Like Tree1Likes
Old 12-30-2011, 01:43 PM   #2491
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Originally Posted by mhavlena View Post
At first, I was loosing the rear end in the long sweeper all week, then the car started to flip in the sweeper as well?? confusing as this indicated lack of traction followed by too much traction??
Played with all the normal suspect items (shocks/sway bards, roll center, etc), but the only thing that seemed to help was putting a new set of tires on (we have to use sweep at our local track)?
The used tires weren't that old....anybody experience this before...oh ya, running 17.5 blinky on indoor carpet.
Appreciate any experience out there...
mine did this too this too! felt like my geardiff locked up? I checked and did everything to figure out what it was! I checked to see if it was camber, changed to springs, checking play in wheel axels, but it still gave me issues? I solved mine by widening the rear by 6mm and using ball diff instead of geardiff.
hotdognobun is offline   Reply With Quote
Old 12-30-2011, 01:44 PM   #2492
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default Parts question
Can you use the new 417X motor mount on the old 417 chassis?
Are the holes the same?
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 12-30-2011, 05:04 PM   #2493
Originally Posted by ShrewdRacer View Post
hi guys, just curious, is there a difference in running the 111t vs 113T spur aside from the different FDRs you can get from the two? is there a difference in top speed/acceleration between the two?
or to make it a little bit more distinct, what's the advantage of running a small spur vs a bigger spur (or vice-versa) when running the same FDR?
I find that a larger spur gives you more bottom-end, where a smaller spur (keeping the same FDR) gives you more top speed. But you probably cannot feel the difference between 111T and 113T.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 12-30-2011, 05:38 PM   #2494
ShrewdRacer's Avatar
so isn't it advisable to get the smaller ones because BL motors have a lot torque compared to brushed motors?
ShrewdRacer is offline   Reply With Quote
Old 12-30-2011, 07:59 PM   #2495
TryHard's Avatar
Thanks Greg G
yes
| THard.co.uk | Xray | MuchMore |
Old 12-30-2011, 09:44 PM   #2496
RL.2002's Avatar
just wanna know. does the 417x lower chassis fit on 417??
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 12-31-2011, 05:29 AM   #2497
I use it to fine-tune the way my car drives. If I am at a small track with low speeds, then I will use a larger spur to get the bottom-end power, and at high speed tracks, I will focus on the top speed from a smaller spur.
Niklas Hansen
Old 12-31-2011, 07:17 AM   #2498
Vicko's Avatar
Trader Rating: 14 (100%+)
so to change the 417 to the X you need the top deck, chassie, shock tower,
motor mount parts and battery holders? did I miss anything?
Vicko is offline   Reply With Quote
Old 12-31-2011, 09:52 AM   #2499
CL
CL's Avatar
Trader Rating: 32 (100%+)
Gear diff if you don't have one.
More racing and less typing!
CL is online now   Reply With Quote
Old 12-31-2011, 10:29 AM   #2500
the king pins are different too.
Smartypants is offline   Reply With Quote
Old 12-31-2011, 11:33 AM   #2501
Question for the guys running the 417x. What motor mount configuration is everyone running on the X, 1 piece or 2 piece?? Since the X has alot of flex already in it??
Pinionizer is offline   Reply With Quote
Old 12-31-2011, 11:59 AM   #2502
2 piece with seperate suspension mounts frt and back! i like flex! i run mine at Tamiya track and it feels just right
Old 12-31-2011, 12:16 PM   #2503
carpet or asphalt?
mhavlena is offline   Reply With Quote
Old 12-31-2011, 01:32 PM   #2504
carpet or asphalt?
assphalt and it is a short track with lotso turns! Not a real technicle track but it does require grip cause it is a slippery track even though they and addictives to the surface
Old 12-31-2011, 04:40 PM   #2505
nolo148's Avatar
can anyone help suggest a pinion i should run? im using the 113t spur and dont know how much pinion teeth would be best
thanks
nolo148 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
