Like Tree1Likes
Old 10-24-2011, 08:03 AM   #2116
Have you tried looking at your wheelbase/ackerman settings? It looks like it starts to happen as the ackerman effect comes in.
I can't quite see in the video what spacers you are running so not sure if that might be anything to do with it?
Other than that I'm stumped.
Ade
ade_7 is offline   Reply With Quote
Old 10-24-2011, 09:59 AM   #2117
Originally Posted by Nilks View Post
Thanks for your reply, Elliott.
I have uploaded two new videos, but I didn't manage to do one with the car on the track. The problem started between two heats, and last year's indoor season and this year's outdoor season I had no such problem. My 4th battery of this indoor season, it started with this.
does it also happen with your wheels off?
Minami is offline   Reply With Quote
Old 10-24-2011, 10:55 AM   #2118
Originally Posted by TryHard View Post
Some chatter will be there at full lock for sure... but given from the list of what you've changed so far (i.e. everything!) to solve it, can only reason that that is the problem.
When you say you turned the steering down, was it on the bench? or on the track?
The rims themself are round yes? Have you tried a newer set of tyres since it occured, can't remember if you mentioned it or not. I mean, if you are running on carpet, tyres tend to last a while... so could simply be them out of balance. Otherwise running out of ideas!
HiH
Ed
The steering was turned down on the bench. I can try to turn down the steering and try the car on the track the next time I am at the track.
The rims are not perfectly round, no, but I have tried with a completely new set of tires and a set of Sorex tires, and the problem is there with all of them.
Ade
I am running kit setup on that matter, but I can try to play around with that the next time at the track.
It's hard to tell. I think I can hear it without the wheels, and the wheels then increases the "problem". But honestly I am not sure.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-24-2011, 11:30 AM   #2119
Originally Posted by Bony85 View Post
Elliott
Do you know what length shafts the arrowmax are equivalent too when built, I'm guessing 44mm?
Also do you know any shops in the uk who are selling these?
Mark
Hi Mark,
Hope you are ok?
I think the arrowmax driveshafts are 43mm... it is a little shorter but I dont think this makes much difference
Im not sure where you can get them in this country im afraid
Elliott
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 10-24-2011, 11:53 AM   #2120
double post
Old 10-24-2011, 12:22 PM   #2121
gave you a pm man. i hope you get this all sorted out
Old 10-24-2011, 07:45 PM   #2122
TryHard's Avatar
Ok, try turning the steering down a little on the track, see if it helps.
I know I have some chatter on the bench when I rev my car up at full lock, but isn't noticeable on the track. Turning it down on the bench is always a little bit of an issue, as the car has no load, so is easier to create any noise.
Haven't happened to change anything else in your steering setup recently, servo, horn etc, that may have increased the lock your using?
Bolting the wheels on will for sure make the issue more apparent, due to having to turn a much larger weight, and especially if they are out of balance!
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-24-2011, 11:44 PM   #2123
Regards
Ed
Well, I switched back to carpet setup (from my asphalt setup) for the indoor season, and renovated the car (new bearings and the like) and four batteries later, it started. It shouldn't be the setup, as I have used that before, but it might have happened during the renovation of the car.
Niklas Hansen
Old 10-25-2011, 02:24 AM   #2124
Id have another good look at the car, might be somthing silly like bulkheads wrong way round or tweaked.
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 10-25-2011, 03:24 AM   #2125
Trader Rating: 22 (100%+)
Any hard hits in these recent packs? As you said it got worse after 4 runs!!!
Have you checked the spool cups?
A groove in the spool cups can make the chatter worse as the uni will run in the groove of the cups...
bjspinner is offline   Reply With Quote
Old 10-25-2011, 05:26 AM   #2126
No hard hits - only barely touched the curb on the inside of the corner a couple of times, but not anything worse than that. The problem wasn't there at all before the 4th run. I have changed the spool cups and even tried a gear-diff.
Niklas Hansen
Old 10-26-2011, 06:22 AM   #2127
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
I looked at the arrow max drive shafts and they look the same as the spec-r shafts. Does anyone have any feedback on these.
sprintcarracer is offline   Reply With Quote
Old 10-26-2011, 06:38 AM   #2128
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Just a thought here, if there is a grinding sound, as you clearly have, something has to be grinding. The should be some sign of wear... Anno wearing off, plastic parts shaving, small bits of metal, somewhere.
I am late to this discussion, but have you swapped out the front CVD's maybe with some from another racer at your track. So you can take your parts out of the equation. Try shorter CVD's just to see if that helps..Maybe pop the shocks off, and run the suspension through it's full stroke,without turning the wheels.. does that cause the chatter too ? Maybe pop the steering linkage off and try steering it manually. Just isolate it down to the smallest denominators.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-26-2011, 12:02 PM   #2129
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Default Need a car to start racing
Should I get the 417 now or wait for the 417X? I will be racing indoor asphalt and carpet. Need a good all around car but not sure if the new chassis will help or impair me.
What should I do?
Racing4Evo is offline   Reply With Quote
Old 10-26-2011, 12:14 PM   #2130
Bad-Andy's Avatar
What should I do?
You are probably going to get a lot of different opinions on this, but depending on the grip level of the carpet track vs the asphalt track and which one you will be racing more on will be the factor.
A lot of time racing on high grip carpet vs asphalt I'd stick w/ the 417. The deep cut outs in the chassis are going to keep me from upgrading mine to an X version since I race on the rug. It just seems like it would flex too much.
If your going to spend more time on asphalt go with the 417X.
Bad-Andy is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
