Old 02-26-2012, 11:39 AM   #2791
Csaari77's Avatar
Trader Rating: 34 (100%+)
The preload collars don't need to be the same from side to side. Adjust them until the ride height is the same for both sides.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 02-26-2012, 11:57 AM   #2792
Pro10noob's Avatar
Pehaps there is a suspension arm the wrong way around?
This will set the shock more to the inside of the car and hence raise that side.
This if they both are mounted the same way.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-26-2012, 04:05 PM   #2793
Somebody can tell me if metallic central pulley from TRF417 can be installed in TRF416X? . I am having a lot of problems with rear belts and Gear diff ver 2 installed in my 416X.
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 02-26-2012, 04:33 PM   #2794
Trader Rating: 22 (100%+)
Yes it fits but you need to use flanged bearings as the 416X bulkheads are further apart.
bjspinner is offline   Reply With Quote
Old 02-26-2012, 04:43 PM   #2795
Can you tell me which kind of flanged bearings? Reference or size/type?
Thanks.
Old 02-26-2012, 05:12 PM   #2796
Thanks.
4x8mm flanged bearings. Flanges to the inside as the 416 series has wider bulkhead spacing.
Any brand will do quality versus price is your choice.
Old 02-26-2012, 07:09 PM   #2797
Trader Rating: 31 (100%+)
The 417 pulley is larger than the 416 pulley. Not sure if it's a direct drop in or if you have to use 417 belts or if it fits at all.
ittjv is offline   Reply With Quote
Old 02-26-2012, 07:44 PM   #2798
Rear belt same as 416X front belt is longer than the 416/416X.
Half correct
Old 02-26-2012, 11:17 PM   #2799
Thanks a lot, I have to try this. Two broken belts with Tamiya 417 ver 2 inside my 416X in two races...
And yes rear belts are the same for 416X and 417 (54207)
Old 02-26-2012, 11:24 PM   #2800
Pro10noob's Avatar
@Rosokam....Is the belt tension ok??
I run the TRF416X lipo also with the VII spec gear diff but havent stripped or broken a rear belt in a whole season.
The front belt should be a bit tighter then the rear so the car want's to pull a bit.
Check if the gear adaptor is right in the middle as if not the adaptor can damage the belt.
Same with the gear diff.
regards Roy
l===/o\===l
Old 02-27-2012, 01:27 AM   #2801
3 racing's pulleys fit with small mod, if u want 1.947 gear radio
Cp Grafix is offline   Reply With Quote
Old 02-27-2012, 05:29 AM   #2802
The forn belt should be a bit tighter then the rear so the car want's to pull a bit.
regards Roy
Maybe thatīs the reason. Rear belt was well tensioned but I didnīt check the front belt and rear was tighter than front.
Old 02-27-2012, 06:16 AM   #2803
CraigM's Avatar
Default I'm back!
Hey gang, I just spent the week in Thailand pitting next to the TRF team. I was having heaps of trouble getting my Kyosho to work in the high grip, so the night before qualifying I bought a 417X and built it for the next day
I got heaps of tips from those guys which I'll share when I have more time, and I have the setup they were using which i will post as well - nothing drastic really, just minor tweaks to the base setup.
Their cars were pretty standard too, just running the new double jointed front unis and metal spool outdrives
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-27-2012, 07:18 AM   #2804
Nice... I just finished my 417x build and added those parts.
Pretty pumped to try it out.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 02-27-2012, 12:18 PM   #2805
banquer's Avatar
Please, inform us wich references are.
Cheers!
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
