Old 12-27-2011, 01:49 PM   #2461
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Where can I buy Tamiya blue titanium turnbuckles for the camber links?
Racing4Evo is offline   Reply With Quote
Old 12-27-2011, 01:57 PM   #2462
Pro10noob's Avatar
What Racing4Evo said is spot on.
The front pulley is on the wrong side.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-27-2011, 02:41 PM   #2463
haywood's Avatar
Trader Rating: 48 (100%+)
Default 417x
Does the kit need ecs or dcj in the front? Do the stock joints produce chatter like the Xray and others?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-27-2011, 02:46 PM   #2464
Trader Rating: 30 (97%+)
+1, and if it needs ecs, are the arrowmax ones better, or spec r, never mind arrowmax are better, but shipping is so stupid, 23 dollars just for shipping, but you can get lot of sets of their ecs shipped for that price, anyone want to split shipping I,m in canada,lol, let me know, and maybe we can get a group buy on these items and save on shipping
zaraz is online now   Reply With Quote
Old 12-27-2011, 04:58 PM   #2465
Default Camber link length and effects?
What are the handling changes/differences between running the camber links long and short?
I copied Jilles snowbirds setup, car runs great in the tight corners but is quite loose in the large sweepers on power. Played with shock position, shock springs, rear camber and sway bars with no effect.
Now thinking of playing with the camber links, perhaps making them shorter in the rear, or should I make them shorter in the front?
Appreciate any advice!!
mhavlena is offline   Reply With Quote
Old 12-27-2011, 05:29 PM   #2466
2-Bad's Avatar
Trader Rating: 24 (100%+)
High speed sweepers, think droop first imo....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-27-2011, 06:42 PM   #2467
ngo8's Avatar
Send a message via ICQ to ngo8
its $23 shipping but you get it overnight with dhl they did for me anyway .....i have both arrowmax and spec-r v2 and the arrowmax are stronger but the sprec r v2 wont fall apart in the middle of a run like it did yesterday and i had the set screw thread locked very weird i hope it doesnt happen again .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-27-2011, 06:49 PM   #2468
sorry which ones feel apart, arrowmax or spec r, also any mods needed to fit the spec r v2, thanks
Old 12-27-2011, 07:02 PM   #2469
ngo8's Avatar
arrowmax not sure why but it happened.
Old 12-27-2011, 09:56 PM   #2470
Racing4Evo's Avatar
I just put the ver. 2 spec r ecd shafts on my car and it went smoothly the only issue I ran into was the wheel hex being a bit tight when putting them back on. I just put on a wheel and crank down on the wheel to set the hex adapter flush the steering knuckle.
Old 12-28-2011, 01:09 AM   #2471
banquer's Avatar
Originally Posted by Racing4Evo View Post
You mounted the front pulley on the wrong side of the spool assembly. Look at this picture from kentech's blog. His is mounted all the way against the right side bulkhead.
Thanks a lot, Racing4Evo, this was my mistake.
Cheers!
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 12-28-2011, 09:07 AM   #2472
Hello everyone,
Im new to this forum, so please excuse me for posting in the wrong area if I do.
Anyway, I currently own a 417 and for xmas, I got a new servo, Savox SC-1251MG, the low profile one.
Before I was running another digital servo and everything was good.
Now, I just swapped the servo's, did some re-wiring and when i turn my steering stick left/right, the steering knuckles doesn't touch the C-Hub (about 3mm off) whereas with my old servo it was touching.
Also I noticed something weird, if I rotate the servo whn it's NOT connected to the battery (ESC to battery), the servo is able to rotate about 110-125 until it's at full lock.
When the ESC is on and connected to the battery and the servo is getting power, when I steer left/right, it only rotates about 70, which is why it doesn't touch the C-Hub.
What is wrong ??
I tried another receiver, ESC and still problem there :/
Thank you very much for any help, I hope it will be fixed soon
MatJ is offline   Reply With Quote
Old 12-28-2011, 09:18 AM   #2473
Pro10noob's Avatar
Check your EPA on your transmitter.
Not all servo's have the same trow.
Some brand servo's need adjustment of EPA after mounting it on your chassis.
regards Roy
Originally Posted by MatJ View Post
Hello everyone,
What is wrong ??
l===/o\===l
Old 12-28-2011, 09:25 AM   #2474
regards Roy
Roy, thank you for your hint, I just tried to adjust the EPA on my transmitter (Sanwa Gemini II), the max it proposes me is 120%, I set it at 120% and it would only rotate to 70, if I went lower than 120 (i.e 100 ...), the servo would rotate less then 70 ...
Old 12-28-2011, 09:37 AM   #2475
Pro10noob's Avatar
Hmmmmmmm most servo's have a trow of 60
I have it's Team orion counterpart and had to dail it in a bit down on the EPA.
Do you use a servosaver?
If so, how long is the length of the horn from centre to ball?
Check below specs of the 1251MG.
It should be ok
regards Roy
Dimensions(mm): 40.8X20.2X25.4
Weight(g): 44.5
Speed(@4.8V sec/60): .10
Torque(@4.8V oz-in): 97.2
Speed(@6.0V sec/60): .09
Torque(@6.0V oz-in): 125.0
Gear: Metal
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
l===/o\===l
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
