Like Tree1Likes
Old 11-01-2011, 11:53 PM   #2161
Pro10noob's Avatar
What class are you running?
The supplied oil is 900.
regards Roy
Originally Posted by Da4head View Post
I just started running the 417 on low to med bite carpet with box setup and have noticed that the car would kick out on hard accelleration out of corner. I am suspecting maybe its due to the rear gear diff. Is there rule on what CST oils should be used and does anyone know what the kit diff oil viscosity.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-02-2011, 02:24 AM   #2162
chrisk's Avatar
Trader Rating: 32 (100%+)
Default Set up help
i have been struggling a bit with my 417 to get it to drive nice out of the corner. i am having trouble with it being loose on exit under power.
i have been running a 416 with a smokem fx chassis and have that dialed and can drive it easy and never have any issues.
i am having this frustration with my 417.
one of the mod guys at my track drove it and him having alot more experience and smoothness could drive it nice, but could get it to be loose if he drove it hard.
me not having that experience yet struggle with the rear grip until i can learn to be a bit more smoother. but saying that , my same driving style with my 416 doesnt have the rear grip issues.
i am attaching my current setup for review and would love to hear from you guys about how to plant the rear more on exit under power.
running a 21.5 blinky class on ashphalt, medium grip track
thanks for anybody that will help with some ideas
Uploaded with ImageShack.us
http://imageshack.us/photo/my-images...ct2011001.jpg/
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 11-02-2011, 02:28 AM   #2163
Originally Posted by mhavlena View Post
Also, what are the drawbacks to using normal CVD's as opposed to the DCJ's that everyone is talking about?
Try to take a look on the last couple of pages in this thread. I had a huge problem with the normal CVD's and there is even a couple of videos displaying the problem. Switching to Litemodz CVS eliminated the problem!
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 11-02-2011, 02:59 AM   #2164
Trader Rating: 69 (100%+)
Switch to lighter oil because your air temperature is too cold. Use Muchmore #250 (equivalent to AE #40) instead for both front and rear.
Run both front and rear upper links at the inner most hole instead of the middle hole so you get more roll for medium grip track.
Use Muchmore 28 instead, again because of colder weather.
Front suspension mounts use 1C-1C and rear 1XA-1E for more grip. You have 0.5 front arm sweep for more mid-corner traction and 2.5 for rear toe, which is a bit less stable than the factory standard 3.0.
Ground clearance front 5 and rear 5.5 instead, this will have a bit less caster so your car is more stable out of the corner. You' also increase corner entry steering a bit.
eComet is offline   Reply With Quote
Old 11-02-2011, 03:01 AM   #2165
Switch to lighter oil because your air temperature is too cold. Use Muchmore #250 (equivalent to AE #40) instead for both front and rear. Also, take out the TRF blue O-ring on top of the shock bladder. Rebuild your shocks to have rebound no more than 3mm.
Old 11-02-2011, 04:39 AM   #2166
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Originally Posted by defcone View Post
I've been running mine for over 3months now and still haven't broke them yet. I have taken out the grub screws and covered the hole with heatshrink.
They look exactly like the Roche dcj's that are coming out:
(Taken from Max Ma's facebook page)
looks tough er..
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 11-02-2011, 09:55 AM   #2167
Da4head's Avatar
regards Roy
I am running 17.5 blinky class. I was going to try 2K to see if this has relation to the problem. Any other suggestions I could explore?
Da4head is offline   Reply With Quote
Old 11-02-2011, 10:26 AM   #2168
artwork's Avatar
Trader Rating: 62 (100%+)
Typically the slower the motor the thinner the oil, but if the car is loose then I would suggest thicker oil. In mod and 17.5 timing I personally like 1000, but in 17.5 no timing I like 80wt shock oil or 700 cst oil. The thinner the oil the more the car can rotate. Thicker rear oil will decrease rear rotation.
