Old 06-12-2012, 05:20 PM   #3226
2-Bad's Avatar
Trader Rating: 24 (100%+)
Associated Green Slime
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 06-13-2012, 01:56 PM   #3227
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
I have a few questions regarding the TRF417x...
1) How does it perform on carpet?
2) Anyone use the front stiffener from the TRF417? Why/Why not?
3) Anyone use a shorty Lipo?How did you make it fit?
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 06-13-2012, 02:15 PM   #3228
RC MARKET's Avatar
ARENA released Spring Steel Front Direct Cups for TRF417 Series
RC MARKET is offline   Reply With Quote
Old 06-13-2012, 02:42 PM   #3229
Are those outdrives the same length as the tamiya original plastic outdrives
so you can use the 44mm CVD INSTEAD of the 46mmCVD.
As they are the same lenght as the Roche steel outdrives you may not sell
it to me.
eded1 is offline   Reply With Quote
Old 06-13-2012, 02:45 PM   #3230
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by OI82lose View Post
I use green slime from Team Associated to seal my shocks and gear diffs.
Is this the same product as "Slime" which is green and sold to repair tires and tubes?
Any information would be great.
Pretty sure it's this stuff...
http://shop.noleenj6.com/product.sc?...&categoryId=13
Old 06-13-2012, 02:51 PM   #3231
RC MARKET's Avatar
it to me.
Same Square Hard steel direct cup,
tomorrow check it !
Old 06-13-2012, 03:07 PM   #3232
Bugstomper's Avatar
What Scale are carpet track racers?
Nikko Mystery Car
Built a Tamiya Frog
Bugstomper is offline   Reply With Quote
Old 06-13-2012, 03:14 PM   #3233
artwork's Avatar
Trader Rating: 54 (100%+)
Some people are full scale...and other racers are smaller. Just according to whom you are asking about.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-13-2012, 03:16 PM   #3234
190mm bodied 1/10. Im running 17.5 boosted.
I was running a TA06 but the car has too much rear traction, so much that I cant remove all of it. 2.5* rear camber, 3.5* toe, stiffest springs i can find and it was still unmanagable. Its like the car was MADE for drifting or concrete tracks....
Old 06-13-2012, 03:32 PM   #3235
stitchy's Avatar
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-13-2012, 03:43 PM   #3236
I'm still on the fence on a 417, but I heard the X is better as a asphalt car. the original 417 is better as a carpet. Having owned the 415 and 416 variants, I wanted something different.My ta06 is really good on asphalt. It can keep up with other cf cars in 17.5 boosted. btw, I run 2* rear toe. But something about the 417 allures me.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-13-2012, 04:20 PM   #3237
Is this due to flex?
Old 06-13-2012, 04:59 PM   #3238
that's what I hear. something about the upper brace being too soft. The trf gurus here knows more about it.
TLR 22 3.0
Apex RC Proshop
Old 06-13-2012, 08:40 PM   #3239
artwork's Avatar
The major differences between the 417 and the 417x are around flex in the car. The 417x added a bunch more flex In both the front and the rear of the car. In the 417x rear they separated the motor mount from the one piece unit and removed the brace in the in the top deck in the front. They also added more cut outs to the chassis. All of this was done to allow the car to flex and twist as it transitions weight from side to side and front to rear. The 417x by design will be better outside, but both cars are very capable on both carpet and pavement. I am running a 417 with split blocks and a cut front top deck and it works very well, but it honestly could use a little more grip outside.
The 417x would be great inside on carpet as well and would be really good with one piece blocks...Tamiya makes a great car and can be made to work on all surfaces. However, getting the car setup correctly is a bit more work then cars with really big setup windows. The tamiya tends to have a smaller setup window, but honestly when it is right it is hard to beat.
Look for the next generation car to have even more flex and even more centralized weight distribution. The chassis that Marc, vicktor, and Jilles are running is pretty narrow and does not have many cutouts, but if that chassis ever gets released it will have the normal tamiya chassis cutouts...I assume. Based on my conversations with Marc and vicktor, they really want more flex in the car and are doing whatever they can to make the car work. I was stunned to see their setups at IIC last year but after talking with those guys I can see why they were moving in the direction they were. My car was really good in non-mod classes, but could see why they wanted more grip for mod.
One of the major changes you can make to get more steering in the car is battery placement. In the 416 line up he biggest change between the 416 and the 416we was the placement of the battery in the car. It was moved way forward, and this change made the 416we brilliant outside. When they moved the battery back in the 416x it really took the aggression out of the car. The reason I mention this is that Marc has been running his battery forward recently and it seems to be working well for him with the 417x.
Hope this helps...
Old 06-14-2012, 02:51 AM   #3240
CraigM's Avatar
Trader Rating: 34 (100%+)
While I agree that the stock X is possibly less good in high bite carpet than the regular 417 I have to disagree with a few things
The biggest change on the 416we was the one piece deck, which allowed for ore rear flex. Most of the team used the 416 chassis because the forward battery made for less weight transfer, which is why the X reverted to the original battery position.
The chassis Marc used at ETS has no cutouts by design, and if you look at how his car handles compared to Jilles and Viktor you will notice no double steer and more corner speed. This is something XRAY already found out, they tested all different cheese grater designs and ended up with a solid deck but varying the thickness of the carbon for low grip - I might be wrong but I suspect the 2mm chassis Viktor listed on his RROC setup sheet was also solid.
As for the x being better outdoors, the answer is "it depends". It flexes differently to the 417, the flex is more concentrated at the bulkheads. How it feels on the track depends on the track and tyres, on my track the 417 top deck had more bite and grip than the X top deck
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
