Old 01-23-2012, 07:21 PM   #2641
Trader Rating: 69 (100%+)
Originally Posted by mhavlena View Post
When new, I found that the suspension arms didn't rotate freely within their suspension mounts. Obviously, I could swivel them up and down, but they would not go back down on their own (gravity) when lifted.
The instructions state to shave the suspension arms should they not move freely, thus, that's exactly what I did. After a couple of weekends of racing, I now find that there is way too much front to back play.
Should I have left the suspension arms alone and installed them without shaving?
Has anyone else experienced this?
Do the suspension arms bind at first? and do they free themselves up after time?
Suspension arms that have too much play can't be too good for handling.
Appreciate!!
After some stress and crashes, the suspension mounts will move. You can loosen the suspension mount screws, re-adjust the tolerance for the suspension arm movement, and then re-tighten them again.
eComet is offline   Reply With Quote
Old 01-23-2012, 07:21 PM   #2642
Originally Posted by hotdognobun View Post
i went with Boca ceramic orange seal. It cost almost half of cars price! i feal no advantage over stock! we ll see after a long run how it last? stick with stock and if anyone is looking i have the 417x teflon sealed bearings for sale
Those ones are maintenance free, correct?
Since they will still get dirty on the outside, how do you clean them without removing the internal grease?
mhavlena is offline   Reply With Quote
Old 01-23-2012, 07:24 PM   #2643
I see....but are they tight at first for you as well?
Old 01-23-2012, 07:28 PM   #2644
Without sanding down the arms, yes, they are tight in the beginning. There's two way you can do this, use 0.5mm less shim without sanding down the arms. Or sand it until the movement is small and free.
You can also use the tiny 0.1-0.3 shim to shim out unwanted plays (also for accidentally removing too much material on the arms). But try the method I mentioned earlier first, then add more shims if the play is still too much.
Old 01-23-2012, 07:35 PM   #2645
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Yes, they were tight. I actually swapped the 1mm shim for a 0.7mm shim, for a total of 1.2mm instead of 1.5mm. That helped. I had a race meet over the weekend and haven't checked it over yet, but I will check the play when I get a chance.
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is online now   Reply With Quote
Old 01-23-2012, 07:45 PM   #2646
chrisk's Avatar
Trader Rating: 32 (100%+)
i use the 0.7 shim as well. Also i ran a 3mm reamer through the arm, just one or two swipes, just takes any casting burs of the ends of the arm to enable to to be free on the shaft.
nice a free
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 01-23-2012, 09:35 PM   #2647
hotdognobun's Avatar
Trader Rating: 31 (100%+)
i have yet to maintence/clean my bearings after 12 pack because my lap time has not dropped so they are still running strong! the seals are getting visually dirty but i just compress air it. to be honest i have never maintenance or replace any ceramic bearing from boca to acer! my yokomo r12 after 30+packs still spins freely forever!
hotdognobun is offline   Reply With Quote
Old 01-24-2012, 12:05 AM   #2648
CraigM's Avatar
Trader Rating: 34 (100%+)
Also how Jilles does it, .75mm shim instead of 1mm. Takeoff (and others) make them
If you have excess play you have probably bent a suspension mount
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-24-2012, 08:29 AM   #2649
meccanico's Avatar
Originally Posted by ATLASCOPCO View Post
Hi Guys,
I have just got a 417 and i am looking for a link to some setups for carpet with rubber tyres
Many thanks
i43.tinypic.com/eijz0i.jpg
this was my set up for ETS rd 2 in Italy first in I Main
meccanico is offline   Reply With Quote
Old 01-24-2012, 03:34 PM   #2650
greetings all,
I want to get a gear diff for my 414. Can anyone tell me what the measurement is between the rear bulkhead diff bearings of the 417, or the measurement of the tamiya gear diff II is from side to side where the the bulkhead bearings are?
Cheers
Obsidian is offline   Reply With Quote
Old 01-24-2012, 04:05 PM   #2651
ATLASCOPCO's Avatar
Thank you
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 01-24-2012, 05:41 PM   #2652
chrisk's Avatar
greetings all,
Cheers
go onto the Tamiya 415 forum and the last 5 pages has the instructions for fitting a gear diff into the 415, what spacers required and what belts to use for the different pulley sizes.
not sure of the difference between the 414 and 415 bulkheads so it may not be exactly correct, but a lot more info on that thread that will help you out
smaracing.org
Old 01-25-2012, 01:01 AM   #2653
I have just fitted a gear diff to a 415, I will have a go to see if it fits on the 414 this weekend.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-25-2012, 07:17 AM   #2654
Originally Posted by Obsidian View Post
greetings all,
Cheers
The real problem your going to have mounting a gear different in the 414 is pulley size.The closest size I can find is a 34T from spec r. It'll fit, the belts will be too tight. I've used a gear diff from top racing for 2 years now. Not the best, but in my car I've never been off pace. Won the roar nats last year with it and nearly won reedy with it. Just mount your standard 414 one-way gear on it. I have never rebuilt it. I filled it with black AE grease and drove it. It will brake in nicely after about 2 to 3 packs. If you find a way to mount a better brand please pm me. Thanks
Juan Aveytia is offline   Reply With Quote
Old 01-25-2012, 10:46 AM   #2655
Thanks everyone for your input. Very appreciated. Juan, see you at Norcal!
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