If you need to run 2000 or thicker with 17.5 to stabilize the car then something else in setup needs to be fixed. The team drivers setups seems to work very well on the correct surface. On carpet I run something very close to Jilles snowbirds setup. Outside I would run Marc's Reedy setup. There is no need to go at this alone and try to develop your own setup. There are plenty out there that you can use as a base setup.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 11-02-2011, 12:39 PM   #2169
Johnny Wishbone's Avatar
Originally Posted by artwork View Post
Typically the slower the motor the thinner the oil, but if the car is loose then I would suggest thicker oil. In mod and 17.5 timing I personally like 1000, but in 17.5 no timing I like 80wt shock oil or 700 cst oil. The thinner the oil the more the car can rotate. Thicker rear oil with decrease rear rotation.
+++++Art, that has to be the very best description on gear diff feel and oil needs I have ever read in any forum. I think I will copy/paste that for future reference. AWESOME
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-02-2011, 03:29 PM   #2170
Understood thx!!
But I still wanted to know how the Spec R version compares with the above litemodz version? They look the same...just easier to find.
Are the Spec R's just as relaible as the Litemodz? same functionality?
where can I find the litemodz?
Thz again!!
mhavlena is offline   Reply With Quote
Old 11-02-2011, 07:31 PM   #2171
TryHard's Avatar
chrisk, You haven't put your camber link or shock positions on the setup, these do have a big effect on the car.
Personally, I wouldn't go so soft on the oil... MM250 is very light, I've never gone that low, even in very cold conditions. Maybe MM400 would be better, but tbh, 450 probably is about right.
Also, personally, I've never had much success with blue springs on the rear... I find that the car rolls over to quick, and "dumps" all it's traction. For me, the silver rear has always worked best, and I find it more consistent to drive. Also gives more corner speed
I do agree that going to longest links will help the car to roll more.
Also, I would be tempted to move the front wheelbase back as well, try 1.0mm in front of the rear arm. If you are running the sweep as well, reduce the steering spacer to 2mm with this change, otherwise the ackerman will become affected.
Moving the wheelbase on the front only will give the car more steering (as the static weight goes forward), but also help to reduce and pendulum effect. Try it, you'll be surprised with the results
1XA/1D on the rear is a bit less toe, and if you still struggle going back to 1E on the rear should help, but given it's 21.5 blinky, less toe will only give more speed! 1C/1B I also like at this time, as mentioned, more mid-to exit steering, so I wouldn't worry too much about that.
Last thing I would try as well, if your still struggling, is cutting the motor mount and top deck. Both these changes will give the car more rear traction.
Main thing to remember is only change one thing at a time... so that you'll be able to tell what helps solve the problem.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-03-2011, 02:52 AM   #2172
chrisk's Avatar
thanks for the tips
top deck and motor mount are cut
i did complete the setup sheet but when i saved as a jpeg it lost quality
does anybody know how to upload a pdf file?
i will try a couple of things
28 are too soft, i do run them in the middle of winter but too soft now.
1E on rear would be to much as i want to not loose straight line speed.
Ed, are you saying to try silver on the rear as well as the front?
if i can work out how to upload a pdf you can see the camber links and shocks
smaracing.org
Old 11-03-2011, 04:18 PM   #2173
CraigM's Avatar
Trader Rating: 34 (100%+)
This design confuses me (lol), what stops the pin from falling out through the gap in the clip?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-03-2011, 04:34 PM   #2174
Kevin K's Avatar
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
One end of the clip is bent at a 90 or so deg angle and it goes into the hole where the pin is and pushes on the pin. So the clip will not move unless you pull it off....it is unable to rotate and the gap is in a location so the pin will never find it when fully seated. If you have a 417 its how the standard 417 axles are they use the same method of holding the pin in place.
The look likese these....
http://www.speedtechrc.com/store/ebp...d=967&id=10516
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 11-03-2011, 05:58 PM   #2175
TryHard's Avatar
The clip has a small hook that locates into one of the redundant holes, so it can't move (rotate) around the channel... simples
Still thinking blue again?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
