Old 02-23-2012, 07:50 AM   #2776
Originally Posted by spring71 View Post
New 417 Spool set have arrived from Spec-R.
http://www.tqrcracing.com/shop/produ...t.asp?s_sort=3
417 parts store : http://www.tqrcracing.com/shop/parts...arts_p_id=1447
FYI, Thanks.
Metal against metal will more likely have a lot more chatter than metal to plastic. I prefer tamiya's style much better.
Juan Aveytia is offline   Reply With Quote
Old 02-23-2012, 08:01 AM   #2777
Hey all!
I will be running a 417x on a high grip carpet track in a few weeks. I haven't made any modifications to the car except for the Spec-r front drive shafts.
Is there a good setup around to try?
I have one for a medium grip carpet track that I will use if need be however would be nice to not be so far out on start of practice day.
Btw -... I will run the car in 17.5 boosted or Mod... haven't decided which.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 02-23-2012, 08:46 AM   #2778
gregsbox's Avatar
VOTE HERE
[YOKOMO] [XRAY] [SANWA] [TEKIN] [ALIGN] [JR]
www.thisisrc.com
www.thisisbluerain.com
gregsbox is offline   Reply With Quote
Old 02-23-2012, 02:00 PM   #2779
Johnny Wishbone's Avatar
Originally Posted by TheZoof View Post
Hey all!
You should contact SkaterX on the Canadian forum, either NASCAR or CARCAR forum, he had a very good setup on a high traction carpet track. I believe he drives for Borgfelt/Tamiya Canada, but I don't know if they have a setup forum.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 02-23-2012, 02:18 PM   #2780
artwork's Avatar
Trader Rating: 54 (100%+)
Hey all!
This is the setup I ran at IIC and it is a good high/med grip setup with both 17.5 boosted and non-boosted.
http://www.petitrc.com/reglages/tami...mo_IIC2011.pdf
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is online now   Reply With Quote
Old 02-23-2012, 05:48 PM   #2781
Originally Posted by JoeGlover View Post
I am loving the new 417x. We are on medium grip carpet and the car is really nice to drive. Chassis flex was a non issue. This car has and always will excel outdoors on the asphalt. I have an exotek chassis coming so I will try that out next race day and report back.
I ran my 417 back to back to compare and same laptimes and same consistancy. I wouldn't upgrade if you have a 417 but for everyone else who doesn't have a blue car well they are just going slower
So Jo, how's the exotek chassis coming along? Have you try it? Because I'm planning to purchase the soft flex to replace my old 417 chassis..but not sure which manufacture should I purchase...
If any of you can recomend which one better please let me know, I'll be using for out door aspall med grip track...
k4mp4q is offline   Reply With Quote
Old 02-23-2012, 06:42 PM   #2782
rtypec's Avatar
Originally Posted by Nexus View Post
rtypec,
How did you like running the R8 LMS? Just wondering how it compares to the NSXs that so many people run in GT1.
It's okay I suppose. That was the only body I've run with my 417X. Last weekend, I used an NSX, which felt better. YMYV
rtypec is offline   Reply With Quote
Old 02-24-2012, 07:31 AM   #2783
Art - Thanks. I saw your setup posted there already. I am running a 417x so that is why I hesitated. I will give it a shot and change the link spacers accordingly. Thanks!
Joe tried his exotek chassis and loved it. Don't think he has a direct comparison yet as he ran on a different track than normal however was running well I am sure.
Michael Zufelt
Old 02-24-2012, 07:44 AM   #2784
Can't seem to find those forums?
Michael Zufelt
Old 02-24-2012, 01:01 PM   #2785
Try this and then pm him.
KARZ Calgary POST #12509
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 02-25-2012, 11:56 AM   #2786
rcguy48's Avatar
What is a good ride height for asphalt tracks.
Tamiya TRF417|Savox|Airtronics|Reedy|Tekin
Team Durango DEX410|Savox|Airtronics|Reedy|Castle Mamba Pro
Tc5r
Als Hobby Shop Elmhurst Phone: 1-630-832-4908
Team Durango
rcguy48 is offline   Reply With Quote
Old 02-25-2012, 12:30 PM   #2787
Yup like Zoof said I am liking the exotek stiff chassis for carpet. Car seems a bit more free and easier to find good balance in the setup.
I will be running on our track again next weekend so I will have a better feel for it with some open practice.
I am going to get the flex chassis for asphalt as well.
RCguy if your track has no bumps run it as low as you can without scraping too much, that will just slow you down. That being said I like to be around 4.8-5mm all the time
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 02-25-2012, 12:55 PM   #2788
rcguy48's Avatar
Ok thanks.
Tc5r
Team Durango
Old 02-26-2012, 10:09 AM   #2789
Default Ride height off
Hello all I just got a used TRF 417 and the rideheight in the rear right (battery side) is 1 mm higher than the rear left with the same shock length and preload.
The battery is pushed out as far as possible and the car is balanced left/right.
I double checked the shocks and they are all the same.
I set the chassis flat and tightened the topdeck on a flat surface many times with no change. THe chassis seems flat but the rideheight is still off.
Is it like this for everyone? Or do I need to change the hubs or the bearings or something? What's the usual cause?
Thx.
EvetsFidrat is offline   Reply With Quote
Old 02-26-2012, 10:21 AM   #2790
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Thx.
send us a picture? did you check for bent pins, loosen the 3x10 screw in suspension arm and then check height?
hotdognobun is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
