Old 12-31-2011, 05:03 PM   #2506
Trader Rating: 30 (97%+)
Originally Posted by hotdognobun View Post
mine did this too this too! felt like my geardiff locked up? I checked and did everything to figure out what it was! I checked to see if it was camber, changed to springs, checking play in wheel axels, but it still gave me issues? I solved mine by widening the rear by 6mm and using ball diff instead of geardiff.
my car did the same thing, running 17.5 indoor carpet, changed to ball diff, widned rear, still the same, here is my setup if some one can try to dial the car in for me,
high traction carpet, 17.5 modified
rear tamiya yellow springs, added 1 mm under the top link, stock shock position, 450 xray oil
front, tamiya blue springs, added 2mm under the top link, stock shock position
550 xray oil
droop 2 mm all around
thanks
zaraz is offline   Reply With Quote
Old 12-31-2011, 05:34 PM   #2507
rtypec's Avatar
Default Happy New Year's Eve and Happy New Car
Hi All,
Ran the 417X today for the first time and am pleased with how well it drives.
Straight out of the box with the exception of a putty gear diff in the front, split rear blocks, no motor mount cross brace, 500 shock oil, and F:24.0mm R:24.5mm droop. Good start so far...
Here's a video from earlier today of the the car being run at race pace for the first time (only second battery...first half-battery run was just a shake down). Thanks to Mark for filming and apologies to Maxepower for hacking the crap out of him
+ YouTube Video
And here's a picture of the new Audi R8 LMS body in RedBull livery:
It's been a good year and I wish all of you a happy new one!
Tamiya TRF417-audi-r8a.jpg   Tamiya TRF417-audi-r8b.jpg   Tamiya TRF417-audi-r8c.jpg
rtypec is offline   Reply With Quote
Old 12-31-2011, 06:56 PM   #2508
TryHard's Avatar
If your gear diffs feel like they are locking up, check the shims inside. They have a tendency to cone, and then apply pressure to the big gears, making it feel like it's getting tighter. The reason they cone is that the shims are bigger in diameter than the pins, so any pressure is applied only to the inside of the shims.
I replace the standard shims with 1 0.3m x 5mm shim, as these also have a smaller outer diameter, only a little bigger than the pins, so they don't cone.
HiH
Ed
Old 12-31-2011, 07:47 PM   #2509
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by rtypec View Post
Hi All,
+ YouTube Video
who makes the body
who make the body
Craig W is offline   Reply With Quote
Old 12-31-2011, 10:24 PM   #2510
nolo148's Avatar
Originally Posted by Craig W View Post
who make the body
Im pretty sure it was made by tamiya
nolo148 is offline   Reply With Quote
Old 12-31-2011, 10:30 PM   #2511
lbckevin's Avatar
Trader Rating: 89 (99%+)
That is the new Tamiya Audi R8 body.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-01-2012, 12:53 AM   #2512
PizzaDude's Avatar
who make the body
Who made these decals?
BTW very N I C E...
PizzaDude is offline   Reply With Quote
Old 01-01-2012, 12:55 AM   #2513
What a nice body the Audi R8 GT3 and the wheels too. We should drop the Protoforms and start to use realistic Tamiya bodies and no more disc wheels in TC racing.
BJS414 is offline   Reply With Quote
Old 01-01-2012, 01:51 AM   #2514
CraigM's Avatar
Trader Rating: 34 (100%+)
That body would scrape hard being so low!
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-01-2012, 02:23 AM   #2515
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Form>Function
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 01-01-2012, 05:59 AM   #2516
rtypec's Avatar
Happy New Year!
The body is indeed the new Tamiya R8 LMS set and the decals are from the old Audi A4 DTM 2005 Red Bull . The part number for the decals is 9805892.
Yes, the body was lowered one hole on the body posts and the wheels were spaced out for photos. If I ran it at that height, it would scrap everywhere, including the straight lol.
Old 01-01-2012, 06:16 AM   #2517
Just ordered a set of the arrowmax ecs's, do they bolt right up or need modification to fit??
Pinionizer is offline   Reply With Quote
Old 01-01-2012, 07:18 AM   #2518
RedBullFiXX's Avatar
Very nice, as always Rod.
What color is that ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-01-2012, 07:43 AM   #2519
hotdognobun's Avatar
Trader Rating: 31 (100%+)
HiH
Ed
I was using 1 shim set up and did sand down the small gear! Right now i am testing a gear diff and using anti grease instead of oil! my lap time actually is .8sec slower cause it might be to sticky but car did stop breaking loose in the rear.
Also i ordered the spec r shaft spec 2 and notice it is short on the threaded axle part where you insert the pin? package says for 416/417!
hotdognobun is offline   Reply With Quote
Old 01-01-2012, 08:55 AM   #2520
Originally Posted by eded1 View Post
Do you drive a spool or diff in the front.
And what kind of blades you are using, or without blades.
Ed
Spool, no blades. I'm running them on the CEFX chassis with the TOP spool.
avink007 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
