Like Tree1Likes
Old 11-27-2011, 06:06 AM   #2296
kedal's Avatar
Originally Posted by Pinionizer View Post
Can anyone help me with this?? I would like to order some parts for the car soon. Thank you.
Check here for the part list and things to know about the 417 :
http://www.thard.co.uk/viewtopic.php?f=55&t=456
And here for some carpet setup :
http://www.petitrc.com/reglages/tami...miyaTRF417.htm
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 11-27-2011, 06:54 AM   #2297
TryHard's Avatar
Where can I find Arts setup from IIC?? I am looking for a good carpet setup??
here you go... Art's IIC setting
| THard.co.uk | Xray | MuchMore |
Old 11-27-2011, 07:54 AM   #2298
Thank you for the info. I will check out the links you posted!!
Pinionizer is offline   Reply With Quote
Old 11-27-2011, 07:58 AM   #2299
Hi guys, has anyone experienced rear belts not lasting with gear diff, and the outdrive blades quite the same.
Is there a wider/stronger belt out there that will fit. With the slightest of wear on the out drives promote heavy plastic blade wear, the Tamiya blades are cheap plain plastic are there other blades of better quality.
A rear belt has cost me two finals......really looking for some advice.
I do set the rear belt a bit tighter dot forward for gear diff.
Thanks.
charl mac is offline   Reply With Quote
Old 11-27-2011, 09:47 AM   #2300
kedal's Avatar
Thanks.
Maybe that is the problem.
About the blade, I use the Spec-R ones, no issues with it, stronger than the tamiya's ones.
Old 11-27-2011, 10:37 AM   #2301
Skitee's Avatar
Thanks.
What about the condition of the center pulleys, if those aluminium pulleys start wearing they'll definitely negatively impact the life of the belt.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 11-27-2011, 03:14 PM   #2302
Does anyone know what brand spur is on this car??
Old 11-27-2011, 03:28 PM   #2303
Pro10noob's Avatar
Looks like the new type Xenon gear.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-27-2011, 04:51 PM   #2304
TryHard's Avatar
Thats what I would say too.... Rear belt needs to be tight, but not too tight. needs about 3-4mm of deflection when you press down on it.
Also, as Skitee says, check the centre pulleys. Over time, they do wear, and the teeth become pointed (especially with mod motors), and can strip belts more easily... and this comes from experience
Regarding the blades, personally, the tamiya blades are fine, although the Spec-R's work good too. Most critical thing when using a gear diff is to make sure the outdrives are in good shape, any notching in them, replace the outdrive, as you'll just destroy the blades, whatever the type.
HiH
Ed
Old 11-27-2011, 06:37 PM   #2305
artwork's Avatar
Trader Rating: 62 (100%+)
Thanks.
The belts on the Tamiya are really good...they are flexible but not too soft. If you are having issues it is probably a pulley, because the belts wear very well. Something has to be going to to have two belts break or wear that quickly. Check the gear diff and middle pulley for wear or stuff clogged in the teeth.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 11-28-2011, 03:49 PM   #2306
Default Drilled shock caps or not?
For carpet racing.....does one prefer to have drilled shock caps or not?
What about shock rebound on carpet?
Any experience is appreciated.
Thx!!
mhavlena is offline   Reply With Quote
Old 11-28-2011, 04:44 PM   #2307
chrisk's Avatar
Trader Rating: 32 (100%+)
just got my Smokem chassis
looks great, just need to do a rebuild now and see if it is as good as the Smokem FX for my 416 was
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 11-28-2011, 05:13 PM   #2308
TryHard's Avatar
Thx!!
Personally, on carpet I go with sealed tops, but no foam, and minimal rebound... although I know some people like to use full rebound as well.
HiH
Ed
Old 11-28-2011, 06:32 PM   #2309
Trader Rating: 27 (100%+)
Looks great~! where is this company from?
JoeyE is offline   Reply With Quote
Old 11-28-2011, 07:53 PM   #2310
chrisk's Avatar
http://www.smokem-racing.com/Home.html
smaracing.org
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
