Old 03-21-2012, 05:56 AM   #2911
banquer's Avatar
Hey guys!
Since I have my 417X, I'm having problems with three items.
- Leaks of silicone througt short differential joint.
- Short and long aluminium differential joint take plays in to quickly and broke to many blades.
- CVD (TA-51445) take plays to quickly also.
aluminium Differential joints are changed to a steel one and hope this resolv blade and joint problems, but what about CVD?
Last Andalusian (Spain) Regional, I must change two times to reduce play.
I'd bought new Tamiya double from CVD.
Are this stronger than simple CVD?
Do you know how to reduce leaks from differential version II? Why from shot differential joint?
King regards from Spain!
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 03-21-2012, 06:28 AM   #2912
columbia-mk2's Avatar
Originally Posted by banquer View Post
Hey guys!
Hi Banker,
I have never reduced to zero the leak of the differential, but mounting it whith grease like jilles groskamp says in his tutorials helps a lot.
I have replaced the original aluminium joints with steel made by Roche and solved the problem.
The original CVD axles are quite strong and reliable, never had a problem with them, do you keep them greassed and clean?
Cheers!
Awesomatix A700EX
Hobbywing Justock / LRP SXX V2 TC
Hobbywing Xerun 10.5 / LRP X12 5.0 Octa Wind
columbia-mk2 is offline   Reply With Quote
Old 03-21-2012, 08:49 AM   #2913
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Guillermito View Post
Thank you! Somewhere in the USA?
Best Regards.
I always go through speedtech and ampdraw. They might not have it in stock but if you give them a part number they can get it quick
hotdognobun is offline   Reply With Quote
Old 03-21-2012, 11:15 AM   #2914
banquer's Avatar
Originally Posted by columbia-mk2 View Post
Hi Banker,
Cheers!
Thanks Columbia.
I've done Mr. Groskamp tutorial, but steel leaking silicone. Do anybody knows if are optional o'rings better for tamiya diff gear?
Roche joints are in the way to my car ...
I'l try to keep my CVD cleans and greassed too!
Thanks a lot and king regards. I hope my next post will be about first position for our Regionals!
Tamiya 419
Tamiya TRF 101
Sanwa M12 - RX-471
Old 03-21-2012, 12:11 PM   #2915
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Thanks Columbia.
I had a similar problem until I loosened the screws holding the sides together and tightened them evenly, slowly, and without much torque. While mine isn't 100% leak-free, I'd say a solid 90%. Jilles makes a point to mention the tightening of those screws.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 03-21-2012, 12:13 PM   #2916
Guillermito's Avatar
hotdognobun and CraigM, Thank you very much for the information!!
This set of titanium bolts you can put the TRF417X?
http://www3.towerhobbies.com/cgi-bin...?&I=LXANNE&P=7
Because only offer it as an option for TRF417...
Thanks. Best Regards.
Mugen MBX7R - Nova Keep Off 4S - Futabas S9353HV & R614FS
Mugen MBX7R ECO - Combo Tekin Gen 2 - Futaba S9353HV & R614FS
Team Durango DEX410V3 - Tekin Redline G2 7.5T & RS Pro - Futabas BLS551 & R614FF
Tamiya TRF417X - Tekin Redline 6.5T & RSPro - Futaba BLS551 & R614FS
Tamiyas: Hotshot - Blackfoot - Avante 2011 - Futaba 4PKS-R FASST
Guillermito is offline   Reply With Quote
Old 03-21-2012, 12:35 PM   #2917
yes that is the one i used. I got mine off ebay for $44.00 and got it in less than 2 weeks. I stop ordering from Towers cause they take forever to ship and price is higher than most sites.
Old 03-21-2012, 03:06 PM   #2918
CraigM's Avatar
Trader Rating: 34 (100%+)
Kyosho make a red oring for the v1rrr that will stop the diff leaking, I don't have a part # sorry
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-21-2012, 06:34 PM   #2919
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Some pointers I've come up with when building the gear diffs
- only sand the back of the bevel gears enough to remove the plastic burrs...keep them as thick as possible
- ditch the shims the diff came with... get a pack of 5mm shims from tamiya (.1, .2, .3mm thickness)
- .4mm goes behind the crown gear
- shim on the outside until you get little to no side to side play from the outdrives (i have .1 on the short outdrive and .2 on the long one).
basically the idea is to shim internally for mesh, then shim on the outside to reduce/remove play.
so far no leaks on my units since i've done this.
Hope this helps.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-22-2012, 12:45 AM   #2920
CraigM's Avatar
Are you running mod? I've gone back to kit shims because the little ones kept collapsing into the oring
Old 03-22-2012, 12:48 AM   #2921
VooDooPH's Avatar
yes. 7.5T with boost. so far so good... the shims seem to hold up. i think its the slop that kills the gears and causes the leaks...
hated the kit shims because the cone after a few laps and made the diff run stiffer in the middle of the heat.
for insurance i have 2 spare built diffs in the bag aside from the one installed in the car.
Old 03-22-2012, 03:28 AM   #2922
CraigM's Avatar
I had coning at TITC with the outside shimmed, then I had the small shims collapse with the outside shimmed back home in lower grip, so I started building them how kiyo said and it's been ok since. I think they will cone again but so far so good, running 4.5t btw.
My friend modded the gears to take a 10mm pin and that's solved the problem completely so I'll do that if they cone again
Old 03-22-2012, 04:04 AM   #2923
Still a 2mm pin? because I tried a 3x10mm and the gear broke
Cp Grafix is offline   Reply With Quote
Old 03-22-2012, 03:22 PM   #2924
CraigM's Avatar
Yep same diameter just longer, so under load it presses on the case and not the oring
Old 03-22-2012, 04:53 PM   #2925
1.5mm pin x10mm long
justin v is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
