Like Tree1Likes
Old 09-20-2011, 08:19 AM   #1921
Originally Posted by RL.2002 View Post
the white n blue spring was included in the box with the kit if you buy 1st hand
only in the 1st gen 417. 2nd gen doesn't include them.
the greek is offline   Reply With Quote
Old 09-21-2011, 10:23 AM   #1922
Starteur's Avatar
I had a little mishap with the boards, bent my 1XA block
Can I run split 1XA blocks in the front portion of the rear of the car?
I know some guys run them in the rear portion of the front of the car for strenght but I would like to do the same for the rear.
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 09-21-2011, 12:29 PM   #1923
CL
CL's Avatar
Trader Rating: 32 (100%+)
Yes.
More racing and less typing!
CL is offline   Reply With Quote
Old 09-21-2011, 05:01 PM   #1924
maxepower's Avatar
Talking "Split blocks, tuning feature"
I was told by a reliable source that using split blocks in the back will increase rear grip because the split blocks allow the chassis to flex more in the back! FYI
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-21-2011, 07:59 PM   #1925
transplantlife's Avatar
Trader Rating: 43 (98%+)
Just my 2$
+1 i use split blocks in front and felt it gave the car more steering
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-24-2011, 11:16 AM   #1926
I have moved across to using split blocks in the front and rear (1C and 1XA) and the car felt much better with foams on carpet. So good in fact that I won the A final.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-24-2011, 01:00 PM   #1927
Starteur's Avatar
Thanks a lot guys .
I'll be runing them front and back!
Regards
Old 09-26-2011, 02:06 PM   #1928
Hi there,
I finished assembling my new trf417 and I have few questions:
1. Regarding the steering, even though I adjusted the adjustment rod to the exact same measurements, I can still see that the right wheel is a little bit more to the right than the left wheel. Has anyone had the same issue and had to make one rod longer to fix it? Also, even though the servo was exactly at neutral at the time I installed the handle but i still had to trim a lot for the wheels to point straight, and again that was following the manual's measurements. Is that normal?
2. I noticed that the rear wheels wiggle a little bit, I am not sure if it's the wheel itself that is not a perfect disk or something else. Should I worry about?
3. Finally, I had to install around 3 0.1mm shims on the rear wheels because the axis was playing a it, I was able to wiggle it in and out without the shims. Should I keep them?
Sorry my questions are basic, but I am relatively new to this hobby.
halayli is offline   Reply With Quote
Old 09-26-2011, 04:25 PM   #1929
Send a message via ICQ to rcnewb2004
Hi Halayli,
I am not an expert here and haven't built a trf417 before (i have built a 3 tamiya cars before though), anyways here are my suggestions (please correct me if i am wrong other more knowledgeable forum members):
1. Use calipers to check that your rods are the same length from center of the ball cup to center of the ball cup. Sometimes I also check by eye, but quickly counting the threads (if there are not too many) u should be within 1 thread.
2. I do not know how much wriggle there is based on ur description but a bit of "wriggle room" is always designed in RC cars because it allows the parts to give a little when under a crash. If there is no give, parts could break more easily. Check the manual if u have forgotten any parts if there is too much play and ofcourse you can progressively shim more and more until you feel the car responds well to your shimming.
3. I am not too sure what you are describing here, but make sure that the "hexagon" indent at the center of the wheel fits perfectly over the hexagon hub and that you have tightened the nut (which holds the wheel against the hub) properly.
if you are referring to the axles themselves having a tiny bit of play longitudinally, they are suppose to allow for suspension travel. The axles may "tilt" to compensate.
(I hope I am being clear... but I am running on 3 hrs of sleep).
Hope that helps.
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 09-27-2011, 12:34 AM   #1930
Originally Posted by rcnewb2004 View Post
Hi Halayli,
Hope that helps.
Thanks for your detailed response!
1. Yes I used calipers to check the length. I am measuring from the inner edge of each adjuster, according to the picture, the gap between the adjusters should be 28.3mm but the only way I got the two wheels to point at the same angle was to have one at 28.3 and the other at 30.8. Which is odd.
2. It's a little bit of wriggle I guess I can ignore it for now as you said a bit of wriggle room is intentional.
3. Yes, I made sure the hexagon indent at the center of the wheel, but I think the wheels are not 100% perfectly circled. On the other hand, I had to add more shims than mentioned in the manual between the small shaft and the wheel axle so that the wheel axle doesn't move in and out a lot.
Basically, I don't know if my adjustments outside of whats mentioned in the manual is normal thing to do when setting up the car (like in 1.)
Old 09-27-2011, 12:56 AM   #1931
TryHard's Avatar
Hi Halayi,
In response to your questions;
Originally Posted by halayli View Post
Hi there,
Personally, I ignore the instructions when it comes to setting up the steering, more than anything because some servo's put the spline further away from the centre of the car than others, meaning the link will always be off. I also cant the horn over more than the manual says, so to make the horn and link at a perpendicular angle when in the centre. This (if i recall rightly) makes the link a lot shorter, so much so trimming the ball cups is needed, but does give equal L-R steering. Takes a bit of time to setup, but once done, the EPA's on the handset rarely need more than a few % difference.
Don't worry about using a lot of trim to get it right (as long as it is sub-trim), IMO it's more important to get the locks right side to side, and this will require some fiddling with the links and sub trim to get right.
I'll try and hunt down the post somewhere of the method I use... thought I had it too hand, but it might be in the 416 thread tbh, need to go looking!
Pretty normal, I wouldn't worry too much unless it's causing a very big vibration at speed.
If I remember right, I use 0.2mm shims on the axles to help reduce play. But you don't want to shim all the play out, as that can cause binding as well... a bit of play means it's free, which also means it's fast (to a point obviously!)
No problem at all, it's what we're here for
Old 09-27-2011, 01:40 AM   #1932
TryHard's Avatar
Couldn't find my old post on here... so put one up on my site instead, least will make it easier to remember where it is!!
http://www.thard.co.uk/viewtopic.php?f=49&t=464
Regards
Ed
Old 09-27-2011, 07:22 PM   #1933
Regards
Ed
Thanks a lot for the detailed explanation and the link, very helpful ... I'll follow the instructions and let you know if it didn't work out
Old 09-28-2011, 12:09 AM   #1934
Cool
Ok so here's the problem I am facing, no matter what I do, unless I change the link attachment on the right to be longer, the right wheel will always point outward more than the left as shown in the picture attached.
I am 100% sure that the link attachments are exactly the same length as I have measured them several times using a caliper and I also tried to swap them with no difference.
Logically the link attachments must be the same length. Any suggestions to solve this issue?
Old 09-28-2011, 12:31 AM   #1935
TryHard's Avatar
Firstly... put the links on the rear holes on the hubs... this will make the steering better, trust me
Next, with the links the same lengths... adjust your servo sub-trim on your transmitter so the steering is in the middle. If the horn cants more towards the centre of the car, don't worry.
The other option is to length the link between the servo horn and the steering, so it becomes more central.
You can actually see in that shot that the bell-cranks are pointing to the left of the car, hence why it looks like the right wheel is steering more to the right.
Just have a play around with it, and get a feel for what adjusting each thing does to the steering.
This weekend I'm on holiday, so I'll try and add some pics to the guide to help.
Regards
Ed
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
