Old 05-03-2012, 04:42 AM   #3061
Originally Posted by Blueman Austria View Post
Hy there!
Anybody tried the CSO lower decks wich are available for the 417?
They look like the 417x lower decks, but are nearly half the price.
So how is the quality of them compared to the Tamiya original ?
Greetings Rainer
I got one and it fuc#ing nasty, really bad finish with pin holes and dull! don't think I will ever put it near my car! Don't even think its Carbon Fibre!
Smokem chassis is way nicer than this!
Keith
kdempsey is offline   Reply With Quote
Old 05-03-2012, 05:00 AM   #3062
Gundevil-81's Avatar
her is mine. still gotta add some stuff to the body, but I am very happy with the car so far.
One Lug Racing
Remember a compeditive racer gives you 2 corners before peeling you, but a courtious racer takes the time to help pick up all the pieces to a Tamiya puzzle off the track so racing can resume
Gundevil-81 is offline   Reply With Quote
Old 05-03-2012, 07:24 AM   #3063
Guillermito's Avatar
What tires are better: soft, medium or hard? Muchmore Racing are good?
http://www3.towerhobbies.com/cgi-bin...?&I=LXUDL2&P=7
Thanks. Best Regards.
Mugen MBX7R - Nova Keep Off 4S - Futabas S9353HV & R614FS
Mugen MBX7R ECO - Combo Tekin Gen 2 - Futaba S9353HV & R614FS
Team Durango DEX410V3 - Tekin Redline G2 7.5T & RS Pro - Futabas BLS551 & R614FF
Tamiya TRF417X - Tekin Redline 6.5T & RSPro - Futaba BLS551 & R614FS
Tamiyas: Hotshot - Blackfoot - Avante 2011 - Futaba 4PKS-R FASST
Guillermito is offline   Reply With Quote
Old 05-03-2012, 10:15 AM   #3064
Blueman Austria's Avatar
Keith
Thanks for the Info. Thats what i have expected.....
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 05-03-2012, 03:20 PM   #3065
Hy there!
Greetings Rainer
I run with the CSO chasis plate and top plate and there is no
difference with the original only the price tag
Ed
eded1 is offline   Reply With Quote
Old 05-03-2012, 03:24 PM   #3066
I run these for parking lot racing. The 28's are the best all around. If it's cool outside use the 24's. I've used the 28's with 120 degree track temps and loved them.
M3CSLDreamin is offline   Reply With Quote
Old 05-06-2012, 05:53 PM   #3067
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Iv just picked up a 417x its still boxed and im going to build it up later this week, iv always run associateds but feel the 417x is the best car on the market. As this is my first Tamiya kit What does everybody suggest i do straight off the bat? I know the outdrives arent the best but what else.
I run 17.5 boosted in a big flowing outdoor track with a tight infield as well as indoor
svndayNZ is offline   Reply With Quote
Old 05-07-2012, 12:39 AM   #3068
CraigM's Avatar
Trader Rating: 34 (100%+)
Steel outdrives
HPI springs
Split suspension blocks
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-07-2012, 05:06 AM   #3069
artwork's Avatar
Trader Rating: 56 (100%+)
If you plan to run the spool in front I would suggest 46mm Steel Front CVAs or the new steel 44mm DCJs. I would switch all of my turnbuckles out for Titanium. I would have a set of aluminum C-Hubs in m pit box in case you run at a tougher track. I would also have split blocks as an option as well. The car is really good and I think you will see a big improvement over any AE car currently available.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 05-07-2012, 05:54 AM   #3070
svndayNZ's Avatar
Originally Posted by CraigM View Post
Steel outdrives
HPI springs
Thanks mate, iv checked out your blog. Good reading.
Old 05-07-2012, 06:09 AM   #3071
svndayNZ's Avatar
Thanks bud, ill check this all out. I ran a TC3 10 years ago and all i did was replace springs and actively tune my suspension and wheel geometry and the car was amazing. Had a bit of a heavy feel to it but getting back into it now 10 years later people seem to take these carbon based kits seriously in terms of numerous top plates and even more chassis plates. A lot of it suits driver style and track but your opinions on the kit are a help so thanks for taking the time to help me out.
Old 05-08-2012, 03:07 AM   #3072
LOSI123's Avatar
Trader Rating: 63 (100%+)
Is the Anti-Wear grease on the thrust bearing of the ball diff build in the manual a typo or real?
LOSI123 is offline   Reply With Quote
Old 05-08-2012, 04:11 AM   #3073
its real, just keeps it smooth and slows down wear.
I ran front and rear 417 balls diffs (I race my 417 on foams and carpet.. probably the only person on here that does) and they didnt need rebuilding after 9 months of weekly racing (only 13.5t though).
I currently run Gear diffs... I dont know if they really give me any advantage (Although the lack of slip helps away from the line) but I miss the ability to make small quick adjustments...
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-08-2012, 08:21 PM   #3074
LOSI123's Avatar
I would have thought that how thick it is would have caused the diff to loosen it self since the thrust bearing is meant to allow the bolt to turn during diff action so as not to undo or tighten the diff bolt and nut while driving.
Old 05-09-2012, 12:40 AM   #3075
CraigM's Avatar
Its best to dab some threadlock on the diff nut, but I've never had a ball diff loosen off. You should use a graphite grease of some sort on all thrust bearings.
I all seriousness though, chuck the ball diff in the bin and get a gear diff
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
