Like Tree1Likes
Old 01-12-2012, 03:48 AM   #2581
CraigM's Avatar
Trader Rating: 34 (100%+)
Ride springs are good too, less aggressive than HPI but more stability so maybe the go for high bite asphalt or low bite carpet. They are the same as MR33
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-12-2012, 05:54 AM   #2582
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
mr33 come in a nice blue to go with car or you can get them in black
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 01-12-2012, 05:19 PM   #2583
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
just sharing... "repairing" notched diff outdrives (gear, ball):
1. add a blob of epoxy over the notches
2. let it harden overnight.
3. sand/dremel the blob flat so only the notch is filled.
4. sand the slots with 1200 or finer sandpaper to smoothen it
5. (i also take the "edge" out of the slots with a dremel"
pic attached is an outdrive for a mini but i've done the same to my SpecR and Tamiya white gear diff.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-12-2012, 06:59 PM   #2584
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Nilks View Post
Tamiya (White/Blue) for carpet and HPI springs for asphalt. So the Tamiya springs are being used!
OMFG!!! Is there anyone else want to bitch!!!
Yes I've already acknowledge my original comment was in reply to my views on asphalt tracks and I didn't take into consideration what is used on carpet.
FFS, comments from the "Cheap Seats" ... Get Over IT already!!!
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-15-2012, 01:55 AM   #2585
RC MARKET's Avatar
Cso TRF417X Chassis
RC MARKET is offline   Reply With Quote
Old 01-15-2012, 02:14 AM   #2586
hacker's Avatar
Trader Rating: 140 (100%+)
Originally Posted by 2-Bad View Post
Nobody runs Tamiya springs competitively unless the rules dictate you have too. Get the Xray...
I wouldn't say nobody
hacker is offline   Reply With Quote
Old 01-15-2012, 09:46 AM   #2587
Marek Gadomski's Avatar
Default my love
my 417X from training
i went from xray, car is great , much more mechanical traction
____________________________________________________
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
marcgadomski@gmail.com
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 01-15-2012, 09:46 AM   #2588
Default my love
Old 01-15-2012, 12:03 PM   #2589
Craig W's Avatar
Originally Posted by RC MARKET View Post
TRF Damper X-Ring
are these the seal that go in the gear diff
Old 01-15-2012, 12:20 PM   #2590
No they go in offroad dampers! Hence trf damper x ring.
Smartypants is offline   Reply With Quote
Old 01-15-2012, 12:42 PM   #2591
Craig W's Avatar
what part number for 1s that go in the diff
Old 01-15-2012, 01:08 PM   #2592
REALLY
You were only singing about how good Xray was on the Xray forum
sidecarphil1 is offline   Reply With Quote
Old 01-15-2012, 02:35 PM   #2593
hotdognobun's Avatar
Trader Rating: 31 (100%+)
they work perfect for onroad too! i am using them on my 417x and after 6 packs it still retains smooth motion and leak free and i did not use green slime! i use 70 durometer with trf 40 mineral shock oil
hotdognobun is offline   Reply With Quote
Old 01-15-2012, 04:58 PM   #2594
Craig W's Avatar
So you ran then in the gear diff
Old 01-15-2012, 06:41 PM   #2595
i meant you i used them in my onroad shocks even though they are meant for offroad! i believe you can use the Spec R x ring with tamiya gear diff? i have some on order and will let you know when i install it
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
