Like Tree1Likes
Old 12-07-2010, 12:15 PM   #286
Yes on the spur and not every spur gear will fit. It must have 4 holes in the right spot so the adapter can sandwich the spur in. There are no screws holding the spur in anymore. It all goes together and is held together by 1 e-clip. Very cool
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 12-07-2010, 10:30 PM   #287
Hi,
Can somebody confirm that the spur gear that comes with the TRF 417 is 64P?
R.
TheRock899 is offline   Reply With Quote
Old 12-07-2010, 10:36 PM   #288
Originally Posted by TheRock899 View Post
Hi,
R.
yes, it comes with two 64 pitch spur gears. 111 and 113 tooth.
JPRacing is offline   Reply With Quote
Old 12-08-2010, 03:16 AM   #289
Trader Rating: 22 (100%+)
What is the difference between the 416 spool cups and the 417 spool cups?
Anyone notice.
bjspinner is offline   Reply With Quote
Old 12-08-2010, 03:31 AM   #290
i just wish spur gears are accessible without removing the upper plate
cheapskate.brok is offline   Reply With Quote
Old 12-08-2010, 06:58 AM   #291
I like to loosen the screws on the top deck periodically throughout the day anyway to let the car relax so removing them takes an extra 2 mins.
How often do you change a spur gear at the track anyway? Unless you strip one of course but I haven't done that in a long time.
Joe
Old 12-08-2010, 07:00 AM   #292
Anyone notice.
They are the same. Its the same spool too. The bulkheads are narrower but the bearing holder is recessed in the bulkhead so the spool width is still the same.
Joe
Old 12-08-2010, 07:04 AM   #293
The other things I noticed is the motor is .5 to .75mm higher than the 416x and the top deck is 1mm higher too.
Joe
Old 12-08-2010, 07:13 AM   #294
Trader Rating: 45 (100%+)
Motor is higher probably cause of it rubbing the track on the 416x and higher top deck for more flex.
Wow, the more you point things out, I swear they must have looked at the TCX for some ideas.
Apex is offline   Reply With Quote
Old 12-08-2010, 08:00 AM   #295
jag88's Avatar
sometimes I think it's the other way round.
jag88 is offline   Reply With Quote
Old 12-08-2010, 08:09 AM   #296
True. The TCX did copy the 416x. But the 417 copied the TCX in some ways too. Plan to setup the 417 as close as I can to TCX and see if I can tell the difference.
Old 12-08-2010, 08:23 AM   #297
syndr0me's Avatar
Trader Rating: 32 (100%+)
We saw them experimenting with raising the motor as far back as Reedy, which I think predates the TCX, right?
Is the manual online anywhere?
What's the story with belts on the car, are they different than the 416/416X? It looks like there's a new front belt?
51439 TRF417 Low Fric Drive Belt Front
syndr0me is offline   Reply With Quote
Old 12-08-2010, 10:56 AM   #298
519mm front belt and 177mm rear belt or in other words 1 tooth longer front belt than X and the rear belt is the same. Can be seen from the pictures of ets race 2.
Mr_Orange is offline   Reply With Quote
Old 12-08-2010, 12:42 PM   #299
hey guys,
In general, what pinion gears do you guys usually carry around?
Old 12-08-2010, 12:46 PM   #300
kentech's Avatar
Blank setup sheet @ http://kentech.blogs.se
Will post more pictures as soon as I have time
Hi,
R.
The spurs are 0.4 pitch but compatible with 64 pitch.
The upper deck is higher to clear 25.1mm lipos.
kentech.wordpress.com
kentech is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
