Old 10-18-2011, 09:51 AM   #2041
Hi to all. Help me choose a gear diff! I have a sakura gear diff v1, but the gears inside the differential wear quickly, and o-rings tight, so the differential works tight even with a small value of density!
Is sakura diff V2 is better than V1 ? Or better use the tamyia gear diff v2?
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 10-18-2011, 10:45 AM   #2042
Pro10noob's Avatar
Use the Tamiya V2 diff.
Shim on both sides with 3 shims and use the supplied oil.
After running in it is smooth as butter.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-19-2011, 03:33 AM   #2043
chrisk's Avatar
Trader Rating: 32 (100%+)
Any idea yet on an upgrade pack ie: top & bottom deck & towers and motor mount?
Will they be sold seperate from the complete car?
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 10-19-2011, 06:43 AM   #2044
artwork's Avatar
Trader Rating: 56 (100%+)
I seriously doubt that Tamiya will release an upgrade kit to a 417X...I am sure it will be a new car only, based on the pics from the Tokyo Hobby show.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 10-19-2011, 07:51 AM   #2045
John.C's Avatar
Trader Rating: 36 (100%+)
I agree that Tamiya most likely won't offer an 'upgrade package'. That being said, Tamiya will offer each part/component individually. This is supported by the fact that every part for a TRF417 is currently available for sale. You'll just have to determine if the total cost (will be high) of purchasing the items individually is worth it.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-19-2011, 07:55 AM   #2046
GeorgePravata's Avatar
Trader Rating: 106 (100%+)
is that going to be a chassis for carpet..
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 10-19-2011, 09:58 AM   #2047
Truth is though, not many of the tweaks are essential maybe the bottom plate if you want more flex and have already cut the motor mount and top deck.
The mods just make the car more tuneable, and easier to adapt to different circuits. If you have sorted the car for your own track you won't go quicker unless you need even more flex than the cut mount, split blocks and cut top deck already give you.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 10-19-2011, 10:33 AM   #2048
John.C's Avatar
Agreed! It just so happens that I like all of the upgrades/changes that they've made to the new car. I even like the metal battery holders. I know some drivers didn't use the CF types on their 417 but the new metal types looks great. I don't know if I'll be any quicker with the new car but the idea that it 'may' and the excitement of building a new kit are good enough reasons for me to upgrade.
Old 10-19-2011, 10:39 AM   #2049
So can some body tell me if the new trf417x is going to be for carpet with the new changes
Old 10-19-2011, 10:40 AM   #2050
TryHard's Avatar
I do agree with this to an extent... but I've found recently that my car is faster on high grip asphalt surfaces as well as low to medium grip, with all the flex dialled in... and that does include the split blocks.
I know Jilles and the gang all used the "flexy" options at the Euro's a while back, and that was traction rolling grip levels.
It maybe that carpet results in a different effect on the grip level, where less flex helps to "un-bind" the car, but tbh I still reckon a X will be just as good on the rug... maybe more tricky to drive, but faster.
HiH
Ed
Old 10-19-2011, 10:57 AM   #2051
John.C's Avatar
I haven't read or heard of the 417X or any of the revised parts as being designed specifically for carpet. In a traditional sense carpet specific chassis are thicker resulting in a stiffer car. I don't believe the revised chassis is thicker and/or stiffer. As Ed and others have mentioned the new chassis and motor mount provides more flex. Since I've never run TC on carpet I don't know if that is a good or bad thing. Good news is a new carpet track opened up so I'll have all winter to figure it out.
Old 10-19-2011, 11:00 AM   #2052
Nice we just had a new track open for us race at. My TRF417 was way out to lunch. it was so bad I got sea sick...
Old 10-19-2011, 12:08 PM   #2053
John.C's Avatar
= for a new carpet track opening up near you
= for the 417 not working so well
I'm going to run both cars when I get the X to see what works better. For me it's about getting the car easier to drive which results in faster and consistent lap times.
I'll catch up with you at Jackson come Spring/Summer. The X should be right at home there.
Old 10-19-2011, 01:00 PM   #2054
yeah can you say way out to lunch with it.. I almost picked up a tc6
Old 10-19-2011, 01:05 PM   #2055
artwork's Avatar
What setup are you running...I posted one recently that works very well anywhere I go. The car works very well on carpet....
http://linewerx.com/Linewerx/Racing_...IIC%202011.pdf
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
