Old 12-28-2011, 09:48 AM   #2476
Originally Posted by Pro10noob View Post
Hmmmmmmm most servo's have a trow of 60
I have it's Team orion counterpart and had to dail it in a bit down on the EPA.
Do you use a servosaver?
If so, how long is the length of the horn from centre to ball?
Check below specs of the 1251MG.
It should be ok
regards Roy
Dimensions(mm): 40.8X20.2X25.4
Weight(g): 44.5
Speed(@4.8V sec/60): .10
Torque(@4.8V oz-in): 97.2
Speed(@6.0V sec/60): .09
Torque(@6.0V oz-in): 125.0
Gear: Metal
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
Yes I do use a servo saver, the length between center to center-ball is 16mm (I'm using the standart servo saver that came with the kit with the big holes for the screw).
I mesured the throw, and it is indeed 60 (sorry to mention 70, I was just guessing to give an idea of the situation).
So how come the servo is only rotating 60 while without power it can do about 80 ?
Am I the only one that my steering knuckle is 3mm away from the C-Hub ?
PS: My previous servo had a throw of 90 and a full rotation without power of 170 ( how come both of my servos would rotate less when they're connected to power?
Thanks again Roy
MatJ is offline   Reply With Quote
Old 12-28-2011, 10:21 AM   #2477
Pro10noob's Avatar
Without power you can rotate the servo horn about 170 to 180
On power it is a lot less.
My servosaver horn is 17MM centre to centre.
Perhaps that is just what you need
I don't think you need the steering knuckle to touch the C-hub tho.
Just drive the car and see if you have enough steering
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-28-2011, 10:25 AM   #2478
regards Roy
Cheers Roy, good to hear that it's "normal", well I hope it is
Unfortunately I won't be able to drive it before the new year, so I'll see later
Thanks again!
Old 12-28-2011, 04:57 PM   #2479
hotdognobun's Avatar
Trader Rating: 31 (100%+)
hey guys just tested 10 packs with the x ring 70 with vg 40 oil and its shows no leaks so no need for green slime! it does work for any shocks! I have extra 50 x ring if anyone is interested nip
hotdognobun is offline   Reply With Quote
Old 12-28-2011, 07:38 PM   #2480
Has anyone tried the Aeromax ECS front drive shafts?
avink007 is offline   Reply With Quote
Old 12-28-2011, 08:54 PM   #2481
ngo8's Avatar
Send a message via ICQ to ngo8
Yes very good
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-29-2011, 10:46 AM   #2482
Originally Posted by ngo8 View Post
Yes very good
Cool. I will have them on my car for the first time at the Birds.
Old 12-29-2011, 11:44 AM   #2483
Do you drive a spool or diff in the front.
And what kind of blades you are using, or without blades.
Ed
eded1 is offline   Reply With Quote
Old 12-29-2011, 11:44 PM   #2484
ShrewdRacer's Avatar
hi guys, just curious, is there a difference in running the 111t vs 113T spur aside from the different FDRs you can get from the two? is there a difference in top speed/acceleration between the two?
or to make it a little bit more distinct, what's the advantage of running a small spur vs a bigger spur (or vice-versa) when running the same FDR?
ShrewdRacer is offline   Reply With Quote
Old 12-30-2011, 12:13 AM   #2485
Using a smaller spur instead of a larger one with the same FDR will make the car have a different rate of acceleration. The smaller spur will rotate a full 360 turn faster than the larger spur, hence your wheels etc will turn quicker etc. The top speed will ultimately be the same.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is online now   Reply With Quote
Old 12-30-2011, 01:45 AM   #2486
RC MARKET's Avatar
TRF417X Spare parts released !
Tamiya TRF417-ta-13454829.jpg   Tamiya TRF417-ta-14004089.jpg   Tamiya TRF417-ta-13454832.jpg   Tamiya TRF417-ta-14004090.jpg   Tamiya TRF417-ta-11424470.jpg
RC MARKET is offline   Reply With Quote
Old 12-30-2011, 02:41 AM   #2487
daleburr's Avatar
The only difference will be a change in weight distribution due to the motor being in a different position. Power will be the same if the FDR is the same.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 12-30-2011, 08:44 AM   #2488
Default Are people still using 2 o-rings at the bottom of their shocks?
Just like the title states?
I think I may have accidentally ovalized the shock shaft guide washers and thought I should try using 2 o-rings instead of the standard 1 o-ring with guide washer.
What are the handling/behavioral differences? Do the shocks still seal properly with 2 o-rings?
Thx!
mhavlena is offline   Reply With Quote
Old 12-30-2011, 08:48 AM   #2489
Default 417X traction roll problems
At first, I was loosing the rear end in the long sweeper all week, then the car started to flip in the sweeper as well?? confusing as this indicated lack of traction followed by too much traction??
Played with all the normal suspect items (shocks/sway bards, roll center, etc), but the only thing that seemed to help was putting a new set of tires on (we have to use sweep at our local track)?
The used tires weren't that old....anybody experience this before...oh ya, running 17.5 blinky on indoor carpet.
Appreciate any experience out there...
Old 12-30-2011, 10:38 AM   #2490
Check your rear tyres are not coming unglued.
Smartypants is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
