Old 10-12-2011, 12:31 PM   #2011
transplantlife's Avatar
Trader Rating: 43 (98%+)
Originally Posted by infokiz View Post
I hope they sell an upgrade kit for regular 417's as I just purchased one a month ago.
+1
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 10-13-2011, 09:51 PM   #2012
Trader Rating: 69 (100%+)
Pictures from 2011 Tokyo Hobby Show:
Courtesy of www.hobby-show.info
eComet is offline   Reply With Quote
Old 10-13-2011, 10:01 PM   #2013
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
i just wet my pants...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 10-14-2011, 12:07 AM   #2014
TryHard's Avatar
I'm really interested to see how that motor mount cross piece mounts... as there aren't any extra screw holes in the chassis plate, yet you can see the thread in the cross piece and mounts... Wonder if it's a counter sunk screw in the mount, then onto the chassis.
Old 10-14-2011, 07:29 AM   #2015
hana166's Avatar
Its gotta be. North/South mount a lot easier to deal with too
hana166 is offline   Reply With Quote
Old 10-14-2011, 07:46 AM   #2016
Hi guys,
I hope some of you experts can help me a bit with my 417.
When applying 50+% steering, I get some weird grinding noices and a lot of vibrations. It is not the normal spool wheel chatter, but it is a lot more violent. The problem is also present with a geardiff.
I have changed steering knuckles, C-hubs, wheel hexes, wheel axles (51445), and probably more that I've forgotten. The problem is, as far as I can see, in the front, as I have tried removing the belt and turning the wheels by hand, without improvement. I have tried removing the dampers, and detaching the steering and the camber links. No improvements.
I recorded it, so you can see it yourself:
+ YouTube Video
I hope someone knows about the problem, or can see it from the video. I have had 3 different Tamiya-drivers looking at my car, and no-one can find the problem.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-14-2011, 07:59 AM   #2017
Maybe your rims (inside ribs) rubbing against the arms?
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 10-14-2011, 08:08 AM   #2018
artwork's Avatar
Trader Rating: 54 (100%+)
Originally Posted by Nilks View Post
Hi guys,
+ YouTube Video
Have you tried replacing your front axle, cross joint, and swing shaft assembly and replacing the plastic spool cups? It is clearly binding up at sharper angles causing the wheels to hop and vibrate. Over time these parts start to dry out and bind-up more often. I check and relube the front drive train about once a week to ensure smooth operation. Last time I had an issue like this it was the spool cups. Replacing them fixed the problem.
Car sounds smooth when going straight so I would assume that nothing is stuck in the teeth of the pullies.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 10-14-2011, 10:11 AM   #2019
That was my first though, but that is not the case.
I have tried with a completely different (but older, so that might have the same problem) driveshaft. I will try with two driveshafts I know work tomorrow. I don't think it is the spool cups, as I also have the problem with a geardiff.
Niklas Hansen
Old 10-14-2011, 10:17 AM   #2020
Pro10noob's Avatar
Perhaps a silly question from my side.....But perhaps the drive shafts are to long?
Then when turning they push against de rear of the spoolcup and that causes the vibrations?
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-14-2011, 10:31 AM   #2021
steveonamission's Avatar
That's normal chatter off load, always will have vibration at more extreme steering angles due the nature of the spool and standard CVD shafts.
Most touring cars have it, unless they are running double joint driveshafts.
steveonamission is offline   Reply With Quote
Old 10-14-2011, 11:07 AM   #2022
MikeR's Avatar
Trader Rating: 14 (100%+)
+1 Spot on. Chatter is amplified when the car/tires sits in the air.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-14-2011, 11:46 AM   #2023
44mm - like the stock driveshafts. Just steel.
The problem (the noise at least - can't see about the chatter) exists on the track also. It sounds very violently, and none of the other 417's sounds like that. The problem just started from one battery to another. And it didn't push the throttle on that video - it gets a lot worse when applying more throttle.
Niklas Hansen
Old 10-14-2011, 01:28 PM   #2024
theatriks's Avatar
Hi guys,
+ YouTube Video
Lower your epa on your transmitter and see if it still happens
theatriks is offline   Reply With Quote
Old 10-14-2011, 01:28 PM   #2025
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by RC.Jon22 View Post
So how many of you guys will be switching over to the 2012 417? I've been loving my regular 417, wondering if the new changes will be good on all tracks..
I'm gonna sell mine and revive the 416WE with the LiPo chassis. And then only for high bite.
syndr0me is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
