Like Tree1Likes
Old 06-11-2012, 10:57 AM   #3211
Johnny Wishbone's Avatar
Originally Posted by svndayNZ View Post
I was wondering if somebody could help me I just bought some 1XA split suspension blocks, since I've installed them there is a lot of bind in the right hand side, the left is free flowing and fine. I can't get the sway bar to lift the right hand side, I've isolated the bind to these blocks. Since they are the same angle as the kit I didn't think I'd be having these issues
Not my make of car, but we use a similar system, something that will also help the bind issue, is to put a small dab of the tamiya silver grease on the ball, so it doesn't bind in the cup of the brace, the lube will let it float a little better and center itself to the angle of the toe setting so it should free up the arms a little bit.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-11-2012, 11:25 AM   #3212
the grease does help. But aren't you supposed to ream the arms out so it pivots freely there instead of the sus ball?
redbones is offline   Reply With Quote
Old 06-11-2012, 11:39 AM   #3213
A reduction in shim thickness should be used to float the pin.The greased ball is to help in the final assembly as the steel ball can seize in the aluminum mount and if off slightly can put slightly more pressure on the arms shims and then the arms won't drop correctly. The free movement of the arms should be checked on final assembly without anything else mounted to them, they should free drop, the slightest bind can make the car act erratic, its very important, and thats for any car out there.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Last edited by Johnny Wishbone; 06-11-2012 at 02:04 PM. Reason: edited due to mis-information, my bad.
Old 06-11-2012, 12:06 PM   #3214
kentech's Avatar
Absolutely, reaming the arms is a must, once done they should float on the pin with no bind. The greased ball is to help in the final assembly as the steel ball can seize in the aluminum mount and if off slightly can put slightly more pressure on the arms shims and then the arms won't drop correctly. The frre movement of the arms should be checked on final assembly without anything else mounted to them, they should free drop, the slightest bind can make the car act erratic, its very important, and thats for any car out there.
This is totally wrong.
The TRF is designed so that the arm do not move around the pin, but the pin is solid in the arm and the only pivot points are the pin inside the suspension balls. This gives much less friction (especially under load) and more precision compared to if the whole arm pivoted around the pin, like on some other cars. This is one important feature which stands out on the leading TC's (same system used by Yokomo and HB for example).
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 06-11-2012, 01:28 PM   #3215
To remove arm binding replace a 0.5 shim with 0.3 from the 3mm shim set. Then it will have a little play.
This method is comparable to jilles's build method, of replacing a 1mm shim with a 0.75mm (the one from the c hub).
Do not ream the arms like kentech states, that is totally wrong and gives too much play (sideways).
BR, Steffan
Steffanchr is offline   Reply With Quote
Old 06-11-2012, 01:32 PM   #3216
I stand corrected. Edited mis-information.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-11-2012, 01:35 PM   #3217
artwork's Avatar
Trader Rating: 59 (100%+)
It takes some time to get the arms to rotate freely and also takes some patience. Jilles method is really good and works very well, but a little trial and error goes a long way. I constantly have to readjust the blocks to ensure that they are not bound up, but also to ensure there is not too much play. On the Tamiya...you never reem the arms out like Kentech posted.
Everything on the car should rotate or move freely and if it is not the car will be inconsistent. when I am unsure if I have a problem I take everything off the chassis and start my build over. This ensures that everything is straight and moving freely.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 06-12-2012, 04:13 AM   #3218
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Thanks for all the advice guys, I seem to have figured it out, some tuning tweaking and jilles on YouTube helped a lot. These separate blocks need more fine tuning than the one piece that's defnately something I've found.
First race outing in ten years coming up on Sunday. Things have changed since my P2K powered TC3 and when 2800mah nimhs were massive!
I'm only 26, making myself sound old.
Thanks again gents
svndayNZ is offline   Reply With Quote
Old 06-12-2012, 10:13 AM   #3219
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I have my 417x on order, and am excited to get back onto the tarmac... but, I am a little worried about parts. I thought I would have no problems, but I think being new to the brand is confusing me a bit... I was planning on doing all my parts shopping at speedtechrc, but a) 75% of their parts are out of stock for this car, of parts that show up under a search are actually for a different car (example, TB03 arms show up for the 417).
Could you guys point me towards the following? Im looking for spare:
front/rear suspension arms
c-hub carriers
steering blocks
rear hubs
spur gears
thanks for the info guys!
-Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-12-2012, 10:27 AM   #3220
John.C's Avatar
Trader Rating: 36 (100%+)
c-hub carriers
steering blocks
rear hubs
spur gears
-Cpt.
Build items
Tamiya TRF417x (TAM42205)
Tamiya Aluminum Horn (TAM54121)
Tamiya Air Duct (TAM3454480)
Tamiya Double Cardan Joint Shaft Kit (TAM32216)
Tamiya TA05 V2 Separate Suspension Mount 1A/1XA (TAM54172)
Tamiya TA05 V2 Separate Suspension Mount 1C/1XC (TAM54174)
Parma/PSE T2 Ultimate bumper
Spares/tuning items
Tamiya 5x9 Ball Hex Connector (TAM9804381)
Tamiya 4.5x4.7 Flanged Tube (TAM9804396)
Tamiya 4.5x3.5 Flanged Tube (TAM9804382)
Tamiya 3x0.7mm spacer (TAM9805645)
Tamiya TRF416 Derlin Direct Cup (TAM9804388)
Tamiya TRF416 Front Uprights (TAM51332)
Tamiya TRF416 Rear Uprights (TAM51333)
Tamiya TRF416 Front C-Hubs (TAM54031)
Tamiya Short Reversible Suspension Arm X2 (TAM53928)
Tamiya 46mm Titanium Coated Suspension Shaft (TAM53851)
Tamiya 416TB03 Alum Suspension Mount 1E (TAM54073)
Tamiya TRF Damper Large Diameter Retainer (TAM42192)
HPI Option Springs (Blue) X2 (HP6542)
HPI Option Springs (Silver) X2 (HP6543)
This spares/tuning list is a good starting point. Depending on your driving style, class, and track you may need additional spares/tuning items. If you don't go with the DCJs you'll want to pickup the 46mm steel shafts for the front.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 06-12-2012, 10:34 AM   #3221
John.C's Avatar
Default Spur gears
I'm currently using this spur gear.
I have these on order.
A third option from SpeedtechRC.
Old 06-12-2012, 10:39 AM   #3222
Super Moderator
Thanks for the fantastic reply... much appreciated!!
- RCSpecialties -
Old 06-12-2012, 10:50 AM   #3223
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Depending on the track you race at I would also look at the softer plastic C-hubs as they have more give to them.
TAM51293 Tamiya TA05-IFS F Parts (Hub Carrier, 4 degrees)
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 06-12-2012, 03:08 PM   #3224
OI82lose's Avatar
Default Green slime
I use green slime from Team Associated to seal my shocks and gear diffs.
Is this the same product as "Slime" which is green and sold to repair tires and tubes?
Any information would be great.
OI82lose is offline   Reply With Quote
Old 06-12-2012, 03:11 PM   #3225
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
No. The one for tired solidifies.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
