Old 12-06-2010, 02:42 PM   #271
kentech's Avatar
Diff pictures below. The new diff is impressive. Only retains the bearings, pulley and diff balls. Outdrives, diff rings, diff screw, thrust assembly all new. Screw and thrust same as on TRF201.
More @ http://kentech.blogs.se and more tomorrow..
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-06-2010, 03:18 PM   #272
syndr0me's Avatar
Trader Rating: 32 (100%+)
Will the new diff work in the 416?
syndr0me is offline   Reply With Quote
Old 12-06-2010, 03:29 PM   #273
Great photos Kenneth! Keep them coming.
Don't forget to let us know of the driving impressions especially when compared with the 416X.
Thanks.
Josť Cordeiro is offline   Reply With Quote
Old 12-06-2010, 03:30 PM   #274
I tried it just for you and it fits perfectly
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 12-06-2010, 04:24 PM   #275
syndr0me's Avatar
Sweeeet, thanks! How about that pretty new steering rack? Much as I'd love a 417, this just isn't the right time for me to change platforms. Doesn't mean I wouldn't mind putting a few of the updates on the ol' X, though.
Old 12-06-2010, 05:04 PM   #276
The new posts are shorter but it would fit if you changed everything but the arms so you would need the rack and the shorter posts. The holes are in the same location. Cool thing is you need less shimming for acerman now since the piece is bigger. No more need for the stronger screws no bending going on here anymore.
Joe
Old 12-06-2010, 05:35 PM   #277
syndr0me's Avatar
Cool, thanks for checking that. You see anything else new that might be backward compatible?
Old 12-06-2010, 06:05 PM   #278
Trader Rating: 22 (100%+)
Are the camber link ballstud positions on the bulkheads in the sams spot as the 416.
I noticed kentech you are in the middle hole!
bjspinner is offline   Reply With Quote
Old 12-06-2010, 11:04 PM   #279
jonest's Avatar
Finally Kiyo-san did something right.
Can't wait to get mine.
Thanks ken,
jonest is offline   Reply With Quote
Old 12-06-2010, 11:44 PM   #280
crabboy's Avatar
Trader Rating: 57 (98%+)
What's the advantage of the new loose ball thrust, the one piece one looks better to use.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 12-07-2010, 10:08 AM   #281
Pics of the hot rod
I don't think anything else is compatable other than suspension parts
Joe
Old 12-07-2010, 10:10 AM   #282
Originally Posted by Manson View Post
Where did you buy it ?
Dynamic Hobbies in Canada. They have 2 more
Joe
Old 12-07-2010, 10:21 AM   #283
The middle hole on this car is the inner hole on the 416. The bulkheads on this car are 2mm narrower than the 416.
Joe
Old 12-07-2010, 11:55 AM   #284
With the rear motor screw accessed via the large outer holes in the spur gear, it looks like if you want to change to 64dp you'll have to make sure that the screw can still be reached through the spur?
Toon is offline   Reply With Quote
Old 12-07-2010, 12:01 PM   #285
Trader Rating: 45 (100%+)
Alot of the updates on the 417 look similar to what was done on the TCX. Can't wait until they are released in the US in the next couple of weeks.
Apex is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
