Old 08-22-2011, 12:28 AM   #1831
I use the square 416 bumper guard on my car (tight indoor carpet track). Its pretty good at stopping and breakages at the front end.
The ta05 plastic hubs are ok if you are running 13.5t or below you just wont get the speed necessary to incur flex. I have used both and not noticed any difference in lap times.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 08-22-2011, 12:36 AM   #1832
TryHard's Avatar
Originally Posted by syndr0me View Post
So you guys won't run aluminum c-hubs 'cause you're scared they might bend, but you're okay running the rubber TA05 bits that flex 20 degrees with no load at all?
Absolutely! at least I know there flexing ... whereas with the alloy, I have had it before where it's been bloody difficult to see any bend until stripping them off the car.
At least with a plastic, if it's broke, you know about it
Having said that, never tried the Parma T2 bumper solution, although the carbon c-hubs are a lot more beefy than they used to be as well, so probably the bumper would be fine.
Anyway, on another point, I've finally got round to updating the 417 things to know list on my massively neglected site... I promise I'm going to try and keep it a bit more updated, I've got plenty of setups I need to put up there as well! If anyone's got any other tips, feel free to add them in!
Regards
Ed
Old 08-22-2011, 02:48 AM   #1833
Jack2's Avatar
Originally Posted by Damnit Man View Post
I would be happy with something in the middle of the stock reinforced piece and the way too flexible piece. Since that is not available, I am open to ideas. Where can I find the "Square aluminum c-hubs" from? I thought the front bumper was already hard compared to my previous experience with the hard front bumper I had on my t3'11s, but I will go ahead an pick up a Parma bumper and try it out. Maybe the harder bumper is all that is needed?
earlier in this thread i posted up my findings running EVO hub carriers, which are made from a less fragile plastic, but much beefier in design so they dont flex.
i had to remove .7mm of material at the top under side and run the king pin/spacer different to factory to correct roll centre.
the EVO hubs are like 3 bux and are very durable. i modded 3 pairs but have yet to go thru the first pair. I also ran them with modded 416 knuckles, i had to dremel them out to accept the 417 clip pin cvd's. ended up with a cheap as chips setup that doesnt flex and carry on and its tuff.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 08-23-2011, 02:06 PM   #1834
stitchy's Avatar
417 w/gear diffs back in stock!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 08-23-2011, 03:17 PM   #1835
stitchy's Avatar
417 gear diff pulley cases and outdrives too....
Old 08-29-2011, 07:35 AM   #1836
Thank you for posting this however it seems the setup doesn't include all the information? Shocks and such aren't filled out?
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 08-29-2011, 07:50 AM   #1837
transplantlife's Avatar
Trader Rating: 43 (98%+)
+1
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 08-29-2011, 08:20 AM   #1838
The linked pdf does seem strange, you have to click on some areas to dislpay the hidden text. I would instead go to http://www.teamtrf.com/index.php/set...gory/34-trf417 and select the 5th one down 'TRF417_JGroskamp Snowbirds'.
Toon is offline   Reply With Quote
Old 08-29-2011, 08:38 AM   #1839
Hi all
When servicing my car I noticed the end of the pulley plate (blue disc) had become detached from the pulley and was just wobbling around on the layshaft.
When I built the car I did shim it differently to the instructions(the pulleys rubbed on the top deck if I did that) anyone else had this problem? Or not shimmed the pulleys like the instructions.
Cheers
Old 08-29-2011, 09:18 AM   #1840
kedal's Avatar
Hi just had the same "problem" on last saturday. I built the car like the instruction said.
I just rebuilt the blue pulley for now, I see if it's enough during the next sunday as I have a race.
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 08-29-2011, 10:52 AM   #1841
thanks for that, hopefully our fixes will work
I reheated the disc over a stove and then fitted it back on the pulley so it contracted against the pulley.
Its wierd as the rest of the car looks almost new including the drive shaft protectors as we are running 13.5 blinky at our club now.
Old 08-30-2011, 02:25 AM   #1842
please can someone tell me if the first generation 417(ball diff gen) uses 46 or 44mm driveshafts? i started building a second gen 417 and it has 44mm driveshafts. i thought that gen 1 has 46mm.
the greek is offline   Reply With Quote
Old 08-30-2011, 02:42 AM   #1843
The '1st release' 417 comes with 44mm shafts front & rear.
If using the front spool, 46mm steel shafts are a recommended upgrade, but I found that 46mm shafts are bit tight when using a gear diff (front or rear), so use 44mm.
Old 08-30-2011, 02:42 AM   #1844
Trader Rating: 69 (100%+)
TRF417 uses all 44mm driveshafts. Only the older TRF416 uses 46mm driveshafts.
eComet is offline   Reply With Quote
Old 08-30-2011, 04:33 AM   #1845
FunkyDunky's Avatar
+1
I always use 46mm on the front with a spool, much more reliable
FunkyDunky is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
