Old 06-21-2011, 01:43 PM   #1621
Pro10noob's Avatar
Can only comment on the one i have mounted on my Sakura Zero.
They are good.
No problems so far and i have used and abused the car from the end of last year.
regards Roy
Originally Posted by PizzaDude View Post
How do 3racing suspensionmounts compare to original Tamiya ones?
(quality-wise)
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-21-2011, 01:44 PM   #1622
marcel p's Avatar
Send a message via MSN to marcel p
Originally Posted by Pro10noob View Post
Your fast Rogier
Very fast
regards Roy
Ps you don't have a 416 some where lurking ready to be sold??
my 416x wil be sold after ets final round in andernach.
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 06-21-2011, 01:51 PM   #1623
Pro10noob's Avatar
Hey Marcel,
Pm me as i have 2 mates of mine who are looking for one.
Send me some pic's and price on what you have in mind for the car and what is with the car.
regards Roy
l===/o\===l
Old 06-21-2011, 07:42 PM   #1624
TryHard's Avatar
Originally Posted by Tron View Post
I think FX2 is too aggressive for run-in tires and causes some overheat issues especially on asphalt...making the run inconsistent.
FX2 is the least aggressive I've run so far... T-Cube was ok, and LRP carpet 2 (yes, carpet on asphalt) was waaaaay too aggressive. I've also tried Tweak, MR, and CS, and FX2 still comes out the best.
Bear in mind though that the additive procedure I'm using is not exactly standard. Don't wipe the tires, just apply 10mins before the run, then hit the track with them still wet. No warmers either. Honestly, if I could get away without running additive I would, but with the tyre hardness (36), it's needed to get them working right from the start.
Regards
Ed
Old 06-21-2011, 10:21 PM   #1625
PizzaDude's Avatar
Regards
Ed
Wouldn't heating them, help you with that?
PizzaDude is offline   Reply With Quote
Old 06-21-2011, 10:55 PM   #1626
if u run the car with wet FX2 on tire, your car tend to spin, tire dont grip at all...
The Dark Force of Racing
- EP Dungeon -
zamrioo2 is offline   Reply With Quote
Old 06-22-2011, 12:08 AM   #1627
TryHard's Avatar
No offence, but that isn't the case at all. On a normal type asphalt track I would absolutely agree with you, but for this track the traction is mega high, and literally the wet doesn't stay for even half a lap. When we're running 10min races (with 11.5's) anything to extend additive life is a good thing!
Warming works to an extent, but the grip is just that much higher than anything else I've run on, bar the TITC track, that it just isn't needed in combination with the right additive schedule. Pretty much like a carpet track really...
Old 06-22-2011, 03:41 PM   #1628
Little bit random, but I got my titanium turnbuckles today (TRF official ones) and they look green not blue! Anyone else had that? Or are they greeny blue nowadays? (looks aweful on the car.. Shallow I know)
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-22-2011, 03:56 PM   #1629
Although the ones I purchased are TRF blue I've seen them in the color you describe. Not pretty, but they work just the same.
Cheers
Turillo is offline   Reply With Quote
Old 06-22-2011, 04:19 PM   #1630
syndr0me's Avatar
Trader Rating: 32 (100%+)
The new gear diff seems pretty great. It's so... white. The plastic they used for the housing is unusual. I built it like Jilles suggested, with 3 shims and the crown gears filed down flat. No issues in 17.5. I'll test it out with some mod next week.
syndr0me is offline   Reply With Quote
Old 06-22-2011, 04:35 PM   #1631
hanulec's Avatar
Trader Rating: 23 (100%+)
huh? i thought u were XRay for life now?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-22-2011, 04:46 PM   #1632
syndr0me's Avatar
It's a very nice car, and has the predictable, stable feel on the track the Tamiya sometimes lacks. But right now, it's slower. I'm going to put some time in trying out some other setup ideas next week.
In the meantime, the 417 is behaving well enough if I make it push a little and steer with some throttle/brake.
Old 06-22-2011, 07:20 PM   #1633
TryHard's Avatar
Default Split suspension mount brace
So, as in one of my previous posts, I thought I'd try making up a brace to match the stiffness of the one-piece suspension mounts, when using the split suspension mounts.
Thankfully I had a damaged 417 chassis plate that I could use, and cut a thin strip of carbon from it (making it orientated longitudinally for stiffness), drilling a couple of holes using a one-piece mount as a guide. Then using some longer screws on the inner positions, a couple of 0.5mm spacers for belt clearance, bolted it all together.
Only other thing I did was sand some of the corners slightly to a curve, so as to not touch the block and introduce tweak into the chassis.
It's a bit rough and ready, but should do the trick to try and see if I can feel any difference next time out If it works well enough, I'll make one up for the rear of the car as well. I should mention that it does make changing the roll centres a bit of a pain, as you need to use on the flat tamiya nut wrenches to undo the bolts without taking the bulkheads off (they block a nut driver getting in).
Also attaching a picture of my car from last weekend
Old 06-22-2011, 10:52 PM   #1634
Cheers
Thanks, it's annoying as they were described as blue on the listing.. Why would anyone want that colour?
Tryhard - the brace looks interesting. I think 3 racing make carbon suspension block parts(they come with their alum blocks) so people could use them instead if having to source and cut carbon.
Be interesting to see how it performs.
Old 06-22-2011, 10:58 PM   #1635
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
its kinda hard to get an exact shade of blue when anodizing titanium as the process relies on a specific voltage passed through the piece (instead of using a dye like when anodizing aluminum).
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
