to the old 414 / original 415 style. The original 415 was brilliant with foams on carpet. I might try it one day.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-14-2012, 06:35 AM   #3242
OI82lose's Avatar
Originally Posted by robk View Post
Thanks for the info. I would have never found that!
Ordered it and its on its way!
OI82lose is offline   Reply With Quote
Old 06-14-2012, 07:40 AM   #3243
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Very nice. Is it the 417 or 417x?
I will be running rubber tires, 17.5 boosted... I am just stuck between the trf417 and 417x. I read the 417x has more flex, and is BRED for asphalt(the same issue I have with the TA06, but I feel the TRF will be MUCH more managable) and the trf417 is stffer and it could yield better results. Being as how Marc Rheinhardt prettymuch created both, I have been reading every document I could find. Ironically he is placing 2nd regularly on carpet and is "not satisfied" with its performance on carpet. Mainly due to him being a asphalt man.
I am by no means within a lightyear of his talent, and i would not be racing against people of that caliber. besides the "flex" he is experiencing on a 4.5t motor will not be experienced as much on a 17.5t boosted...
opinions?
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 06-14-2012, 07:53 AM   #3244
artwork's Avatar
Trader Rating: 56 (100%+)
opinions?
Don't get it confused...Marc is a hired gun he does not design the cars. He is a driver and is very good at what he does. He does provide valuable input into the design team, but does not actually do any design work on the car.
If I were you I would buy a 417X without question. It is the newest car and with some work can really work well on any surface.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-14-2012, 07:55 AM   #3245
John.C's Avatar
Trader Rating: 36 (100%+)
opinions?
There is an alternative chassis (Hard type) available from Exotek to dial in the handling characteristics your seeking for carpet. It's certainly worth a look and hopefull will help with in your decision making process.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 06-14-2012, 08:14 AM   #3246
I was checking that out... However I dont know how I feel about removing cooling ports for a tad more stiffness.
Old 06-14-2012, 08:18 AM   #3247
*edit... That is an extra hard chassis... Harder than the 417 woudnt this be overkill from a 417x?
Old 06-14-2012, 04:20 PM   #3248
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Smile ??
Anyone tried an Xray gear diff in a 417x ?
FK05 lover is offline   Reply With Quote
Old 06-14-2012, 04:21 PM   #3249
It's the 417. The Car has more flex than i have seen on a car (even the 416 is rigid compared to it). It took a while to get the set-up sorted but now my car is really planted and I get fastest lap pretty much every week. At our club the racers after getting a trf have bought the 417 over the X.
I also do not use additive. I run 13.5 on a tight circuit.
Old 06-14-2012, 04:44 PM   #3250
Swaybars or no swaybars which do you prefer and why
bosfan is offline   Reply With Quote
Old 06-14-2012, 05:54 PM   #3251
???E-Racer's Avatar
If touring car racing gets more popular around here, I'll probably
get one of these cars. Until then I guess I'll run my TA05 ver2.
I bet one of these cars are a dream to drive in mod class.
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 06-14-2012, 06:26 PM   #3252
Trader Rating: 29 (97%+)
i have had a 417x and now own a ta05r with the exotek conversion, I am faster with the ta05 then the 417x, I just could not set up the x well, but the ta05 is just amazing, I also have a ta06 pro, and again the ta05 is faster, must be the exotek chassis, and I can run the low profile bodies from tamiya best of bot worlds
zaraz is offline   Reply With Quote
Old 06-15-2012, 07:10 AM   #3253
John.C's Avatar
Can someone explain the handling characteristics when adjusting the front and rear wheelbase independently? Iím aware of what overall wheelbase adjustments do for handling.
Old 06-15-2012, 07:21 AM   #3254
artwork's Avatar
In order to answer this question you have to understand what sway bars actually do and how they might affect the handling of your car. What works for one person does not work for all. Check out this video...it is for real cars but applies directly!
+ YouTube Video
Old 06-15-2012, 07:32 AM   #3255
artwork's Avatar
When you move wheelbase at both ends of the car at the same time (assuming an equal amount) the weight distribution changes on the car. This is usually done to affect the tipping point or center of weight shift.
When you change one end of the car you are actually adjusting the wheel base by making the overall car either shorter or longer. This also affects the weight bias in the car and usually has a dramatic change in the overall feel of the car. The shorter the wheelbase the easier is the car to rotate through a corner and the longer the wheel based the more stable the car is which usually has less overall steering.
It is best to try and achieve as close to 50/50 front and rear and then adjust to your liking. People usually use scales to measure the weight distribution front to rear.
I personally do not do this...I usually drive the car and fine tune as I need to. This is not a setting I usually mess with once I get my car set the way that I like it.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
