Old 03-18-2012, 12:51 PM   #2896
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Originally Posted by heretic View Post
thanks for the super-quick answer !
The 84195 are an absolute no-go, they are super tight on the rod, and the material is way too hard. But they are nice to have if you want to use them under a screw to mount, for instance, a top plate in a flexible way.
As for the others... could you comment on the respective merits of each item ? I see none of them are the transperent kind found in the box. Are the x rings good ?
skip the clear orings they leak! any of the blue are great they help prevent leaks even under exsteam heat cause they do not expand. i use x ring 70 #42215 which requires mineral base oil. 50durometer # 42214 is meant for silicon oil which are popular cause the oil is cheaper and work just as good. i normallly use green slime to prevent any leaks but not with the x rings! 8 packs and still no signs of leaks
hotdognobun is offline   Reply With Quote
Old 03-19-2012, 02:35 PM   #2897
8 packs?
How often do you change o-rings?
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 03-19-2012, 03:08 PM   #2898
Default 417 spur gear
Hi does anyone know if I can get a 48p spur gear from another brand that will fit the 417?
EvetsFidrat is offline   Reply With Quote
Old 03-19-2012, 03:28 PM   #2899
hanulec's Avatar
Trader Rating: 23 (100%+)
Xenon white gears appear to work. speedtechrc sells them.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-19-2012, 06:44 PM   #2900
Potoczak's Avatar
Trader Rating: 109 (100%+)
Hey guys I am looking for a medium grip outdoor asphalt setup for a 417. Can someone point me in the right direction. ThankS
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-19-2012, 08:58 PM   #2901
Originally Posted by ezh_m5 View Post
8 packs?
i use the others for my other shocks or on outside shaft so retainer does not hit shock bottom
Old 03-19-2012, 10:04 PM   #2902
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Lot of good asphalt setups here for indoors and outdoors.
http://www.petitrc.com/reglages/tami...miyaTRF417.htm
I recommend Dave Jun's setup for tamiya America track. Only thing I would really do is play with the steering spacer measurement(aka Ackerman), maybe start with the stock setting and reduce the shim thickness if needed.
Racing4Evo is offline   Reply With Quote
Old 03-19-2012, 10:11 PM   #2903
I use serpent 48p spur - stock spacer works fine - just need to watch the shimming since its thicker
Tamiya - TRF 417V5 - Smokem - Hobbywing V3 - Reedy Sonic 4.5 Mach2
Sanwa M12
iwkyb is offline   Reply With Quote
Old 03-20-2012, 11:03 AM   #2904
Which c-joints are good for use?
Original tamiya are very bad quality
Tamyia TRF 417
Old 03-20-2012, 11:48 AM   #2905
Guillermito's Avatar
Hello, I know that I have to use pinion for the Tekin RS-Pro sensored Brushless ESC / Motor Combo (6.5T) and Tamiya TRF-417X.
Thanks! Best Regards.
Mugen MBX7R - Nova Keep Off 4S - Futabas S9353HV & R614FS
Mugen MBX7R ECO - Combo Tekin Gen 2 - Futaba S9353HV & R614FS
Team Durango DEX410V3 - Tekin Redline G2 7.5T & RS Pro - Futabas BLS551 & R614FF
Tamiya TRF417X - Tekin Redline 6.5T & RSPro - Futaba BLS551 & R614FS
Tamiyas: Hotshot - Blackfoot - Avante 2011 - Futaba 4PKS-R FASST
Guillermito is offline   Reply With Quote
Old 03-20-2012, 07:00 PM   #2906
RockyMania's Avatar
Trader Rating: 17 (100%+)
Anyone tested the CSO lowerdeck for 417x? feedback pls compared to the ori lowerdeck
RockyMania is offline   Reply With Quote
Old 03-20-2012, 08:17 PM   #2907
Which you buy the parts for TRF-417X?? They have nothing in Towerhobbies...
Thanks. Best Regards.
Old 03-20-2012, 08:37 PM   #2908
rcmarket.hk
banzaihobby.com
rcmodel.hk
http://www.tamiya-asia.com/shop/tami...-302_2167.html
Old 03-21-2012, 02:46 AM   #2909
rcmarket.hk
banzaihobby.com
rcmodel.hk
Thank you! Somewhere in the USA?
Best Regards.
Old 03-21-2012, 03:07 AM   #2910
CraigM's Avatar
Trader Rating: 34 (100%+)
Best Regards.
Www.speedtechrc.com
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
