Like Tree1Likes
Old 03-15-2012, 02:11 PM   #2881
Originally Posted by Pro10noob View Post
Why not use the top flange mount on the bottum with the flange from the inside of the C-hub?
This will create less room so you need a thinner spacer(the blue one)
regards Roy
Just install without any washers
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 03-15-2012, 05:51 PM   #2882
Trader Rating: 37 (100%+)
Originally Posted by Yeti AS3 View Post
So, I sold my TC6 (first TC) and I am looking into a Tamiya.
Here's the question...I can get a 416x with Exotek chassis, gear diffs, ball diffs, and parts for about 250 less than the 417x. Is it worth the extra coin to get the 417x? It will only be run on asphalt.
If it were me I'd save the coin and buy the 416x. Then down the line if you decide you like Tamiyas buy a used 417x. Both cars will use the same arms, hubs, and other parts. Then you can have 2 TCs setup for 2 classes that share spares.
I know people with both and it's not like the 417 will make you any faster. Heck I see some 415s tearing it up still.
Nexus is offline   Reply With Quote
Old 03-16-2012, 01:47 AM   #2883
RockyMania's Avatar
Trader Rating: 17 (100%+)
i know 417x lower deck is 2.5mm. what is the thickness of 417 lower deck? 2.25mm or 2.5mm?
RockyMania is offline   Reply With Quote
Old 03-16-2012, 01:53 AM   #2884
RockyMania's Avatar
anyone knows is there any changes in the bulkhead geometry of 417 to 417x? i heard 417x bulkhead is narrower than 417, is tat true?
Old 03-16-2012, 02:02 AM   #2885
kentech's Avatar
They're both (417 & 417X) 2.25mm
And both lower decks fit both cars; i.e. bulkhead holes are exctly the same.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 03-16-2012, 05:28 PM   #2886
racer x 1's Avatar
Trader Rating: 27 (100%+)
Default 417
is the regular 417 still a good car on med traction carpet and possibly outdoor asphalt?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 03-16-2012, 06:52 PM   #2887
maxepower's Avatar
Exclamation 417 vs 417X
In the right hands....................................Ha Ha Ha!
I have both 417X and the 417 and I like the original 417 with 13.5 and the 417X with 17.5.
To me it seems very similar but I need more steering with the 17.5 so I run the 417X and with the 13.5 I don't need hardly as much steering so I run the original 417. I hope this makes sense. To me the "X" has more steering!
So, on carpet it's very close to how both feel. This is dependent on set-up driving style etc,etc.
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 03-16-2012, 09:33 PM   #2888
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Just my 2$
+1
Regular 417 seems easier to drive on carpet.
Racing4Evo is offline   Reply With Quote
Old 03-17-2012, 09:45 AM   #2889
The original is great on carpet with foams.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 03-17-2012, 01:36 PM   #2890
Marek Gadomski's Avatar
hey
do you know patent to use metal gears in trf gear diff (need for TRF 511 )
bot gear look same as in 417 one
i need help
thanks for replies
____________________________________________________
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
[email protected]
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 03-17-2012, 09:36 PM   #2891
Where can i buy 417x chassis and motor mount?
M3CSLDreamin is offline   Reply With Quote
Old 03-17-2012, 11:47 PM   #2892
hotdognobun's Avatar
Trader Rating: 31 (100%+)
rcmarket.hk
hotdognobun is offline   Reply With Quote
Old 03-18-2012, 10:32 AM   #2893
heretic's Avatar
Hi everyone
I'm looking for O-rings to rebuild my Tamiya shocks. I see the part # is 53574 but it includes the teflon parts which I don't need. ( At least i think I don't need them ... just want to chage the bottom o-ring as regular maintenance).
Does tamiya have a part number for O-rings alone ?
Does another brand sell orings that fit ? I mean REALLY fit, at least as good as the original O-ring, not something that binds or leaks...
Thanks guys !
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 03-18-2012, 11:21 AM   #2894
Originally Posted by heretic View Post
Hi everyone
Thanks guys !
http://www.tamiyausa.com/product/ite...oduct-id=84195
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGG96
http://www.tamiyausa.com/product/ite...oduct-id=42137
http://rcmarket.com.hk/product_info....ducts_id=12657
http://rcmarket.com.hk/product_info....ducts_id=12658
Old 03-18-2012, 11:47 AM   #2895
heretic's Avatar
thanks for the super-quick answer !
The 84195 are an absolute no-go, they are super tight on the rod, and the material is way too hard. But they are nice to have if you want to use them under a screw to mount, for instance, a top plate in a flexible way.
As for the others... could you comment on the respective merits of each item ? I see none of them are the transperent kind found in the box. Are the x rings good ?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
