Old 12-09-2011, 04:20 PM   #2401
Pro10noob's Avatar
Dunno what your running front/rear then but at the rear/front it would be 1XA.
Some of the split blocks you can swap from left to right to get a different angle.
You won't get this with the one piece blocks.
Just dismount one and see what you got.
regards Roy
Originally Posted by Pinionizer View Post
Thanks for the info. It looks like the car has some front sweep, (Front Front block is 1C, and the Front Rear are the split blocks, the Front rear are the split blocks and the Rear Rear is a 1E). Sorry if i'm sound dumb but this is my first tamiya.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-09-2011, 04:22 PM   #2402
stitchy's Avatar
Originally Posted by maxepower View Post
Stitchy,
When are the 417X kits suppose to get to your store? Was it sometime next week or do you have an exact date when they come in?
Thanks in advance!
TA-mee-ya USA received them yesterday and should have started shipping to distributors already. We should have them by mid-next week
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 12-09-2011, 04:42 PM   #2403
2-Bad's Avatar
Trader Rating: 24 (100%+)
Send mine out first, yes??? hahaha
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-10-2011, 01:22 PM   #2404
Trader Rating: 26 (96%+)
I am going to be running on a high grip carpet track, what would be the best droop setting , thanks
zaraz is offline   Reply With Quote
Old 12-10-2011, 01:53 PM   #2405
the kit comes with really nice black crome screws, where can I purchase some more in different sizes
Old 12-10-2011, 07:09 PM   #2406
I paid over 650 for my kit and the rear suspension mount is scratched, and my left c hub is all deformed anyone else have this
Old 12-10-2011, 07:57 PM   #2407
ngo8's Avatar
Send a message via ICQ to ngo8
Xray|Kyosho|Exotek|Hobbywing|Sanwa|Trinity|Xpert|KoPropo
ngo8 is offline   Reply With Quote
Old 12-11-2011, 12:09 PM   #2408
FunkyDunky's Avatar
I run 6mm front and 5mm rear, both are measured from under the wishbones
top roll centres are 5mm front and 4mm rear
FunkyDunky is offline   Reply With Quote
Old 12-12-2011, 07:55 PM   #2409
Swampracer's Avatar
Trader Rating: 67 (99%+)
Default Split blocks
Quick question....when using the split blocks, what are people using as spacers.
I saw a blog with pictures of the new 417X and it looked like he had small spacers under each split block.
Does Tamiya make these? or are they aftermarket?
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 12-12-2011, 08:35 PM   #2410
TryHard's Avatar
Thanks Greg G
Personally, I just use the same spacers as for the wheelbase and camber links... I think the Kentech blog you saw, he was running cut down standard suspension block shims.
HiH
Ed
TryHard is online now   Reply With Quote
Old 12-13-2011, 05:26 PM   #2411
miguelfs14's Avatar
Finally, I found a solution to premature wear in diff caps. I know blades are a consumable, but not in two runs with new diff cups.
You need: mini drill, damaged diff cups, associated 3.5mm blades 31238 and 3.5mm diamond bite
First, take your damaged diff cups, a diamond bite of 3.5mm and make the groove more wider until asso blade fit good.
Second, make holes of blade little wider with a screw driver or something until move freely and put into shaft pin.
Enjoy your car for many many runs without thinking in shaft blades.
I can't put some pics because forum permissions, sorry.
miguelfs14 is offline   Reply With Quote
Old 12-13-2011, 09:15 PM   #2412
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Kentech or anyone who is done building the 417x! does the front belt rub onto the right steering post? I seen seen photos and it seems very close?
hotdognobun is offline   Reply With Quote
Old 12-14-2011, 12:32 AM   #2413
It's the same on the 417, the belt can brush against the servo mount. I tried shimming the centre pulley over a little and that helps it move away.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-14-2011, 12:39 AM   #2414
Tron's Avatar
Trader Rating: 16 (100%+)
Servo mount? What's that!
Shoe goo!
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 12-14-2011, 04:44 AM   #2415
CraigM's Avatar
Trader Rating: 34 (100%+)
Shoe goo!
Servo mount (noun) a rc device some people use to tweak their chassis
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
