Old 09-07-2011, 09:12 PM   #1876
infokiz's Avatar
Originally Posted by MDRTales View Post
I have a problem with the steering screws that hold the steering bridge to the arms in where the right one would just work itself loose,and I built per kit instructions?
Just put some medium loctite on the screw if you don't have that try some white glue. that is totally normal when you screw metal in to metal.
infokiz is offline   Reply With Quote
Old 09-07-2011, 09:59 PM   #1877
spring71's Avatar
Smile
Hello guys,
We have indoor carpet track in Chino CA.
Annual Radiopost Grand Prix will be held on Sept. 25th.
If you guys plan to go to IIC, it will be a great IIC Warmup race.
Also, Click Here to visit the Tamiya 417 Parts Store.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 09-07-2011, 10:25 PM   #1878
transplantlife's Avatar
Trader Rating: 43 (98%+)
Anyone know if i can fit the 416 motor mount on the 417 chassis? Thanks
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-07-2011, 10:35 PM   #1879
i'm pretty sure you can't
platypus_s13 is offline   Reply With Quote
Old 09-07-2011, 10:41 PM   #1880
ok thanks for the reply guess i'll jus cut the motor mount
Old 09-08-2011, 12:37 PM   #1881
Starteur's Avatar
Originally Posted by Starteur View Post
Another question:
Why are the B4's banned from TCS Racing????
Anybody???????
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 09-08-2011, 03:22 PM   #1882
Tron's Avatar
Trader Rating: 16 (100%+)
Anybody???????
It is explained in the TCS rules.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 09-08-2011, 09:41 PM   #1883
Pro10noob's Avatar
Perhaps they are not as realistic as the normall TC or GT bodies from Tamiya?
Don't know the rules tho.
Or perhaps it is it's availebility?
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-09-2011, 01:40 AM   #1884
The B4 is an aero shell, not a scale shell. That is why it is not allowed. It would be unfair to use this shell as I was built as a racing wing with just a nod to a real car.
If you would allow this shell then everyone would use them, and you would have lost the whole identity of scale racing which the tamiyacup promotes.
Also re cutting the mount, try the car first without doing it before deciding if you need to cut it.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-09-2011, 07:02 AM   #1885
i agree..
proampsmalaysia is offline   Reply With Quote
Old 09-10-2011, 08:38 AM   #1886
onekiwi's Avatar
Hi all
My first onroad car and its a 416we couldn't see the original thread and thought that most here would have started with the 416 anyway.
My question is do I need to have the servo saver or can I just use a alu arm?
I ask this as I have tried with the arm and it seems to turn more one way than the other, and I probably shouldn't have a huge difference in EPAs
Does the supplied servo saver solve this?
If so then how do I put it together?
Do I need 3 metal rings?
I think I have 3 gold coloured ones (the same size) and one black one (larger) is it just a gold one and a black one or do I open up a gold one as well?
onekiwi is offline   Reply With Quote
Old 09-10-2011, 12:35 PM   #1887
You need to have the arm slightly off from centre leaning towards the middle of the car. It still might not be perfectly centred but it should be close.
I wouldn't use a tamiya servo saver, use a kimborough type as tamiya ones come loose quickly. Most racers use alloy arms, as long as you are confident of not hitting barriers and have a good servo.
Old 09-11-2011, 01:59 PM   #1888
So I ran my 417 on carpet for the first time since Winter...
Handling wise the car was pretty decent however I had a few problems.
I was using Jaco Blue tires(old ones that a friend of mine had) and the traction was lower with those tires compared to my usual. That being said the biggest problem was actually the rims fitting the hex. I stripped two wheel hexes out as it seems the hex on the jaco rim are too big for the tamiya? There was slop and eventually they let go. Anyone know if this was a problem with Jaco tires of old? I worry as this is the hand out tire for the IIC...
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 09-11-2011, 05:21 PM   #1889
Vicko's Avatar
Trader Rating: 14 (100%+)
How old are the rims? I been runnnig Blues for the last 2 years and never had it issue with my 416 or 417
Vicko is offline   Reply With Quote
Old 09-11-2011, 05:45 PM   #1890
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
The old Jaco rims had some issues, there newer ones are ribbed around the hex for more strength.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
