Like Tree1Likes
Old 09-04-2011, 09:59 AM   #1861
maxepower's Avatar
Exclamation "The Body of Choice"
Originally Posted by Starteur View Post
Here's a quick one for you guys:
What is the best Tamiya body to run in Sedan or GT1??
Was going to run B4 but it is discontinued!
Regards
(TCS Legal) 2005 NSX with High Downforce option wing!
Non-Tamiya Protoform Mazdaspeed
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-04-2011, 08:00 PM   #1862
TryHard's Avatar
Hey all,
The past few weekends I've been off practising hard in preparation for the Hobbywing Cup in a few weeks. Pretty much the unoffical chinese nationals, with drivers coming from all over the country to compete, so it's going to be pretty big event.
Anyway, been running through a lot of different combinations of setups, and thought I'd share some more of my findings...
Cut top deck and no steering brace are working great. Gives more rear traction, which is perfect for modified. Still yet to try the split blocks (can't find 1XA's for the life of me anywhere!), but the car is working very well in this configuration.
Wheelbase back is also another thing that has helped, simply gives more steering. Using 0.5mm behind the front arm, and 3.5mm in front of the rear (like Marc and Jilles at the ETS), and also 1.5mm on the ackerman spacer. Simply gets through the turn better, without being unstable.
Lowering the inner camber links has also given a better feel, with better corner speed (4mmF, 3mmR), although this may be more track specific... there are a few long turns on the track at the moment that mean corner speed is key.
Drag brake... best find of the day was going from 5% to 10% drag brake on the speedo. Made the whole run much more consistent, and I could happily nail the tricky tightening first turn much easier with no stepping out
I've been playing around with a lot of different settings on the rear to try and get the rotation I want as well. With the almost standard rear setup (0.5mm suspension block shims, 1XA/1E, middle hole 3mm camber link, hole 2 shock tower), the rear of the car just didn't rotate enough in the middle, so losing time waiting to get on the throttle.
Started out by raising the rear block using 0.7mm shims, and going to 4mm on the camber link, but keeping everything else the same. It was better, with but a little too unstable on the rear if pushed too hard. Traction was good however, so I made a slight change mid-run to 3.5mm on the rear camber link, which again was close, but still not quite there.
Next run I tried out 1mm on the suspension blocks (bearing in mind the fronts are on the chassis, which is probably as big a split as I'd ever want to run) with 4mm under the camber link. Now the balance was really good, and at the start I thought great, got the setup I want... until about 4mins in when the rears started to overheat By the end of 8mins, it was very difficult to drive, so losing all the benefit of the start of the run. Honestly, I'm not too surprised, as the difference in terms of front and rear roll centre is probably too big, and leads to working the rears too hard. Forward traction was very good though...
Next run, went back to 0.5mm blocks (in an effort to keep the F-R diff smaller), 3mm on the camber link, and hole 1 on the rear tower... Again a little loose, so mid run change to 3.5mm camber link, and spot on. Stayed consistent for the rest of the run, and the whole of the next.
Also found some good things in terms of additive, but I'm keeping that under my hat until the race meeting
Overall, very happy... feel I'm getting more and more out of the car at the moment, and just getting quicker. Shooting for the A at the HW Cup... will be tough, but should be able to do it!
Regards
Ed
Old 09-04-2011, 09:54 PM   #1863
stitchy's Avatar
Regards
They are available here in the US. (I'm guessing you aren't?) I can get you some B4 bodies if you like...
I know you're in China but in case you were desperate, we have them
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 09-05-2011, 08:12 AM   #1864
Starteur's Avatar
I don'r see any on your site?
Send me PM about price and shipping cost via USPS.
If you need extra infos like a postal code etc.... PM me
Thank you
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 09-05-2011, 09:31 AM   #1865
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www.tamiyausa.com/announcement.php
Sweet, they're probably announcing a new plastic tank.
syndr0me is offline   Reply With Quote
Old 09-05-2011, 10:11 AM   #1866
transplantlife's Avatar
Trader Rating: 43 (98%+)
yea i wonder what it could be maybe a updated website
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-05-2011, 12:45 PM   #1867
Trader Rating: 22 (100%+)
New Partnerhip?
Does someone's partner need a hip replacement.
Thats funny hope they spellcheck it if is a new website.
bjspinner is offline   Reply With Quote
Old 09-05-2011, 02:15 PM   #1868
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Default 417 thrust bearing size
hey does anyone know the actual size of the thrust bearing balls for the 417 ball diff, are they 1/16 or 3/32
bozzplayer is offline   Reply With Quote
Old 09-05-2011, 07:03 PM   #1869
chrisk's Avatar
New Partnerhip?
well the timer stopped and it says END, nothing has happened yet
a little bit like the year 2000 alot of hype and NOTHING!
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 09-05-2011, 08:37 PM   #1870
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Thank you
I have one those B4 NIP ...pm back ..Thanks
OVA is offline   Reply With Quote
Old 09-06-2011, 01:38 AM   #1871
Send a message via Skype™ to flyfish
want to see more pics
flyfish is offline   Reply With Quote
Old 09-06-2011, 10:07 AM   #1872
Starteur's Avatar
Another question:
Why are the B4's banned from TCS Racing????
Old 09-06-2011, 10:11 PM   #1873
syndr0me's Avatar
So the big announcement was a...
wall hugging mouse?
Old 09-06-2011, 10:38 PM   #1874
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
New website layout or something....what a joke.
Dan is offline   Reply With Quote
Old 09-07-2011, 08:46 PM   #1875
I have a problem with the steering screws that hold the steering bridge to the arms in where the right one would just work itself loose,and I built per kit instructions?
MDRTales is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
CL
