Old 09-29-2011, 11:54 PM   #1951
crabboy's Avatar
Trader Rating: 58 (98%+)
Hi Guys, i always like to see pics of other guys cars so i thought i would post a couple of mine.
As you can see i have done the chassis mods (well most any way) also cut the top deck, motor mount, running split blocks, theres a lot of weight on the car as the weight limit for the event was 1450g , i was running the Arrowmax drive shafts but the grub screws come out twice so i put them away for another day, also to make the car look a bit different i put on white wire and ball cups.
The biggest problem i seem to be having is with the Tamiya V2 diff, the 3 shims in the diff start to cone where the gears start to push the shims against the o ring and in turn starts to make the diff feel notchy, and its hard to try to buy the shims.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 09-30-2011, 12:01 AM   #1952
TryHard's Avatar
Rhys
Have you been sanding the back surface of the gears as well, until all flat? Thats the advise Jilles gave... and I'll be trying out for myself soon.
Actually got a bit of an abundance of diff's at the momenet, as two v2's turned up today (although sure I only ordered one!), to go with the three I have from Spec-R! oops!
Oh well, will be good to have a comparison, I've got the Spec-r's running pretty well
Ed
Old 09-30-2011, 12:42 AM   #1953
crabboy's Avatar
Hey Ed, Yeah i sand the gears, but you use 3 x.1mm shims on each side behind the gears, and when the gears are running they push towards the out drives and tend to cone the washers, i spose the best thing to do is run yours for a day then take it apart and check the shims, im sure you will find they are coned slightly, more so the shim next to the O ring.
I have run the Spec R diffs with no probs except for a bit of oil leaking out.
The new Spec R drive shafts look good with the clips instead of the grub screws.
Rhys
Rhys Marshall.
Old 09-30-2011, 01:25 AM   #1954
hana166's Avatar
Originally Posted by TryHard View Post
So... also looks like you can run a jointed and cut motor mount by removing the insert (look closely at pics on Kentech's blog)... Like it, will be a new car for me soon then!
Ed
Had to look very closely. Looks like it screws in from underneath. That is a really clever, neat solution.
It'd be great to get the new car, of course, but
with a little handy Dremel work and purchasing only the new mount (+ poss shock towers) its viable to upgrade the old car without breaking the bank
hana166 is offline   Reply With Quote
Old 09-30-2011, 01:34 AM   #1955
TryHard's Avatar
Yup, compare that to the new Xray 2012 that's just been announced....
NEW chassis designs
NEW redesigned top deck
NEW front shock tower
NEW rear shock tower
NEW upper bulkheads
NEW gear differential
NEW steering blocks
NEW servo saver
NEW ball joints
NEW servo position
NEW optimized shock positions
NEW optimized chassis flex
NEW roll center positions
After all those years of "optimising" still not managed it....
Old 09-30-2011, 01:58 AM   #1956
hana166's Avatar
NEW chassis designs
NEW upper bulkheads
NEW steering blocks
NEW servo saver
NEW ball joints
NEW servo position
So basically, for more money, (+60GBP alloy shocks eh?) you can have a copy of a Tamiya
Old 09-30-2011, 02:01 AM   #1957
chrisk's Avatar
Trader Rating: 32 (100%+)
Cant wait for the new mount, will help with achieving the right FDR for 21.5 blinky i am running. Cant get it with the current mount without modifying.
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 09-30-2011, 07:34 AM   #1958
yup it looks like it would be cheap to upgrade. The motor mount isnt really needed for anyone who has found a cut mount to be better and doenst need to adjust it to run a different gear range (why would you run it locked, if after you had cut one it ran better). Although if you travel tolots of circuits it is great to be able to choose if you want it split or not.
The other upgrades are very minor, I already have a cut top deck.
Its a nice set of refinements, and if a part breaks etc I will update to the newer parts, just goes to show how good the car is already.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-30-2011, 02:22 PM   #1959
Red face
i'm sorry guys, i must be a little slow. i've looked & looked but can't find any pictures of the cut motor mount,steering rack ,etc. can someone please put it up here so i can just click on it. thanks
S411LE#63,eryx 2.0,kyosho ultima sc,B44.1,futaba.the short list. Ricky Bobby body club,member #4
atmeearacing is offline   Reply With Quote
Old 09-30-2011, 02:59 PM   #1960
in 3-6 months xray will have another new car out. still with plastic shocks
Old 10-01-2011, 03:56 AM   #1961
TryHard's Avatar
Here's some pics of my steering setup.
First two pictures show how much servo horn cant I use... a fair bit more than the manual 5. Also shows that I move the servo 1mm forward (shims between the servo and servo mounts second picture), and I also push the ball joint on the servo horn forward an extra 1mm. This helps to make the drag link straight at full lock, for a little better resolution of the steering.
Under the ball joint on the steering cross brace, I use a 2mm shim (different to the manual 1mm), as this means you can get full lock on the steering, as the ball joint doesn't protrude underneath the cross brace, hitting the bell cranks at full lock.
Next two pics show the link lengths I use. The drag link length is from the middle of the ball joints, as I've had to trim the ball cups.
Last picture shows the angle of the steering using the setup gauges. Just push the toe-plate all the right. Using the previous method for setting up the steering, I get 25 showing on the plate each side. Because the toe plate isn't perpendicular to the car, that translates into much more real overall wheel angle.
HiH
Ed
Tamiya TRF417-overall-steering.jpg   Tamiya TRF417-overall-steering-2.jpg   Tamiya TRF417-toe-link-length.jpg   Tamiya TRF417-drag-link-length.jpg   Tamiya TRF417-steering-angle-setting.jpg
Old 10-01-2011, 10:30 AM   #1962
jonest's Avatar
Ed,
Do you have any issue with the shocks?
The piston on mine needs to be replaced quite often (2 race old)... otherwise it run out of shape.... and my spool cup too.....needs to be replaced frequently. though running on 10.5t only.
jonest is offline   Reply With Quote
Old 10-01-2011, 11:41 AM   #1963
Smile
tryhard, thanks a ton.very cool, great pictures,descriptions. funny how a picture tells a thousand words. anyone got something on the motor mount?
Old 10-01-2011, 11:55 AM   #1964
FunkyDunky's Avatar
HiH
Ed
Cheers Ed
This is great and very helpful, also also have the same issue with uneven steering lock and this will help resolve me issues!!
Cheers
FunkyDunky is offline   Reply With Quote
Old 10-02-2011, 05:16 AM   #1965
TryHard's Avatar
Originally Posted by jonest View Post
Ed,
Spool cups... Ditch the plastic ones and get hold of a set of Roche spring steel ones. I've been running them for a while now, and even having been running only modified, they have zero wear. Very impressed.
As for the pistons... Don't push too hard on them when you put the c-clip on. There ain't a huge amount of material outside the holes, so very easy too deform them if you press down on the piston trying to squeeze on the clip
Otherwise, stop hitting stuff
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
