Like Tree1Likes
Old 04-01-2012, 02:59 PM   #2971
CraigM's Avatar
Trader Rating: 34 (100%+)
Nt1 gears don't fit. The new s411 ones might
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-01-2012, 08:03 PM   #2972
RockyMania's Avatar
Trader Rating: 17 (100%+)
hi guys, i have a lil problem with the trf v2 gear diff. Even though i read alot sayin it wont leak, mine still does! I build it as per kiyo's recommendation at titc and filled with the stock 900 oil. Oil seems to leak a lil frm the side of the gear, not the oring. i have a feeling the gasket dont seems to seal the oil good enough. Any solutions?
RockyMania is offline   Reply With Quote
Old 04-01-2012, 08:43 PM   #2973
CraigM's Avatar
Green slime on the gasket stops most of the leaks
Old 04-02-2012, 02:00 PM   #2974
syndr0me's Avatar
Trader Rating: 32 (100%+)
Tamiya needs to put the 416WE back into production so the boys have a chance on carpet again.
syndr0me is offline   Reply With Quote
Old 04-02-2012, 04:06 PM   #2975
Hi guys, i need help...
I just broke my 417x lower deck ,
I know that there are a lot of chassis for 417:
Smokem
Exotek hard and soft
Cso CNC 2.5mm
Tamiya 417 and 417x
What do you suggest?
I was thinking to get the Cso 2,5 mm but i didn't find any comments on internet..
il cattivo is offline   Reply With Quote
Old 04-02-2012, 05:12 PM   #2976
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Default for sale
tamiya 417x
hotdognobun is offline   Reply With Quote
Old 04-03-2012, 07:24 AM   #2977
Trader Rating: 37 (100%+)
Kyosho released their metal gears. I'm not sure what the benefit of them is over the standard plastic, but seems to be out there as an option now for some brands.
http://www.redrc.net/2012/04/kyosho-...rential-gears/
Nexus is offline   Reply With Quote
Old 04-03-2012, 12:45 PM   #2978
I have had the same problem from the start, first with the spec-R diff and then I bought the V2 and though it gets faster lap times and fits better, it still leaks a lot. I'd say every 5 min run I do I lose 25% of my oil through the pulley which means it comes out past the gasket even though it's a new one. So far I have tried a few combos and I havent got enough success to answer you but I will try some kind of make-a-gasket paste either just on the paper gasket, or just stuff the big gap between the pulley itself and the sidewall so that it seals the 2 main plastic parts together as well as the gasket inside. I'm going to try and find a good product that can do that without being impossible to clean off after
This leak is really anoying; it messes up the lap times a lot. I wish they could make a V3.
EvetsFidrat is offline   Reply With Quote
Old 04-03-2012, 12:58 PM   #2979
ATLASCOPCO's Avatar
i have a standard 417 chassis, what chassis would you guys recommend for carpet racing and why
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 04-03-2012, 01:55 PM   #2980
smokem
Old 04-03-2012, 03:06 PM   #2981
CraigM's Avatar
kyosho gears don't fit either, the sun gear is too big in diameter.
The plastic gears are fine, if people are stripping them it's because the mesh is wrong or the shims are collapsing.
Old 04-03-2012, 07:29 PM   #2982
spring71's Avatar
Smile
R1Wurks New Tamiya Lightweight CVD Kits are available at TQ.
http://www.tqrcracing.com/shop/produ...t.asp?s_sort=3
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
[email protected]
spring71 is offline   Reply With Quote
Old 04-04-2012, 01:17 PM   #2983
Anyone know which outer Dia have damper piston on 417?
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 04-04-2012, 08:48 PM   #2984
WildManDriving's Avatar
Trader Rating: 29 (100%+)
WOW, amazing. I put the 417x (my first Tamiya) on the track to race last night and it was great. Started off kit setup including supplied oils but Blue springs all round. Changed to Yellow rear, removed the joining plate from under the motor mount and went Kyo 2000wt in the diff. Then the car was amazing, still broke lose a little on power at exit of the hairpins, but all-in-all was a pleasure to drive and showed in my results.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 04-04-2012, 09:07 PM   #2985
Trader Rating: 22 (100%+)
Originally Posted by hotdognobun View Post
How was the exotec flex chassis on asphault.
bjspinner is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
