Old 03-01-2012, 09:34 PM   #2821
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Electro-MAX RC View Post
How much will the Tamiya DCJ cost?
42216  44mm Double Cardan Joint Shaft (2pcs.)
RC Champ show them as 3,675 Yen (~AUD 42), but not in stock yet.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 03-02-2012, 09:37 PM   #2822
CraigM's Avatar
Trader Rating: 34 (100%+)
Here is the setup Kiyo gave me at TITC, the TRF team were all using slight variations on this setup. The track was medium size (50m straight), fast and super high grip - people were traction rolling on asphalt! Its not a big nitro track like it appears in videos, the infield is tighter than it looks.
We started out using 0.5mm shims in the wheels but this pushed a little in the tighter corners so I went to 1mm the same as Jilles when the grip came up and for me that was better.
http://db.tt/nlCvYTLH
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-04-2012, 05:52 PM   #2823
Default Car makes clicking noises when braking?
Running Tekin RS pro, 17.5 SS Pro non-boosted....
After 6 months of running this car, it now seems to make "clicking" noises when braking....?
No signs of anything strange on the chassis and or belts...they don't seem to be slipping...could this be a motor issue?
Any ideas would be greatly appreciated.
Thanks!!
mhavlena is offline   Reply With Quote
Old 03-04-2012, 07:32 PM   #2824
CraigM's Avatar
Thanks!!
Check the drive pin isn't coming out of one of the unis, this isn't so much a problem with the clip system but if you have the older style unis they can work their way out a hit the upright or knuckles
Old 03-05-2012, 02:39 AM   #2825
Thanks!!
I don't know what kind of "clicking" noises you are experiencing, but check your spur-gear. If you don't tighten the topdeck, the spur-gear can move when braking, which will produce a clicking noise, and ruin your spurgear.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 03-05-2012, 04:14 AM   #2826
barts71m's Avatar
Thanks!!
Had a clip come out of a friends car in the 417 axle and it made that same sound as it was eating into the front upright..check your clips are in place in your axle.
barts71m is offline   Reply With Quote
Old 03-05-2012, 08:46 AM   #2827
Trader Rating: 52 (98%+)
Default what is the difference btwn spec R gear diff and the stock one
Can someone tell me what is the difference between the spec R gear diff (black one) and the stock one?
Thanks in advance.
Lots of RC Stuff
straightaway is offline   Reply With Quote
Old 03-05-2012, 09:13 AM   #2828
Thanks in advance.
The Tamiya gear-diff unit II is the best in my opinion. Minimal leaking and buttery smooth. My Spec-R diffs leaked and felt terrible. They can be made equally good, but the Tamiya is nice out of the box.
Niklas Hansen
Old 03-05-2012, 10:14 AM   #2829
maxepower's Avatar
Cool
Thanks!!
Are you using a gear diff in the front? From top speed to when you come to a complete stop does the back end of the car want to come around? If all these questions are answered by yes, it's the gears are stripped in the front. That would explain the clicking sound!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 03-05-2012, 03:13 PM   #2830
Just my 2$
Currently, the back end does not want to come around, but you never know, perhaps this is the start.
I'm currently using spec-R gear diff with diff lock in the front, but I also have an unbuilt Tamiya Gear Diff Unit II.
Is it imperative that I use Jilles recommendations for building the Unit II (video) even if I plan on using diff lock? What would happen if I don't cut down the gears, will they break more easily?
Appreciate any advise...
Old 03-05-2012, 03:20 PM   #2831
Starteur's Avatar
Do it the right way Michael!!!!!!!!!!!!!!
or sell it to me LOL !
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 03-05-2012, 03:30 PM   #2832
The wise man has spoken!! Now I must stop being lazy!!...
Old 03-05-2012, 04:40 PM   #2833
Just my 2$
Before I start stripping gear diff screws, what tool size is required for the Gear Diff Unit II screws? They look smaller than 1.5mm...in fact, I measured 0.05"
Can anyone confirm the best tool size?
Thanks.
Old 03-05-2012, 06:24 PM   #2834
maxepower's Avatar
Questions?? SCREW SIZE?
Thanks.
The thought Tamiya diff should be 1.5 and so is the Spec-R
I'm going to double check !
Old 03-05-2012, 07:18 PM   #2835
CraigM's Avatar
1.5mm, best of you have a worn driver tho as the fit is tight!
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
