Old 07-16-2011, 05:39 PM   #1726
GeorgePravata's Avatar
Trader Rating: 106 (100%+)
Can somebody tell me what weight oil come in the tamiya geared diff.v2
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 07-16-2011, 10:38 PM   #1727
Pro10noob's Avatar
It has been mentioned before here
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-17-2011, 10:08 AM   #1728
Thumbs up Tamiya TRF417 Ceramic Bearings
We have released our Tamiya TRF 417 Ceramic Ball Bearing Kit. Higher speeds, greater snap, and greater durability. $99.99 with FREE shipping worldwide.
ACER Racing: the Fastest, Smoothest, Lightest & HARDEST BALLS in the INDUSTRY.
acerracing is offline   Reply With Quote
Old 07-22-2011, 08:44 AM   #1729
syndr0me's Avatar
Trader Rating: 32 (100%+)
What do you guys do for your foam bumper? The Tamiya one is really too soft to protect the front end. I've been using the Parma T2 bumpers, but they tend to rub on the edges and upset the car in the sweeper. I'm constantly trimming them to keep the rub at a minimum.
syndr0me is offline   Reply With Quote
Old 07-22-2011, 09:04 AM   #1730
Pro10noob's Avatar
Stop hitting things??
Just kidding
Don't have any problems with the stock Tamiya foam bumpers
regards Roy
l===/o\===l
Old 07-22-2011, 09:26 AM   #1731
John.C's Avatar
Trader Rating: 36 (100%+)
I've been using a combination of the SQUARE's hard plastic guard and the Parma's T2 foam bumper with great success. The SQUARE guard is a direct fit with no need for modification. It'll remedy your issue of the foam edges rubbing on sweepers/turns and will keep suspension breakage to a minimum as the plastic guard sticks out further.
The edges of the plastic guard with bend down over time (due to hitting the curbs). Just flip it over when this happens and you'll be good to go.
The item can be found here.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 07-23-2011, 09:10 AM   #1732
Greater Snap WTF lol! Oh and a lighter wallet!
Smartypants is offline   Reply With Quote
Old 07-23-2011, 10:52 PM   #1733
Tron's Avatar
Trader Rating: 16 (100%+)
Is there a better driveshaft blade that can be used on the 417 shafts? The Tamiya ones are soft and wear too quickly.
Has anyone used xray blades? Maybe you have to dremel the outdrives to fit them but maybe a better option??
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 07-23-2011, 11:43 PM   #1734
Pro10noob's Avatar
Perhaps the 3Racing blades are a option??
If you use the Xray, you need to dremel out the outdrives to get them to fit.
regards Roy
l===/o\===l
Old 07-24-2011, 08:35 AM   #1735
syndr0me's Avatar
I never had trouble with the Tamiya blades until we started using gear diffs. Now they seem to get beat up pretty bad, especially in the front. I've got a couple of outdrives that are tore up. Hopefully they start selling those separately.
Old 07-24-2011, 10:41 AM   #1736
kedal's Avatar
What about specR's ones ? Better ? someone tried it ?
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 07-25-2011, 03:04 AM   #1737
TryHard's Avatar
Hey All,
Well just had two weekends of decent practise, at two completely different tracks. Now pretty happy with how I've got the 7 dialled, although still struggle a little to decide which way to go on the camber links at one of the tracks... anyway.
First up, went to the big 8th gas track not far from Downtown shanghai. Track temp was well above 65C, so it was hooooot (i was melting in the pits!). Anyway, ran through a program of testing stuff like cut top deck, back-backs on bodyshell, camber link positions, and also wheelbase. Struggled all day to stop the rears overheating after about 3mins, but that is mostly down to running Powers36's when I really should have found some 40's!
Anyway some thoughts after that day...
Thicker shock oil is massively the way forward in that heat (ok, duh, but it's nice to prove the theory ). Switched out the shocks from MM500 to Losi50, and it even only using the calibrated hand could I tell the tyres weren't heating up as much after a run, and the performance was simply better throughout the run.
Trying the cut top deck was a bit more interesting. I was expecting quite a big change to how the car was performing, but actually it was more subtle. The car had a little more rear bite (so perfect to help when the tyres got hot), and overall a little more all-round grip... but it didn't turn into the flopy unresponsive monster I was expecting! For that track, I'll certainly be using that deck as my base setup for the future.
I did also again try the steering brace out, seems to work better in combination with the cut top deck. Before I've never liked it as I personally think it gives a wooley feel to the steering, and seems inconsistent to drive. However that didn't appear to happen with the cut deck (or maybe I'm just imagining things! )
Last thing I did try was moving the whole wheelbase back 0.5mm (so 0.5 behind front arm, 3.5 in front of rear, and 1.5mm on the ackerman), and this also had a good positive effect, seemingly making the car a bit more stable.
Didn't get round to trying the spilt blocks, or the front gear diff (simply ran out of time, and can't find a split 1XA anywhere!), but quite happy with how the car was going on a lowish traction, very hot track.
Now this past weekend I went to the very high traction, indoor asphalt track which I had struggled at last time with traction rolling.
Anyway, started out with the same setup as before (D/B up front, gear diff, standard wheelbase, standard top deck), with the exception of keeping the Losi50wt in the shocks. Overall the car was good, over-rotating a bit on the exit as previously, but a lot more settled (although the traction wasn't as high)... i guess another "dur" moment there.
Still tried out a little less front sweep, going from D/B to C/B and that helped to stop the exit overrotation. The front end also felt a bit more planted and in the long left hander in the middle, was much more consistent, hitting the apex much more regularly. Tick the box for an improvement...
Next up I wanted to try the cut top deck again, and see how it felt on a much higher traction surface. As previously, gained rear end traction, but this time the car had become much harder to drive consistently, with the feeling it was to hook in one lap, and washing wide the next. Also felt that the car was more unresponsive too... or in other words, as you would expect ("dur" no3 ). Laptimes showed that, as the consistency dropped, although the fastest was similar.
Anyway, I did run out of time to test much more stuff, apart from trying the standard top deck with no steering brace (still not convinced) as I switched my attention to testing out a prototype motor for the rest of the day.
I did notice that the was steadily moving towards increased rear traction on entry the whole time I was motor testing, and I'm putting that down to old tyres/changing track, but I have some ideas of how to sort this.
Apologies for the long and rambling post, but well... I'm bored in the office, and it's 36C outside, so there's no way I'm leaving it anytime soon
HiH
Ed
Old 07-25-2011, 03:09 AM   #1738
TryHard's Avatar
Actually... I forgot to add something...
I've been trying out the Tune-Up RC steel outdrives on my spool, and well, at the moment, not so impressed.
The set I've been running were brand new, and after one day with a 4.5t, already are notched bad enough that I had to sand them down to slide the bearing off!
I am using steel 44mm driveshafts, but given they were lubed up before use, thats not brilliant wear!
I'll be looking to get some Roche ones and see how they compare instead...
Old 07-25-2011, 03:22 AM   #1739
FunkyDunky's Avatar
Originally Posted by TryHard View Post
Hey All,
HiH
Ed
Hi Ed, Let me know if you still need the split 1XA I have a new set knocking around in my box that I have no use for currently
FunkyDunky is offline   Reply With Quote
Old 07-25-2011, 11:14 AM   #1740
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
To adjust rear toe, which block do I need to change? I see that different combinations can give the same toe but different track widths. I'm thinking, to keep it more simple, is to adjust width with hexes and shims and to use the blocks just for toe adjustment. Right now I'm running 1XA and 1E in the rear.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
