Like Tree1Likes
Old 10-20-2011, 01:54 AM   #2071
Pro10noob's Avatar
Hmmmmmm wierd
What axle length are you running up front?
Originally Posted by Nilks View Post
Hi,
I have tried with a gear-diff with 500k oil.
Did you have the same problem?
It should have been eliminated with a diff
Downstop has been checked, and we have even tried some extreme downstops (in both directions).
We have also tried with the shocks detached.
That would only give you more chatter
I started on my 4th battery in this indoor season, between two outings. I didn't have a crash. I have just barely touched the inside of a corner on the curb a couple of times, but nothing serious.
After that it started?
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-20-2011, 02:16 AM   #2072
Originally Posted by Pro10noob View Post
Hmmmmmm wierd
44mm.
The problem didn't go away with a gear-diff.
It first appeared on my 4th run of the indoor-season. There was nothing in the first 3 runs, but on the 4th it started making some grinding noices. I took it in immediatly, and then I noticed the extreme vibrations.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-20-2011, 02:25 AM   #2073
Pro10noob's Avatar
Grinding noises sounds like bearings or a CVD that is eating your steering knuckles up.
There isn't a pin that goes true your CVD almost out?
Look for wear and tear there or even a bend axle stub.
Also a damaged spoolcup can do strange things.
It it deffo somewhere in the drive train.
As a diff would have eliminate chatter.
regards Roy
44mm.
l===/o\===l
Old 10-20-2011, 02:38 AM   #2074
regards Roy
Bearings have been changed, and the CVD's have been renovated, and I even tried some other ones. Didn't help.
Spool-cups have been changed - same issue.
Niklas Hansen
Old 10-20-2011, 02:47 AM   #2075
Pro10noob's Avatar
Now without a clue
regards
l===/o\===l
Old 10-20-2011, 04:13 AM   #2076
Trader Rating: 69 (100%+)
Is your front drive shaft rubbing the stabilizer by any chance? I find out that certain setting the drive shaft might come in contact with the front stabilizer.
eComet is offline   Reply With Quote
Old 10-20-2011, 04:25 AM   #2077
Pro10noob's Avatar
Forgot to ask you something.
How are the front arms shimmed??
Are they tight to the rear or to the front?
Or just in the middle?.
regards Roy
l===/o\===l
Old 10-20-2011, 04:38 AM   #2078
I can see on the driveshaft, that it does touch sometimes, but I have tried manually pushing it away, and that didn't help.
regards Roy
I don't have the car in front of me right now - I will check when I get home from work tonight.
Niklas Hansen
Old 10-20-2011, 05:24 AM   #2079
halim6's Avatar
Send a message via MSN to halim6 Send a message via Yahoo to halim6
Nilks, check also your spool bearing holder. Should be round dot up and triangle down, position should also be same left and right.
>> RIGHT TO RACE <<
** This is my HOBBY. It's all about having FUN, and it's my ultimate STRESS Reliever!! **
halim6 is offline   Reply With Quote
Old 10-20-2011, 06:43 AM   #2080
hacker's Avatar
Trader Rating: 140 (100%+)
besides xenon, would this duratrax and hpi spur fit? Not usually my first choice of spurs, but I need to make an order soon and don't have the car.
are there any other brands that fit the 417?
looking at the manual, it looks like you need holes at the 12,3,6 & 9 o'clock positions.
hacker is offline   Reply With Quote
Old 10-20-2011, 07:48 AM   #2081
Try these, specifically the V2. They have holes that allow you to access both motor screws (90 tooth+).
http://www.speedtechrc.com/store/ebp...d=392&id=11479.
malkiy is offline   Reply With Quote
Old 10-20-2011, 08:20 AM   #2082
Trader Rating: 27 (100%+)
I am currently using a Xenon 88T 64P spur/44T pinion on my 417. All I did was drill two more holes in the spur gear and it's fine. I also got the motor mount milled out so I can have more adjustments to run 17.5...sweet~!
JoeyE is offline   Reply With Quote
Old 10-20-2011, 09:53 AM   #2083
artwork's Avatar
Trader Rating: 62 (100%+)
Have you tried a ball diff up front to see if it helps...I suspect it wont but is something very easy to try. Also another good idea is to try a new front belt and ensure that the pullies are clear of debris.
Make sure the screws that going into the steering blocks are not too long and hitting the axle.
You have to isolate the issue...rule out one thing then move to the next.
I personally think based on the video...that you are trying to use entirely too much steering, and hitting the natural limitations of a traditional CVA. Just go buy some Xray or Hot bodies double joint universals and make them fit.
I have run on a lot of different surfaces and have never had the issues you are trying to overcome. Just not sure what to tell you anymore. There are a lot of people around the world that seem to be able to make this car work just fine without any modifications.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 10-20-2011, 10:03 AM   #2084
artwork's Avatar
RW racing ultralight spur gears work the best in my testing and running. I think they fit perfectly and have holes to access the motor screws. They are also very quite...
Old 10-20-2011, 11:53 AM   #2085
infokiz's Avatar
After watching the video that is totally normal with that much steering throw the universals are at there max and binding up. You would need to get some of the spec-R double joint ones or wait till tamiya comes out with there own. At the IIC Viktor and Marc were testing some tamiya prototypes.
infokiz is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
