Like Tree1Likes
Old 10-20-2011, 02:48 PM   #2086
The video probably isn't the best example, as it is at very little throttle. When applying more throttle, it starts at around 50% steering.
I will take a look at it this weekend, and try some of the suggestions in here. Thank you all so far for taking the time to help out. If I can't fix it this weekend, I will make a new video with more throttle applied, so that it is hopefully easier to see the problem.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-20-2011, 05:41 PM   #2087
@Art_Mighty's Avatar
I ran into this same problem on my TA-05 ver.2 Pro. After awhile and I noticed that there was bit of play between the hingepin, and the A-arm. When I installed a fresh A-arm it improved noticeably. I think this occurs because of play either between that pin and the A-arm or somehow the C-Hub is interacting with the two (I'm not sure how).
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 10-20-2011, 05:55 PM   #2088
Trader Rating: 22 (100%+)
[QUOTE=Nilks;9805405]Update:
I tried some different driveshafts and even tried putting the rear driveshafts in the front, with no success at all.
I really don't know what is wrong, but this isn't just normal wheel-chatter. At the end of the straight at my home-track, we have a left sweeper. When I apply steering at the end of the straight, I can feel the car "jumping" (due to vibrations in the front) so it won't steer in properly and it won't brake.
I am about to give up. The car is un-driveable, and I can't figure out why. I wanted to buy the 417X, but that car is probably 2 months away (if we should believe the rumours).[/QUOTE)
Seems normal to me also...
Lift the suspension arm up so as you simulate the arm position at ride height to its position on the track.
The extra droop without the weight of the car on the tires will make the chatter worse...
bjspinner is offline   Reply With Quote
Old 10-20-2011, 11:57 PM   #2089
Tried that - didn't change anything. Plus the problem is also there on the track.
I will probably try new A-arms this weekend. There isn't a lot of play, but I will see if it helps.
Niklas Hansen
Old 10-21-2011, 12:09 AM   #2090
I read about someone having a similar problem in the rear of a 511 and it ended up being a cracked diff bearing holder which is hard to notice. So check the bearing holders that they are in one piece.
Mr_Orange is offline   Reply With Quote
Old 10-21-2011, 12:16 AM   #2091
What is your setup on the front of the car?
If it is narrow/1B and you run longer bones/46mm with alot of camber the bone may be bottoming in the spool cup!
Old 10-21-2011, 01:56 AM   #2092
I also though about the bearing holders, so I tried different holders, with same result.
I run 1C/1C with 44mm. My first thought was exactly camber, but I have tried detaching the camber-link and manually (by hand) adjust the camber, and try different camber settings. That didn't do the trick.
Niklas Hansen
Old 10-21-2011, 05:34 AM   #2093
Blueman Austria's Avatar
Hy there!
A short question for building up dampers. Is it still so that the tamiya team uses the 1mm hole in the cap only on asphalt and not on carpet?
Greetings Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 10-21-2011, 01:16 PM   #2094
wandiez1019's Avatar
Default gear diff....
my gear diff always leaking......how to solve this?
wandiez1019 is offline   Reply With Quote
Old 10-21-2011, 01:19 PM   #2095
Pro10noob's Avatar
Your 417? or other?
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-21-2011, 05:36 PM   #2096
Trader Rating: 30 (97%+)
44mm.
The problem didn't go away with a gear-diff.
It first appeared on my 4th run of the indoor-season. There was nothing in the first 3 runs, but on the 4th it started making some grinding noices. I took it in immediatly, and then I noticed the extreme vibrations.
I had the same problem, and believe it or not it was the rims, they were hitting the arms at full steering, so check the rims, if you removed them and turned the steering and it still does that, then like every one else has suggested replace the front pieces, and see if it is shimed correctly with nothing binding
zaraz is offline   Reply With Quote
Old 10-21-2011, 06:19 PM   #2097
maxepower's Avatar
Is it a Tamiya or SPec. R?
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-21-2011, 06:25 PM   #2098
maxepower's Avatar
Talking Leaking GEAR DIFF.
You can do two things or both.
First you can change the o-ring to a tighter one. Some are using the clear or the blue o-ring that goes inside the Tamiya shocks, and last put that green-slime on the o-ring and outdrive shaft and that should help also. I also put a very thin coat of silicone sealer on the gasket also.
Try these it just might do the trick!
Just my 2$
Old 10-21-2011, 09:08 PM   #2099
[QUOTE=maxepower;9813336]You can do two things or both.
Just my 2$[/QUOT
mine is 417......other things like blue o-ring n silicon sealer i can find but that green slime things......i really don't know what is that......is that also silicon sealer?......thanks in advance for all of the advise.....
Old 10-22-2011, 12:13 AM   #2100
kedal's Avatar
[QUOTE=wandiez1019;9813801]
Just my 2$[/QUOT
Its the famous and magical Associated Green slime. I use it on shocks and Gear diff as maxpower, and works very well.
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
