Old 01-11-2012, 02:36 PM   #2566
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Juan Aveytia View Post
I use them all the time. The latest and greatest isn't always the best.
I have no idea what you are on about... What is the latest & greatest, Xray springs have been around for years!!!
If you look through all the Team Drivers like Marc, Jilles, Elliott & co, they have only used, Ride, HPI, and HB. Being Tamiya team drivers that might suggest something about Tamiya springs, eh ???
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-11-2012, 02:50 PM   #2567
Mostly Tamiya drivers use Tamiya springs for indoor carpet, and HPI for outdoor looking at the set-up sheets.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-11-2012, 03:03 PM   #2568
Pro10noob's Avatar
Looking at the front of your car, it looks like the front diff is not straight between the bulkheads.
Are your belt tensioners mounted the same?
As in the dots on the holders are facing the same direction???
Also isn't that servo a bit on the large size??
regards Roy
Originally Posted by hotdognobun View Post
heres some old build pictures of my 417x
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-11-2012, 03:35 PM   #2569
hotdognobun's Avatar
Trader Rating: 31 (100%+)
regards Roy
just checked all and everything is by manual. tensioner from diff are correct and servo is the new brushless low prfile that just came out! same size as ko and futaba low pro servos.running right now off the ground and everthing seem to run fine with no vibration or hesitation
hotdognobun is offline   Reply With Quote
Old 01-11-2012, 03:40 PM   #2570
Pro10noob's Avatar
Weird
l===/o\===l
Old 01-11-2012, 03:47 PM   #2571
2-Bad's Avatar
You maybe right about that, the rug might be a different story... oops
Old 01-11-2012, 03:56 PM   #2572
Test back to back and you will find lap times to be the same. Sometimes changing shock oil is needed. I know people like to use what everyone else is using. I found it doesn't mean it is actually any faster. Reinhard couldn't set a car up if his life depended on it. He's just a wheel.
Juan Aveytia is offline   Reply With Quote
Old 01-11-2012, 04:24 PM   #2573
Trader Rating: 22 (100%+)
You could try and flip the belt (take it of and re-install going the other direction) to see if it runs on the right side of the pulley as your pics show it to be running on the left side of the pulley.
May be the weave in the belt forcing it to run on the left side of the pulley.
Check the eccentrics on the bearings are set the same.
Mine does rub a little on the servo mount but seems to not affect performance.
bjspinner is offline   Reply With Quote
Old 01-11-2012, 05:56 PM   #2574
TryHard's Avatar
Agreed... White/Blue is still the ticket on carpet, and why you would want to pay through the nose for Xray springs is beyond me..
Old 01-11-2012, 06:00 PM   #2575
TryHard's Avatar
The belt will naturally touch rub against the servo mount a little, although if it's pressing hard then something is obviously wrong.
Don't forget you can shim the centre pulley out to the right of the car as well, this will help to guide the belt further away from the centre.
HiH
Ed
Old 01-12-2012, 12:49 AM   #2576
bjspinner/tryhard and the rest all rock! flipping belt did the trick and shifting center pulley over helped to! rub free!!!!
Old 01-12-2012, 01:28 AM   #2577
chrisk's Avatar
Trader Rating: 32 (100%+)
Hotdognobun I am in love with your avatar every time you post
Luv it
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 01-12-2012, 01:43 AM   #2578
Pro10noob's Avatar
Yeah
Who is she?
regards Roy
l===/o\===l
Old 01-12-2012, 02:16 AM   #2579
some pic on porn site (tube8)! forgot her name but come to San Diego theres alot of that here! Giggidy Goo!
Old 01-12-2012, 02:24 AM   #2580
Tamiya (White/Blue) for carpet and HPI springs for asphalt. So the Tamiya springs are being used!
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
