Like Tree1Likes
Old 01-16-2012, 03:51 AM   #2596
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by hotdognobun View Post
i meant you i used them in my onroad shocks even though they are meant for offroad! i believe you can use the Spec R x ring with tamiya gear diff? i have some on order and will let you know when i install it
i believe the two are not interchangeable...
SpecR geardiff o-ring is smaller in diameter (inner and outer).
CraigW,
I believe you're looking for 51470 Maintenance Parts Set for Gear Diff2 Units. It has the o-rings, 0.01mm shims and pins in the same bag.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-16-2012, 12:34 PM   #2597
Guys, what spurы and pinions are you using?
I use a stock Tamiya Spurs and pinions Robinson " aluminum pro".
But I think there are better and more durable ???
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 01-16-2012, 02:19 PM   #2598
hotdognobun's Avatar
Trader Rating: 31 (100%+)
what motor turn are you running?
hotdognobun is offline   Reply With Quote
Old 01-17-2012, 02:05 AM   #2599
Usually it is 10.5T on the carpet, I also have 5.5T for fast long tracks and for asphalt tracks.
Tamyia TRF 417
Old 01-19-2012, 01:29 AM   #2600
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Oops! That's what shake down runs are for
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 01-19-2012, 04:20 AM   #2601
chrisk's Avatar
Trader Rating: 32 (100%+)
Phil
They tend to make a nice groove in the rim like that, leave it for the weekend it might give me chance to catch you
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 01-19-2012, 08:23 AM   #2602
Trader Rating: 30 (97%+)
hi, I have a brand new steering carbon bridge from the 417 and two brand new spur gear spacers, and a brand new xenon 112 gear white spur gear, all for the 417x, I sold my 417x and have this items come in yesterday, so if anyone wants them 29 shipped for all of them all brand new. just the spacers were 20 for two, send me a pm thanks
zaraz is online now   Reply With Quote
Old 01-19-2012, 03:52 PM   #2603
Default rear toe-in different from left to right?
Guys:
using 1XA and 1E blocks in the rear, but my setup system shows me that I am 3 deg toed-in on the left, but 3.5 deg toed-in on the right...
Has anyone experienced this before? How can I rectify? Perhaps I need to purchase new mounts?
Any experience would be appreciated!!
mhavlena is offline   Reply With Quote
Old 01-19-2012, 04:40 PM   #2604
chrisk's Avatar
bent pins that go through the arm? inner or outer
bent upright?
bent blocks?
a few things may alter this
smaracing.org
Old 01-19-2012, 04:57 PM   #2605
TryHard's Avatar
Originally Posted by mhavlena View Post
Guys:
try loosening the screws under the blocks and re-tightening them. Also, check all the blocks for any kind of bend (this can happen after hits), and if bent, replace. If it's still the same, it's most likely just some slack in the setup system or bearings... put it down and run it.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-19-2012, 09:59 PM   #2606
who carrys white 12 or 14 gauge wires other than tekin?
Old 01-19-2012, 10:14 PM   #2607
maxepower's Avatar
Exclamation Novak has them
Novak elec.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-19-2012, 10:32 PM   #2608
PDR
PDR's Avatar
Don't worry, Chris. The new chassis is only a couple of tenths quicker
Old 01-20-2012, 06:02 AM   #2609
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
Hi guys,
Going to be getting back into touring after a few years off. I have narrowed down my choices to a couple of cars - namely the X-Ray (used to run them all the time), Associated 6.1 and the 417.
What are the main "issues" with the 417 - what wears out really quickly? I want to go something different - and the Tamiya is where I think I would like to go. I drive for the Durango team in off road - so I dont mind something a little different. I am looking at the 417x.
I appreciate your time in answering
Cheers
Darryn
Thanks to my sponsors for their support:
Team SCHUMACHER RACING - UK || B-FAST PERFORMANCE R/C USA || MAX RACING Products || BUGLE BOY RACING
"To know where you are going-you need to know where you have been" - www.darrynsretrorc.rtox.com
RETRO R/C is offline   Reply With Quote
Old 01-20-2012, 06:36 AM   #2610
Trader Rating: 23 (100%+)
Originally Posted by RETRO R/C View Post
Hi guys,
Cheers
Darryn
With the introduction on the gear diff - the 417 series is as solid as you can get. Probably the only part that takes on some wear is front cvds when you run spools.
Unless the car is abused, you can run 50 packs before you might notice serviceable wear.
In retrospect I would have purchased C-hubs and Cvds as the only spares. The rest of the parts for tuning.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
