Like Tree1Likes
Old 12-20-2011, 11:44 AM   #2446
Originally Posted by Pro10noob View Post
Naaaaaaaaaahhhhhhh
Just saying that the X-type shock rings are nothing new
Spec-R uses them X-rings now to get the gear diff leakage free and it works
Tamiya is comming out with them for the shocks but some one else beat them to it
The do work great and hold there own longer then the normal O-rings form what i have noticed.
Now we have to wait till they bring them out for there own gear diff.
Mine VII diff isn't leaking but hey, they need to work on something new 2 get something great even better
regards Roy
I am only play a yoke, I know this already from the serpent 400 serie.
Se ya Roy
Best regards
Ed
eded1 is offline   Reply With Quote
Old 12-20-2011, 12:46 PM   #2447
Pro10noob's Avatar
You naughty boy
Playing tricks on me
regards Roy
Se ya Roy
Best regards
Ed
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-22-2011, 08:27 AM   #2448
Trader Rating: 30 (97%+)
looking for a setup for a high grip carpet track for a 417x
what tamiya tires to use type a or type b
droop setting front and rear
front shock hole position
rear shock hole position
what spacers to use front, on top of the c hub, and the top where the alumnum diff holder is
rear spacer on top of the hub and spacer on top where the aluminum diff holder is
or should i just built it to box setup, thanks
zaraz is offline   Reply With Quote
Old 12-22-2011, 11:29 AM   #2449
Blueman Austria's Avatar
Hy!
Does anyone know if the double CVD´s are fit also the old EvoIV/415 C-Hubs?
On the pictures it looks like that the original c-hubs have more room for the cvd, so i think it could be an issue.
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 12-23-2011, 12:03 PM   #2450
ngo8's Avatar
Send a message via ICQ to ngo8
Kentech just posted a setup on his blog which is really close to what i run http://kentech.blogs.se/
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-25-2011, 11:09 PM   #2451
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Went and did a shake down run with my christmas present, 417x, an I was pretty happy with the car. Easier to drive than I predicted. I changed a few things from the stock setup. Major thing being the spec r drive shafts and raising the front inner camber link.
I havent driven in 3 years so I'm not sure if my driving is just off but I felt like the diff oil was much too thin. First 2 mins were good then the car became harder and harder to drive for the remainder. It became unpredictable and sharp. Should I try a thicker oil? I was thinking 2000wt instead of the stock 900wt. Or can I fix this by changing something else?
Next time out I want to try a gear diff w/ putty in the front and some harder springs.
Also I have the old Aluminum steering brace from the 416 that also mounts to the upper deck. Can I use this without any problem? What exactly will I gain from it? Is it better than the carbon brace only connecting the steering posts? want to calm the front end.
Racing4Evo is offline   Reply With Quote
Old 12-25-2011, 11:20 PM   #2452
Racing4Evo's Avatar
Also the track I run at is TQ RACEWAY. www.tqrcracing.com . The track is small and technical usually with med/high grip.
I am .5 sec off pace and really lacking consistency. Running 17.5 blinky. Geared at 4.11
Old 12-26-2011, 02:41 AM   #2453
Trader Rating: 69 (100%+)
Isn't the original TRF417 better for high-grip carpet track? TRF417X flexes a lot more than TRF417 so you'll probablt need to stiffen up the car quite a bit.
Have you tried to gear lower? Isn't 17.5 usually gear in the range of 3.5 to 4.0?
What tires are you running?
eComet is offline   Reply With Quote
Old 12-26-2011, 03:39 AM   #2454
hacker's Avatar
Trader Rating: 140 (100%+)
so you havn't driven a TC in 3 years, and expect to be on the pace?
0.5 sec aint too much to be ashamed of.
more laps will bring more speed
hacker is offline   Reply With Quote
Old 12-26-2011, 08:07 AM   #2455
Anyone know if it's possible to buy the trf417x lower chassis plate on its own as of yet?
Smartypants is offline   Reply With Quote
Old 12-26-2011, 12:19 PM   #2456
hotdognobun's Avatar
Trader Rating: 31 (100%+)
rc market should have it
hotdognobun is offline   Reply With Quote
Old 12-26-2011, 08:58 PM   #2457
CraigM's Avatar
Trader Rating: 34 (100%+)
Ed's on redrc!
http://www.redrc.net/2011/12/jj-wang...mas-shoot-out/
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-27-2011, 12:21 AM   #2458
TryHard's Avatar
Originally Posted by CraigM View Post
Um, yeah... and they managed to get my worst side too! Honestly, every other pic had my eyes open!
Still, not such a bad result. Didn't have enough to challenge the front two, but was comfortably ahead of the rest, so third it was. Car wasn't great, but improved a lot during the day, and then found some more stuff that made it better still after racing!
Track was mega traction, tight indoor asphalt, and not helped by running very soft compound tyres, so traction roll was a big issue. Had to soften the car off to make it stable and let it roll, but still was a tendancy for it to fall over the front if I got too aggressive initially.
Anyway, setup is attached, major differences are;
Smokem FX chassis (loads of front end!)
Stiffening the car back up a little with non-cut top-deck and steering brace.
Softer shocks (carpet style)
Wider front (D/B, 1mm axle shims)
Long camber links.
In the testing after, I found Silver/blue to be a better spring combo, and going to 3.5mm on the rear wheelbase shim better as well. Was really struggling in the tight sections of the course, lacked mid-corner, basically making the car a little too stable. So, next time out, I'll be trying shorter links, and also going back to the flexy top deck... that is, after I play with the new toy
| THard.co.uk | Xray | MuchMore |
Old 12-27-2011, 11:47 AM   #2459
banquer's Avatar
Hello guys!
First of all, Merry Christmast to everyone!
Past days, I finished mounting my 417X, and I'd found one problem.
The front belt, touch the inner aluminium servo mount and antenna post.
I'd shaved the inner servo mount to resolv the problem (about 1,5-2,0 mm).
I review all the mount points about central spur gear, rear diff and front spool without founding any mistakes, and shimmed them in the right possition like manual drive us.
And also, the upper belt tensor, is to centered and I must do a drill 1.5 mm to left about not touch the front belt.
Look at this photos.
Do you have this problem? Any ideas?
King regards from Spain!
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 12-27-2011, 12:36 PM   #2460
Racing4Evo's Avatar
Originally Posted by banquer View Post
Hello guys!
You mounted the front pulley on the wrong side of the spool assembly. Look at this picture from kentech's blog. His is mounted all the way against the right side bulkhead.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
