Like Tree1Likes
Old 01-25-2012, 10:13 AM   #2656
Trader Rating: 17 (100%+)
Originally Posted by Juan Aveytia View Post
The real problem your going to have mounting a gear different in the 414 is pilot size. The closest size I can find is a 34T from spec r. It'll fit, the belts will be too tight. I've used a gear different from top racing for 2 years now. Not the best, but in my car I've never been off pace. Won the roar last year with it and nearly won reedy with it. Just mount your standard 414 one-way gear on it. I have never rebuilt it. I filled it with black AE grease and drove it. It will brake in nicely after about 2 to 3 packs. If you find a way to mount a better brand please pm me. Thanks
When are you coming back out to play?
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 01-25-2012, 10:21 AM   #2657
Blueman Austria's Avatar
Hy all!
Picked up a lightly used "original" 417. Build it up with all the tips and Tricks from jilles (cut Top Deck Front and rear, Spec R Double CVDs, Tamiya Gear diff rear, split Blocks).
The only thing i havent done is to cut the motor mount. Is this a "must have" modd, or how would you all rate the improvement?
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 01-25-2012, 03:21 PM   #2658
Trader Rating: 31 (100%+)
If you can't seem to get the rear of the car from sliding around or spinning out, then you should consider cutting the mount. I put the 417X motor mount on my car and it made a pretty big difference. The car feels very stable with it.
- Jose
Originally Posted by Blueman Austria View Post
Hy all!
Greetings Rainer
ittjv is offline   Reply With Quote
Old 01-25-2012, 06:07 PM   #2659
Art
Maybe Saturday
Juan Aveytia is offline   Reply With Quote
Old 01-26-2012, 01:27 AM   #2660
Guys, is there any different between the v1 and v2 Spec R DCJ other than the clips? and any thoughts on yeah racing spring steel one?
Wilson Picaldy is offline   Reply With Quote
Old 01-26-2012, 03:11 AM   #2661
defcone's Avatar
Trader Rating: 15 (100%+)
The material for the shafts themselves I believe are the same, the pin material must've changed as I have not snapped one in about 4 months. The entire cvd has been redesigned, as you do not need grub screws the coupler is now a more solid piece as it does not have the hole where you would screw the grub screw.
defcone is offline   Reply With Quote
Old 01-26-2012, 05:00 AM   #2662
Thanks, is there any noticable different in handling after using DCJ?
Old 01-26-2012, 05:49 AM   #2663
defcone's Avatar
I only felt a difference in high speed sweepers, the car would feel more smooth going through them.
Old 01-26-2012, 06:02 AM   #2664
hotdognobun's Avatar
Smile
anyone try the CSO chassis?
hotdognobun is offline   Reply With Quote
Old 01-26-2012, 07:22 AM   #2665
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
How is the durability of the new v2 SpecR dcj?
tr1kstanc3 is offline   Reply With Quote
Old 01-26-2012, 11:25 AM   #2666
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Tried the V1 last weekend, one bad hit and it has gone, too weak.
I ordered the V2 to see if it is more durable, my mistake when buying, didn't saw there was a V2 type...
On the side of performance the transmission was smooth no vibration at all and the car was better on the track.
My only concern is that the thing only lasted a weekend...back to the old ones already.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 01-27-2012, 05:05 PM   #2667
I'm driving my 417x yesterday for the first time, Unfortunately quake the swing shafts, [i must use tamiya in the tamiya euro cup], i use the sanwa m11x, and from 105% D-Rate (Ive read some peaple use 150 D/R) a loud noise and vibration, what am I doing wrong? (I have other swing shafts test, the 46 mm steel or the 44 mm steel) the same problem.
thanks for fast help, greeting daniel
DPRacing is offline   Reply With Quote
Old 01-28-2012, 07:52 AM   #2668
Marek Gadomski's Avatar
U need DCJ shafts
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
marcgadomski@gmail.com
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 01-28-2012, 12:35 PM   #2669
Originally Posted by Obsidian View Post
greetings all,
I want to get a gear diff for my 414. Can anyone tell me what the measurement is between the rear bulkhead diff bearings of the 417, or the measurement of the tamiya gear diff II is from side to side where the the bulkhead bearings are?
Cheers
Hi,
I tried a spec-r 416/417 gear diff and it wont fit as the pulley is too large so it will need holes cut in the chassis.
Juan mentioned the cheapest and best route. Otherwise if you wanted to change to the 416/7 diff you would need
  • New belts
  • Front 37t pulley
  • Rear 37t Gear diff
  • Shims to remove any play in the rear bulkhead
  • A dremel to cut holes at the front and rear under the pulleys. Or a set of 2mm shims to fit under all of the front and rear bulkheads..
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-28-2012, 02:17 PM   #2670
meccanico's Avatar
Don't worry about it. it's normal.
Vibrations and noise will reduce after some lipos till when the plastic direct cups are a little wear.
meccanico is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
