Old 02-09-2012, 09:27 AM   #2746
SS LS1's Avatar
Trader Rating: 23 (100%+)
Originally Posted by eComet View Post
They are the older C-hubs so the geometry is different. You can install them but you'll probably not going to get much feedback on them.
After all the testing, 4 degrees C-hub seems to be the best overall for the current TC setup. Alternatively, you can also so shim under the suspension blocks to alter caster but you'll also modify the dive characteristic of the car.
Ok, thank you for the reply, I may look into the Xray pieces as mentioned previously. Thanks!
SS LS1 is offline   Reply With Quote
Old 02-09-2012, 10:14 AM   #2747
Blueman Austria's Avatar
Hy there!
I wanted to ask how you all run your Lipos. In the forward, or backward position?
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 02-09-2012, 01:09 PM   #2748
Marek Gadomski's Avatar
Originally Posted by Blueman Austria View Post
Hy there!
Greetings Rainer
Backward
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
marcgadomski@gmail.com
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 02-09-2012, 01:11 PM   #2749
Originally Posted by chrisk View Post
i have put the chassis on my 417 and it is great on outdoors med grip ashpalt, i only run there and not on carpet so can not comment, but agree with Tryhard, Vince does a good job and the quality is great
My friend use this one at ETS and says it's better (Michal Orlowski P4>ITA)
Old 02-09-2012, 01:57 PM   #2750
Csaari77's Avatar
Trader Rating: 34 (100%+)
I'm in the process of getting a spare parts order around for a new 417X. I plan on running the car in a 17.5 blinky class on a low/medium traction carpet track. The only part I'm not sure of is what spur gear I should get. I have seen setups with spurs ranging from 88-105.
What are most people running? Is there a particular brand I should get, I know access to the motor screws is an issue? Has anyone tried the RW spurs from Speedtech?
Thanks for the input!
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 02-09-2012, 03:52 PM   #2751
@Art_Mighty's Avatar
Originally Posted by hotdognobun View Post
shorter gives you less chassis roll. tamiya and protoform are used alot in tcs but nothing beat tamiya bodies. i like the shorter arm i feel quicker turn in! i use exotek super soft chassis but not legal
Regarding the shorter arms, that makes sense. So any body is legal for TCS, interesting...
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 02-09-2012, 07:52 PM   #2752
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Car Body
All car bodies must be painted and must be cut along the trim lines. You are not allowed to create extra vent holes for the purpose of ventilation or performance enhancement. Leaving extra material below the trim lines of the body is prohibited.
All car bodies must use the wings that are supplied in the kit. Mixing and matching ABS plastic wings, between different body styles, is not allowed. Part number 53470 (Lightweight Wing) and 53604 (Racing Wing Set) or any future OPTIONAL wing set is legal for any sedan/sports car body as long as the body is pre-marked with dimples for the option wing mount. See specific class rules for restrictions.
In the spirit of keeping TCS Racing scale in appearance to the public, the Subaru Legacy B4 body (items 53727, 49374 & 53824) is not legal for all GT classes.
hotdognobun is offline   Reply With Quote
Old 02-09-2012, 08:17 PM   #2753
Csaari77's Avatar
The biggest rule of TCS is:
All Tamiya vehicles must use Tamiya parts only. No parts from other manufactures unless specified within this document.
Only Tamiya bodies are legal for TCS races.
Old 02-09-2012, 08:30 PM   #2754
Trader Rating: 22 (100%+)
The 417X has no issues with the spur gear other than it must have 4 holes opposite for the pulleys.
No need for holes in the gear to access the motor screws.
bjspinner is offline   Reply With Quote
Old 02-10-2012, 01:33 AM   #2755
the rw's from speedtechrc work fine on the 417. they have the 4 holes squared as needed by the 417's center pulley/spur gear holder
platypus_s13 is offline   Reply With Quote
Old 02-10-2012, 06:15 AM   #2756
Csaari77's Avatar
Great to hear. Can anyone chime in on spur size for blinky 17.5? Is there a preference, or are people just using anything to get down to 4.0-3.5?
Old 02-10-2012, 06:20 AM   #2757
FunkyDunky's Avatar
there is a very simple modification you can do to the centre pulleys so they accept almost any type of spur gear. This has been done by lots of people in the UK now and none have had any issues
http://www.stockracer.co.uk/tamiya-4...ification.html
FunkyDunky is offline   Reply With Quote
Old 02-10-2012, 06:59 AM   #2758
Default Spur gear size.
I am running a RW 94 tooth, I run on medium sized tracks if that helps.
shaggy1 is offline   Reply With Quote
Old 02-10-2012, 07:25 AM   #2759
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I use RW 94 tooth spur for 17.5 blinky.
Racing4Evo is offline   Reply With Quote
Old 02-10-2012, 06:14 PM   #2760
maxepower's Avatar
Cool drill two holes!
Almost any spur gear will work just add two more holes with a hand drill. There will be at least two holes that will line up and that should be all you need so the spur spins true to the pulley. You can drill the holes way over sized just so it will fit and the two holes that do line up will keep everything true!
Just m 2$
P.S. there is one issue, if the spur is too thick then this can be a problem, I just left off the spacer for the thicker spurs. So, any thin spur gear will work.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
