Like Tree1Likes
Old 06-04-2012, 01:45 AM   #3166
svndayNZ's Avatar
Trader Rating: 20 (100%+)
I also just ran kit setup, I tend to like to drive it first off as they suggest and then build setups off that
svndayNZ is offline   Reply With Quote
Old 06-04-2012, 03:06 AM   #3167
I run on a med/low too, I also have probs with my car is loose in the rear end on power.
I run a 17.5 boosted, I have tried Jilles and Marcs and I still have some problems with the rear end
Cp Grafix is offline   Reply With Quote
Old 06-04-2012, 04:02 AM   #3168
CraigM's Avatar
Trader Rating: 34 (100%+)
Try Kiyo's Wangan setup, it has a narrow rear end and upright shocks so lot of rear grip. I also found the original 417 top deck made my car more consistent on power
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-04-2012, 05:33 AM   #3169
Why is it that every setup you can find have on tamiya cars, have sliver combo, is this the best setup for a faily newcomer
Old 06-04-2012, 12:55 PM   #3170
artwork's Avatar
Trader Rating: 59 (100%+)
Ran the 417 this weekend on a pretty smooth parking lot...I ran the pretty standard setup and the car worked very well. I was running Silver HB springs up front and Blue in the rear...In this case the grip was not high enough to support that combo so going forward I am gonna try blue/blue. I think it is always best to have silver, blues, and pinks for outside. HB springs are king outside...period.
See the attached spring chart for spring comparisons and part numbers...
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 06-04-2012, 02:47 PM   #3171
CraigM's Avatar
Ride/MR33 red are great for low grip too
Old 06-04-2012, 05:42 PM   #3172
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Hey artwork, awesome spring chart!........ Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 06-04-2012, 10:34 PM   #3173
svndayNZ's Avatar
i just picked up a few ride springs, got some reds in there will try them out.
I also grabbed some TRF 1000 diff lube. because I run an R10 Pro with a Reedy 13.5 i followed Jilles esc setup and the things getting some serious wheel spin off the launch. bit like CP Graphix the rear end skips out relatively easily.
Old 06-04-2012, 11:09 PM   #3174
I aslo drive Solaris hard tires, so if any one have a setup for a low/med track i will be pleased.
I have tried alot of things, still can seem to beat the loose rear end.
Yesterday I tried some old Lrp ctx tires and the problem was gone, without setup chances.
Old 06-05-2012, 12:52 AM   #3175
That would imply that it's your tyres that are the issue. They are after all the most important tuning factor for cars.
Assuming you have to use them look at calming the rear end with a slightly narrower rear width and softer springs. Also you could look at calming the front end steering a little to take the bite out of the corner rotation.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-05-2012, 01:34 AM   #3176
Pro10noob's Avatar
The LRP tires fade off very quickly.
Use the Sorex 28R or 24R instead.
Even better grip and last longer with same grip level.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-05-2012, 01:45 AM   #3177
Sadly we have to use Solaris hard tires this year.
Old 06-05-2012, 02:08 AM   #3178
CraigM's Avatar
take some camber out, it will give you more forward bite.
Old 06-05-2012, 02:12 AM   #3179
Thanks all
I have something to go forward with
Old 06-05-2012, 07:05 AM   #3180
KWT-NITRO's Avatar
Hey guys,
Askin for a friend here, he just got the new gear diff for his 417 and the diff seems to leak!! Does anyone have a tip on how to put it together!! Should he use all shims or what?
Cheers
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
