Old 02-27-2012, 06:22 PM   #2806
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Originally Posted by TheZoof View Post
Nice... I just finished my 417x build and added those parts.
Pretty pumped to try it out.
Hey Mike, you gonna run Joe's setup for the 417x at the Niagara race,also i grinded down the end of the axle on my spec r c.v. swing shafts, they stick out a tad too much
bozzplayer is offline   Reply With Quote
Old 02-27-2012, 07:08 PM   #2807
Yeah... I see that. I haven't ground mine down... I might do that if I can remember.
I am going to use a little bit of the guys Vegas setup and a little bit of Joe's. I will change the car based on how it feels. If it isn't free enough then I will go towards that guys setup. If it isn't planted enough I will go closer to joe's.
I am going to try Joe's setup this weekend.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 02-27-2012, 07:24 PM   #2808
CraigM's Avatar
Trader Rating: 34 (100%+)
Default Gear diff
I know there are a few ways to build the v2 gear diff but I thought I would share what Kiyo told me. Unlike Jilles Kiyo does not sand the big gears, instead he just trims them and makes sure they are properly deburred. On the inside he uses 5 x 0.1mm shims, 2 on the short outdrive and 3 on the large side. I built my diff like this and it felt a bit geary at first but once run in it was fine. Do not use the big kit shims because they will cone and make the mesh too tight, instead use the ones that are included to shim the axles. They don't cover the whole oring but that doesn't matter.
I also spoke to Jilles about his method, he said in addition to his YouTube video he's now using 2 x 0.1mm shims on the outside of each of the outdrives. This removes any slop and the chance that the gear diff mesh could tighten up when under load from the suspension.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-28-2012, 09:05 PM   #2809
Have anyone compared the TRF 417x chassis with aftermarket ones like smokem FX? If so, what are your comments?
Tamiya - TRF 417V5 - Smokem - Hobbywing V3 - Reedy Sonic 4.5 Mach2
Sanwa M12
iwkyb is offline   Reply With Quote
Old 03-01-2012, 05:51 AM   #2810
Csaari77's Avatar
Is there an ETA for the new Tamiya drive shafts?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 03-01-2012, 06:04 AM   #2811
TryHard's Avatar
Very soon, as I managed to buy a set at TITC
Old 03-01-2012, 06:09 AM   #2812
barts71m's Avatar
U coming back to the blue side Ed?
Im looking forward to running mine next week, original 417 fitted with Smokem chassis, X shock towers and top deck and have chopped my motor mount up so it looks like the new 417X version. Although after talking to one of the guys on his return from TITC, Tamiya have a bunch of new parts already for the 417X.
barts71m is offline   Reply With Quote
Old 03-01-2012, 06:46 AM   #2813
Which design did they end up using for the DCJ? Arrowmax or Spec R?
At least they will have seperate parts for rebuilding incase you bend something.
Sanwa M12
Old 03-01-2012, 07:56 AM   #2814
TryHard's Avatar
I've still got my 417, but I'm really happy with the A700 at the moment, and the 7 is on sabatical. I'll decide what to do with it later... but I still couldn't resist picking up the DCJ's whilst I had the opportunity!
They are like the Spec R, but Steel and at 44mm length. See the pic!
Old 03-01-2012, 10:46 AM   #2815
Look nice!
I am happy with my spec-r ones for now.
Michael Zufelt
Old 03-01-2012, 01:23 PM   #2816
Trader Rating: 31 (100%+)
Does anyone know where I can source the 417X motor mount and top deck? Tamiya America is taking forever to stock them. Thanks!
ittjv is offline   Reply With Quote
Old 03-01-2012, 06:00 PM   #2817
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Who makes those DCJ's ?
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 03-01-2012, 06:39 PM   #2818
A700?
How much will the Tamiya DCJ cost?
Electro-MAX RC is offline   Reply With Quote
Old 03-01-2012, 07:45 PM   #2819
CraigM's Avatar
Those are the soon to be released tamiya ones.
Old 03-01-2012, 07:48 PM   #2820
TryHard's Avatar
They are the soon to be released Tamiya ones... the shop at TITC had a couple of sets already, so I picked up a set
Originally Posted by Electro-MAX RC View Post
A700?
A700 = Awesomatix
I paid 2500Baht = $75, not cheap, but then I've always found the RC parts there more expensive...
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
